When for DGX Spark GB10, please?
Many thanks!
Many thanks!
is this fully supported tho?
i don’t see gb10 under supported devices in op’s link
Driver 595 is not yet supported on DGX Spark
@aniculescu , then what was the purpose of the June Software release?
Just received notice there’s new firmware form my GB10. Any chance this allows the 595+ drivers?
13.2 had some issues, so maybe we will jumb strait to 13.3 … August?
Already running on Ubuntu 26.04 LTS — driver 595.71.05, CUDA 13.2, open kernel module, GB10 detected, with vLLM serving from a CUDA 13.2 container.
$ . /etc/os-release; echo "$PRETTY_NAME"
Ubuntu 26.04 LTS
$ uname -m -r
aarch64 7.0.0-1006-nvidia
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX Open Kernel Module for aarch64 595.71.05 Release Build
GCC version: gcc version 15.2.0 (Ubuntu 15.2.0-16ubuntu1)
$ nvidia-smi
| NVIDIA-SMI 595.71.05 Driver Version: 595.71.05 CUDA Version: 13.2 |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 Off | N/A |
| N/A 47C P0 12W / N/A | Not Supported | 0% Default |
| Processes: |
| 0 N/A N/A 3005622 C VLLM::EngineCore 95665MiB |
# inside the vLLM container (CUDA 13.2 toolkit):
$ nvcc --version | tail -2
Cuda compilation tools, release 13.2, V13.2.51
Build cuda_13.2.r13.2/compiler.37434383_0
Edit: I’m running this server headless, never tried display output
Do you notice any difference after upgrading?
I haven’t upgraded. Very first thing I’ve done is installed from ubuntu server iso and wiped the nvidia OS. There were some minor quirks first (I think I had the stock kernel, not the nvidia version, and i was experiencing the PD bug) but resolved these. No issues eversince, Using it everyday for a bit of inference and as my home server.
We know - but WHY?
this is not “bleeding edge” anymore its been a long time and the customers are waiting.
If its listed in Supported GPU Products lists, then it should be deployed to Sparks. Why the massive lag in deployment times?
When? Due date, please!
Many thanks in advance!
CM
I’m thinking to install ubuntu 26.04 too and convert to ZFS (to control file cache size through arc_max, also to use compression). You’ve installed nvidia kernel from the nvidia repository?
No, theres an nvidia flavored kernel in the official ubuntu repos.
Here are some of my recent benchmarks on the Ubuntu 26.04 system:
Gemma 4 31B on DGX Spark GB10 — NVFP4 vs QAT (fp8 KV)
Hardware/runtime (both runs): DGX Spark GB10 (Grace Blackwell, SM121, 122 GiB UMA),
Docker image vllm-node-tf5, single GPU (TP=1), dtype=bfloat16,
CUDA graphs FULL_AND_PIECEWISE, torch.compile (inductor).
| NVFP4 | QAT — fp8 KV | |
| vLLM version | 0.20.2rc1.dev234+gcf0d27914 (2026-05-11) |
0.22.1rc1.dev124+gace95c9cf (2026-06-03) |
| Main model | nvidia/Gemma-4-31B-IT-NVFP4 |
google/gemma-4-31B-it-qat-w4a16-ct |
| Quant method | modelopt_fp4 (NVFP4) |
compressed-tensors w4a16 → Marlin kernel |
| Drafter (MTP) | gemma-4-31B-it-assistant |
gemma-4-31B-it-qat-q4_0-unquantized-assistant |
num_speculative_tokens |
10 | 8 |
| KV cache dtype | fp8 (baked into NVFP4) | fp8 (--kv-cache-dtype fp8) |
max-model-len |
262144 | 262144 |
gpu-memory-utilization |
0.85 | 0.85 |
| Load format | (InstantTensor) | fastsafetensors |
| Date | 2026-05-12 | 2026-06-15 |
Shared serve flags: --max-num-seqs 4 --max-num-batched-tokens 16384 --enable-prefix-caching --enable-chunked-prefill --enable-auto-tool-choice --tool-call-parser gemma4 --reasoning-parser gemma4 --trust-remote-code --no-enable-flashinfer-autotune --default-chat-template-kwargs '{"enable_thinking": true}'
llama-benchy: --pp 2048 --tg 128 --depth 0 16384 --runs 2 --latency-mode generation
| Config | pp2048 (t/s) | tg128 (t/s) | tg128 peak | pp2048 @16k (t/s) | tg128 @16k (t/s) | tg128 @16k peak |
| NVFP4 | 1763.8 ± 119.4 | 14.8 ± 1.3 | 24.0 | 785.6 ± 1.2 | 17.9 ± 0.6 | 35.5 |
| QAT — fp8 KV | 816.3 ± 23.5 | 25.2 ± 0.2 | 38.5 | 630.8 ± 0.8 | 22.5 ± 3.5 | 33.5 |
pp = prompt processing (prefill), tg = token generation (decode),
@16k = at 16,384-token context depth, peak = best single-run decode rate (MTP acceptance varies).
Takeaways: NVFP4 wins prefill (~2.2x at depth 0). QAT + matched QAT drafter wins decode
(~1.7x at depth 0); the matched drafter is the dominant decode lever.
This tests with 610 driver and cuda 13.3?
By default cuda repo install 595, and i force it to 610 just for check games performance.
