590 release feedback & discussion
@kode54 I don’t use Steam at all: I use vanilla wine-devel (well, almost vanilla: the patched one with ntsync support enabled), but I’ve made a similar mistake: I forgot I run wine in a container, so I didn’t upgrade drivers there ;-]
It all works now: many thanks for pointing me in the right direction!! :)
Well, at least it was userspace, so you didn’t need to reboot to apply the update.
My display still shows a black flicker on the top half every once in a while when watching videos, what bug are you talking about?
590.44.01 regressed the previously (mostly) working Monster Hunter Wilds benchmark. I can gather logs if necessary.
Replying to my own report here: Yeah, verified, this issue was already present in 580.105.08.
It’s been reported by two people me and thrim above with logs using the full game which is way beyond the benchmark now.
If more logs are needed as thrim and i can send the logs on monday
Sorry, I thought I actually read the thread, I guess I haven’t been paying enough attention. :[
Hey, the more logs, the merrier right I just wanna get the game fixed. I think it’s been four driver versions already and still no leeway. And I guess they’re doing other things in the background, but it would be nice just to have a small update.
I was able to install 590 under Arch 6.17 kernel. However, the package was several hundred MB smaller, which made me suspicious. According to this: https://github.com/CachyOS/CachyOS-PKGBUILDS/pull/1008 , there still seems to be quite a bit of work to be done.
Nvidia removed Maxwell/Pascal support. Even the open source driver is full of removals mentioning them.
But, no i’m referring to this:
  -> Building driver version 590.44.01 on branch regular.
  -> Selected driver integrity check behavior (md5sum or SKIP): SKIP
==> Making package: nvidia-open-dkms-tkg 590.44.01-263 (Sat 06 Dec 2025 04:05:28 PM CST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Found NVIDIA-Linux-x86_64-590.44.01.run
  -> Found 10-nvidia-drm-outputclass.conf
  -> Found nvidia-utils-tkg.sysusers
  -> Found 60-nvidia.rules
  -> Found nvidia-tkg.hook
  -> Found gsk-renderer.sh
  -> Found nvidia-open-gcc-ibt-sls.diff
  -> Found gcc-14-470.diff
  -> Found gcc-14.diff
  -> Found linux-version.diff
  -> Found 01-ipmi-vm.diff
  -> Found 02-ipmi-vm.diff
  -> Found list_is_first.diff
  -> Found kernel-4.16.patch
  -> Found kernel-4.19.patch
  -> Found kernel-5.0.patch
  -> Found kernel-5.1.patch
  -> Found kernel-5.2.patch
  -> Found kernel-5.3.patch
  -> Found kernel-5.4.patch
  -> Found kernel-5.4-symver.diff
  -> Found kernel-5.4-prime.diff
  -> Found kernel-5.5.patch
  -> Found kernel-5.6.patch
  -> Found 5.6-legacy-includes.diff
  -> Found 5.6-ioremap.diff
  -> Found kernel-5.7.patch
  -> Found kernel-5.8.patch
  -> Found 5.8-legacy.diff
  -> Found kernel-5.9.patch
  -> Found 5.9-gpl.diff
  -> Found kernel-5.10.patch
  -> Found kernel-5.11.patch
  -> Found 5.11-legacy.diff
  -> Found 455-crashfix.diff
  -> Found kernel-5.12.patch
  -> Found kernel-5.14.patch
  -> Found kernel-5.16.patch
  -> Found kernel-5.16-std.diff
  -> Found kernel-5.17.patch
  -> Found kernel-6.0.patch
  -> Found kernel-6.0-470.patch
  -> Found kernel-6.2.patch
  -> Found kernel-6.3.patch
  -> Found legacy-kernel-6.4.diff
  -> Found kernel-6.4.patch
  -> Found legacy-kernel-6.5.diff
  -> Found kernel-6.5.patch
  -> Found legacy-kernel-6.6.diff
  -> Found 6.1-6-7-8-gpl.diff
  -> Found kernel-6.8.patch
  -> Found make-modeset-fbdev-default.diff
  -> Found make-modeset-fbdev-default-565.diff
  -> Found 6.11-fbdev.diff
  -> Found nvidia-sleep.conf
  -> Found kernel-6.12.patch
  -> Found silence-event-assert-until-570.diff
  -> Found fix-hdmi-names.diff
  -> Found Enable-atomic-kernel-modesetting-by-default.diff
  -> Found Add-IBT-support.diff
  -> Found gcc-15.diff
  -> Found kernel-6.17.patch
==> ERROR: Integrity checks (md5) differ in size from the source array.
  -> exit cleanup done
MD5 checking is skipped yet it errors out. I’ve never seen this when manually specifying driver versions before.
Flickering.
Yeah, nvidia-all has no trouble with 590.44.01 if it’s added formally to the menu options. Apparently the custom version setting is broken and doesn’t put the SKIP selection into the sources hash array?
every apps that uses kpipewire to capture the screen (spectacle, krdp) either save an empty file or crash when kwin is running on the nvidia gpu
System Configuration: [custom desktop, 9800x3d,asus crosshair hero x670e][fedora 43][Plasma desktop][RTX 4070 TI Super][1 gigabyte M28U , 4K 144Hz, displayport]
user session logs from a failed spectacle screencast
dez 06 19:48:31 crosshair-hero spectacle[7084]: libva info: VA-API version 1.22.0
dez 06 19:48:31 crosshair-hero spectacle[7084]: libva info: Trying to open /usr/lib64/dri-nonfree/radeonsi_drv_video.so
dez 06 19:48:31 crosshair-hero spectacle[7084]: libva info: Trying to open /usr/lib64/dri-freeworld/radeonsi_drv_video.so
dez 06 19:48:31 crosshair-hero spectacle[7084]: libva info: Found init function __vaDriverInit_1_22
dez 06 19:48:31 crosshair-hero plasmashell[2084]: QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
dez 06 19:48:31 crosshair-hero spectacle[7084]: libva info: va_openDriver() returns 0
dez 06 19:48:31 crosshair-hero spectacle[7084]: VAAPI: Mesa Gallium driver 25.2.7 for AMD Ryzen 7 9800X3D 8-Core Processor (radeonsi, raphael_mendocino, LLVM 21.1.5,DRM 3.64, 6.17.9-300.fc43.x86_64) in use for device "/dev/dri/renderD129"
dez 06 19:48:31 crosshair-hero kwin_wayland[1913]: 0x502: GL_INVALID_OPERATION error generated. <image> and <target> are incompatible
dez 06 19:48:31 crosshair-hero kwin_wayland[1913]: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
dez 06 19:48:31 crosshair-hero pipewire[1697]: invalid memory type 8
dez 06 19:48:31 crosshair-hero kwin_wayland[1913]: "2233,115 1017x761" Received stream buffer that does not contain user data
nvidia-bug-report.log.gz (1.2 MB)
==> Betrete fakeroot Umgebung...
`/syhhhyso-           -osyhhhys/`
.syNMdhNNhss/``.---.``/sshNNhdMNys.
+sdMh.`+MNsssssssssssssssNM+`.hMds+
:syNNdhNNhssssssssssssssshNNhdNNys:
/ssyhhhysssssssssssssssssyhhhyss/
.ossssssssssssssssssssssssssssso.
:sssssssssssssssssssssssssssssssss:
/sssssssssssssssssssssssssssssssssss/
:sssssssssssssoosssssssoosssssssssssss:
osssssssssssssoosssssssoossssssssssssso
osssssssssssyyyyhhhhhhhyyyyssssssssssso
/yyyyyyhhdmmmmNNNNNNNNNNNmmmmdhhyyyyyy/
smmmNNNNNNNNNNNNNNNNNNNNNNNNNNNNNmmms
/dNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNd/
`:sdNNNNNNNNNNNNNNNNNNNNNNNNNds:`
`-+shdNNNNNNNNNNNNNNNdhs+-`
-> External configuration file '/home/damachine/.config/frogminer/nvidia-all.cfg' will be used to override customization.cfg values.
-> Checking open driver availability...
==> Beginne package_nvidia-open-dkms-tkg()...
==> Säubere Installation...
-> Purging unreproducible ruby files...
-> Entferne libtool Dateien...
-> Bereinige ungewollte Dateien...
-> Entferne statische Bibliotheken...
-> Komprimiere Man-Pages und Info-Seiten...
==> Prüfe auf Paketierungsprobleme...
==> Erstelle Paket "nvidia-open-dkms-tkg"...
-> Erstelle .PKGINFO Datei...
-> Erstelle .BUILDINFO Datei...
-> Erstelle .MTREE-Datei...
-> Komprimiere Paket...
==> Beginne package_nvidia-utils-tkg()...
==> Erstelle Paket "nvidia-utils-tkg"...
-> Füge install Datei hinzu...
==> Beginne package_lib32-nvidia-utils-tkg()...
==> Erstelle Paket "lib32-nvidia-utils-tkg"...
==> Beginne package_opencl-nvidia-tkg()...
==> Erstelle Paket "opencl-nvidia-tkg"...
==> Beginne package_lib32-opencl-nvidia-tkg()...
==> Erstelle Paket "lib32-opencl-nvidia-tkg"...
==> Beginne package_nvidia-settings-tkg()...
==> Erstelle Paket "nvidia-settings-tkg"...
==> Verlasse fakeroot Umgebung.
==> Beendete Erstellung: nvidia-open-dkms-tkg 590.44.01-263 (So 07 Dez 2025 01:03:26 CET)
==> Installiere Paketgruppe nvidia-open-dkms-tkg mit pacman -U...
Pakete werden geladen …
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
:: nvidia-open-dkms-tkg-590.44.01-263and nvidia-dev-open-dkms-tkg-580.94.11-263 are in conflict (nvidia-open). Remove nvidia-dev-open-dkms-tkg? [j/N] j
:: nvidia-utils-tkg-590.44.01-263and nvidia-dev-utils-tkg-580.94.11-263 are in conflict (nvidia-utils). Remove nvidia-dev-utils-tkg? [j/N] j
:: lib32-nvidia-utils-tkg-590.44.01-263and lib32-nvidia-dev-utils-tkg-580.94.11-263 are in conflict (lib32-nvidia-utils). Remove lib32-nvidia-dev-utils-tkg? [j/N] j
:: opencl-nvidia-tkg-590.44.01-263and opencl-nvidia-dev-tkg-580.94.11-263 are in conflict (opencl-nvidia). Remove opencl-nvidia-dev-tkg? [j/N] j
:: lib32-opencl-nvidia-tkg-590.44.01-263and lib32-opencl-nvidia-dev-tkg-580.94.11-263 are in conflict (lib32-opencl-nvidia). Remove lib32-opencl-nvidia-dev-tkg? [j/N] j
:: nvidia-settings-tkg-590.44.01-263and nvidia-dev-settings-tkg-580.94.11-263 are in conflict (nvidia-settings). Remove nvidia-dev-settings-tkg? [j/N] j
Paket (12)                   Alte Version   Neue Version   Netto-Veränderung
lib32-nvidia-dev-utils-tkg   580.94.11-263                       -277,47 MiB
lib32-opencl-nvidia-dev-tkg  580.94.11-263                        -21,95 MiB
nvidia-dev-open-dkms-tkg     580.94.11-263                       -119,34 MiB
nvidia-dev-settings-tkg      580.94.11-263                         -1,74 MiB
nvidia-dev-utils-tkg         580.94.11-263                       -901,06 MiB
opencl-nvidia-dev-tkg        580.94.11-263                        -85,70 MiB
lib32-nvidia-utils-tkg                      590.44.01-263         279,87 MiB
lib32-opencl-nvidia-tkg                     590.44.01-263          17,40 MiB
nvidia-open-dkms-tkg                        590.44.01-263         120,16 MiB
nvidia-settings-tkg                         590.44.01-263           1,74 MiB
nvidia-utils-tkg                            590.44.01-263         764,17 MiB
opencl-nvidia-tkg                           590.44.01-263          90,00 MiB
Gesamtgröße der installierten Pakete: 1273,35 MiB
Größendifferenz der Aktualisierung:   -133,91 MiB
:: Installation fortsetzen? [J/n]
(6/6) Schlüssel im Schlüsselbund werden geprüft        [------------------------------------------------------------------------------------------] 100%
(6/6) Paket-Integrität wird überprüft        [------------------------------------------------------------------------------------------] 100%
(6/6) Paket-Dateien werden geladen        [------------------------------------------------------------------------------------------] 100%
(6/6) Auf Dateikonflikte wird geprüft        [------------------------------------------------------------------------------------------] 100%
(12/12) Verfügbarer Festplattenspeicher wird ermittelt        [------------------------------------------------------------------------------------------] 100%
:: Pre-transaction-Hooks werden gestartet …
(1/2) etckeeper: pre-transaction commit
(2/2) Remove DKMS modules
==> dkms remove --no-depmod nvidia/580.94.11 -k 6.17.10-273-linux-tkg
==> depmod 6.17.10-273-linux-tkg
:: Paketänderungen werden verarbeitet …
(1/6) Entfernung läuft nvidia-dev-settings-tkg        [------------------------------------------------------------------------------------------] 100%
(2/6) Entfernung läuft lib32-opencl-nvidia-dev-tkg        [------------------------------------------------------------------------------------------] 100%
(3/6) Entfernung läuft opencl-nvidia-dev-tkg        [------------------------------------------------------------------------------------------] 100%
(4/6) Entfernung läuft lib32-nvidia-dev-utils-tkg        [------------------------------------------------------------------------------------------] 100%
Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
(5/6) Entfernung läuft nvidia-dev-utils-tkg        [------------------------------------------------------------------------------------------] 100%
(6/6) Entfernung läuft nvidia-dev-open-dkms-tkg        [------------------------------------------------------------------------------------------] 100%
(1/6) Installiert wird nvidia-open-dkms-tkg        [------------------------------------------------------------------------------------------] 100%
Optionale Abhängigkeiten für nvidia-open-dkms-tkg
linux-headers [Installiert]
   linux-lts-headers: Build the module for LTS Arch kernel
(2/6) Installiert wird nvidia-utils-tkg        [------------------------------------------------------------------------------------------] 100%
Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' → '/usr/lib/systemd/system/nvidia-hibernate.service'.
Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' → '/usr/lib/systemd/system/nvidia-suspend.service'.
Optionale Abhängigkeiten für nvidia-utils-tkg
gtk2: nvidia-settings (GTK+ v2)
   gtk3: nvidia-settings (GTK+ v3) [Installiert]
   opencl-nvidia-tkg: OpenCL support [ausstehend]
   xorg-server [Installiert]
   xorg-server-devel: nvidia-xconfig
   egl-wayland-git: for alternative, more advanced Wayland library (libnvidia-egl-wayland.so)
(3/6) Installiert wird lib32-nvidia-utils-tkg        [------------------------------------------------------------------------------------------] 100%
Optionale Abhängigkeiten für lib32-nvidia-utils-tkg
lib32-opencl-nvidia-tkg: OpenCL support [ausstehend]
(4/6) Installiert wird opencl-nvidia-tkg        [------------------------------------------------------------------------------------------] 100%
Optionale Abhängigkeiten für opencl-nvidia-tkg
opencl-headers: headers necessary for OpenCL development [Installiert]
(5/6) Installiert wird lib32-opencl-nvidia-tkg        [------------------------------------------------------------------------------------------] 100%
Optionale Abhängigkeiten für lib32-opencl-nvidia-tkg
(6/6) Installiert wird nvidia-settings-tkg        [------------------------------------------------------------------------------------------] 100%
Optionale Abhängigkeiten für nvidia-settings-tkg
:: Post-transaction-Hooks werden gestartet …
( 1/12) Creating system user accounts...
( 2/12) Reloading system manager configuration...
( 3/12) Restarting marked services...
( 4/12) Reloading device manager configuration...
( 5/12) Arming ConditionNeedsUpdate...
( 6/12) Install DKMS modules
==> dkms install --no-depmod nvidia/590.44.01 -k 6.17.10-273-linux-tkg
( 7/12) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-tkg.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
 -> -k /boot/vmlinuz-linux-tkg -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-tkg.img
==> Starting build: '6.17.10-273-linux-tkg'
 -> Running build hook: [base]
 -> Running build hook: [systemd]
 -> Running build hook: [autodetect]
 -> Running build hook: [microcode]
 -> Running build hook: [modconf]
 -> Running build hook: [keyboard]
 -> Running build hook: [sd-vconsole]
 -> Running build hook: [block]
 -> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating uncompressed initcpio image: '/boot/initramfs-linux-tkg.img'
 -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
( 8/12) Cleaning pacman cache...
==> no candidate packages found for pruning
( 9/12) Cleaning unused localizations system files...
Wiedergewonnener Speicherplatz: 0B
Gelöschte Dateien: 0
(10/12) Reloading system bus configuration...
(11/12) Updating the desktop file MIME type cache...
(12/12) etckeeper: post-transaction commit
Action completed: 2025-12-07 01:04:23
Status: Successfully completed!
Duration: 3 min 36 sec
──  v0.27.8  ──
Closed.
build and install was succesful!
The latest I have on the RTX 5080 + Sonnet 850T5 + Rocky Linux 10 + Thinkpad X1 Carbon Gen 11(TB4) is at 2023 14″ Lenovo ThinkPad X1 Carbon Gen 11 [13th,10C,U] + RTX 5080 @ 32Gbps-TB4 (Sonnet Breakaway Box 850T5) TB5 eGPU – hard lock on CUDA operations (nvidia-smi works at idle) => patch fixed | Thunderbolt Linux eGPU and (gh-979) Thunderbolt 4/5 and USB4 eGPU Support by roger-pmta · Pull Request #981 · NVIDIA/open-gpu-kernel-modules · GitHub . Without additional support from NVIDIA and Sonnet, I’m at a loss.
nvidia-bug-report.log-3.gz (1.6 MB)
The nvidia-all installation worked successfully for me during testing. However, the nvidia-all package probably still needs to be adjusted because some things in the 590 driver have changed, and the patches and libraries aren’t being applied.
I read somewhere that legacy devices are still supported via the proprietary driver, but apparently only the open-source driver will work in the future. I can’t remember where I read that, I think it was on GitHub.
Please stop posting here nvidia-all issues. This is nothing provided by NVIDIA or equal. Its not an official nvidia installer.
Make issues in the repo of the third party project
If you read the original question, you’d realize I was asking if Nvidia’s driver release was broken.
And driver changes that break third party installs is “feedback”.
True words. I was only interested in post (45), the error has been identified <3 but that doesn’t belong here and I won’t discuss it further.<(_ _)>
My apologies for interrupting everyone’s normal scheduled program of screaming into the void about bugs that (at least some) have existed for years. Lets return to that productive discussion.
Here is a list of issues that still exist in 590 and were reported ATLEAST in 580:
  • Random black screens when playing intensive games, sometimes resulting in a partial GPU driver crash. It is sometimes possible to switch to a TTY, but attempting to switch back to a graphical session will crash the driver for good.
  • Desktop memory usage is excessively high(over 2GB sometimes).
  • A large amount of GPU Memory is unaccounted for in nvidia-smi / NVML.
  • Applications crash when VRAM is full.
  • Shared RAM under Linux seems broken. It’s almost like there is an incredibly small amount(256MB) and once that’s gone things start crashing.
  • DLSS3 / DLSS4 / Smooth Motion is broken. It universally lowers FPS and can cause massive input lag and micro stuttering.
  • Gnome-shell / GDM can freeze on login from a fresh boot. Switching to a TTY and relogging in works around this.
  • Ray Tracing is broken on a lot of games, resulting in an XID 109 or some other error.
  • Some games show DLSS upscaling options but no frame generation(Portal 2: RTX). Maybe a Proton issue?
  • Dragging the HDR slider under Gnome can cause a driver crash(maybe fixed?).
  • DX12 games have a massive performance penalty.
  • VRR causes backlight strobing/flickering
  • Shader cache doesn’t save properly, forcing it to be computing again.
  • Flickering in Resident Evil 4 - reported by @arthursamuelcoombes
Am I missing some?
Edit: ok, so I lied. Just going to throw it out there that if you are using nvidia-all and want to switch back to Arch’s package, you need to do:
sudo pacman -S lib32-nvidia-utils lib32-opencl-nvidia nvidia-open-dkms nvidia-settings nvidia-utils opencl-nvidia egl-wayland
(change nvidia-open-dkms to the closed source if wanted/needed)
Make sure to check if you have any “tkg” driver packages left over, but for me this was everything.
