When I run gamescope in fullscreen or make it fullscreen after I launch it in window mode, it freezes the whole screen and I have to kill it. The second screen is not affected. Unfortunately there is no error message by gamescope nor a kernel error from the driver.
As a temporary workaround you have to start the application in fullscreen mode, but then you won’t be able to go back to windowed so yeah… Furthermore I notice weird frame fluctuation on some games using gamescope.
I can not start it in fullscreen, as described in my initial post. It shows the exact same behaviour. The only way I can use it at the moment is either in window or borderless.
Hi All,
Can you please try with older driver version to confirm if this is indeed a driver regression.
Also just wanted to check if freeze issue happens with Cinnamon or any other desktop environment also ?
Older driver versions are no option, as gamescope only started to work with 515.48.07 on Nvidia. I’ve tried all stable versions since then, including the latest Beta 525.53, and it happens with all of them.
From my testing it happens only with Cinnamon so far(others I’ve tried are KDE Plasma under Xorg and Wayland, as well as Gnome Wayland). It seems to not be driver affected from all 515.48.07 till the beta 525.53 including.
No CAP_SYS_NICE, falling back to regular-priority compute and threads.
Performance will be affected.
wlserver: [backend/headless/backend.c:82] Creating headless backend
vulkan: selecting physical device 'NVIDIA GeForce GTX 1070 Ti': queue family 2
vulkan: physical device supports DRM format modifiers
vulkan: vkGetPhysicalDeviceFormatProperties2 returned zero modifiers for DRM format 0x3231564E (VkResult: 0)
vulkan: supported DRM formats for sampling usage:
vulkan: 0x34325241
vulkan: 0x34325258
vulkan: physical device queue doesn't support presenting on our surface
vulkan_make_output failed
Violación de segmento (`core' generado)
this is my output in my kde over wayland, launched with this command:
Is there any error message ? Have you tried launching steam through terminal and then setting gamescope for the game, checking if terminal indicates an issue ? Have you tried setting gamescope to windowed or borderless, not just fullscreen ? Additionally which is the Desktop Environment/Distro which you use ? I haven’t had problems running it across - Cinnamon(though fullscreen doesn’t work there), Gnome and KDE(for Gnome & KDE I got much better results in wayland than x11)
