[580.105.08 Regression] Hibernate (S4) no longer powers off, fans stay on, resume still works
Hi, I’m seeing a regression specifically in 580.105.08. Hibernate (ACPI S4) worked on 580.95.05 and stopped working immediately after updating to 580.105.08. Nothing else in my setup changed.
What happens now is:
The system writes the hibernate image, the display shuts off, USB briefly power-cycles, but the system never actually powers down. Fans keep running, power LED stays on forever, and I have to do a manual power button shutdown. After that, the system does resume from the hibernate image just fine, so the snapshot is being created properly - the machine just never transitions into S4.
System details:
  • GPU: RTX 3060 Ti
  • Driver package: nvidia-dkms
  • Working version: 580.95.05
  • Broken version: 580.105.08
  • Kernels tested:
    • 6.17.8-zen
    • 6.12.58-lts
      (same issue across all)
  • Distro: Arch Linux
  • Display server: Wayland
  • Motherboard: MSI PRO Z690-A DDR4
  • Hibernate config:
    • HibernateState=disk
    • HibernateMode=shutdown
  • Swap on disk (not encrypted)
This is the upgrade timeline from pacman:
[2025-11-07] upgraded nvidia-dkms (575.64.03 → 580.95.05)
[2025-11-14] upgraded nvidia-dkms (580.95.05 → 580.105.08)
Hibernate still worked on 580.95.05 and broke only after the 580.105.08 update. Here’s the journal output from a failing hibernate attempt on 580.105.08:
systemd-sleep[1723]: Performing sleep operation 'hibernate'...
PM: hibernation: Creating image:
PM: hibernation: Need to copy 1222466 pages
PM: hibernation: Normal pages needed: 1222466 + 1024, available pages: 2922493
PM: hibernation: hibernation exit
systemd-sleep[1723]: System returned from sleep operation 'hibernate'.
systemd-logind[504]: Operation 'hibernate' finished.
NVIDIA’s hibernate/resume services report success but the system never shuts off:
Starting NVIDIA system hibernate actions...
nvidia-hibernate.service: Deactivated successfully.
Starting NVIDIA system resume actions...
nvidia-resume.service: Deactivated successfully.
Physical behavior:
– screen off
– keyboard LEDs off → immediately on
– fans keep spinning
– system stays powered indefinitely
– manual shutdown required
– next boot resumes correctly
Rolling back from 580.105.08 → 580.95.05 restores correct S4 behavior immediately.
I can attach a full nvidia-bug-report.sh log, PM trace, or ACPI trace if needed. Just let me know what’s useful.
Confirming the S4 regression (first seen in 580.105.08) persists in 590.48.01.
Setup: RTX 3060 Ti, Arch Linux, 6.18-zen, Wayland.
Regression: 580.95.05 (Working) → 580.105.08+ (Broken).
Symptoms:
Snapshot and resume work correctly, but the system never reaches ACPI S4 power-off.
  • With hooks enabled: Fans/LEDs stay on indefinitely; requires manual shutdown.
  • With hooks disabled: System resumes immediately after image creation.
Attached are nvidia-bug-report.sh logs (including acpidump) for both hook states. Rolling back to 580.95.05 immediately restores correct behavior.
nvidia-bug-report-590.48.01-hibernate-hooks-enabled.log.gz (3.0 MB)
nvidia-bug-report-590.48.01-hibernate-hooks-disabled.log.gz (3.0 MB)
confirming I see this same issue as well on my laptop.
Arch Linux 6.17.1
Nvidia RTX 4050 Laptop GPU
Wayland
The issue seems to have finally been fixed for me with the 580.159.03 update.
I had the issue from 580.105.08 (Nov 2025) to 580.142 (March 2026).
I’m only using 580 branch, because my GPU (GTX 970) is not supported by 590.X and newer.
595.71.05 on 7.0.3-arch1-1 still failing to power off
Switching nvidia driver to 580.105.08 does work correctly.
For me, it is also failing to power off both the 580.173.02, 610.57.04-1 and with cachyos nvidia drivers, only 580.105.08 works.
I hope nvidia fixes this anytime soon.
Arch linux
Wayland
