[610.43.02][RTX 5060 Laptop][Lenovo 83LY] Reproducible Xid 79 and GSP heartbeat timeout in nvidia-powerd GSP_RM_CONTROL (0x2080a613)
Reproducible Xid 79 / GSP heartbeat timeout while nvidia-powerd is issuing the same GSP_RM_CONTROL request
Suggested title
Summary
On a Lenovo Legion Y7000 IRX10 / Lenovo machine type 83LY with an NVIDIA
GeForce RTX 5060 Laptop GPU, enabling nvidia-powerd makes a short,
GPU-heavy TensorRT workload reproducibly black-screen the machine.
The GPU disappears from PCIe with Xid 79. The display, keyboard and virtual
terminals stop responding, so a forced power-off is required. Five captured
failures have the same caller (nvidia-powerd) and the same incomplete GSP
RPC:
GSP_RM_CONTROL
data0 0x000000002080a613
data1 0x0000000000013840
The problem reproduced across:
  • NVIDIA 595.84 with Linux 6.8.0-136 on Ubuntu 22.04
  • NVIDIA 610.43.02 open kernel modules with Linux 7.0.0-28 on Ubuntu 24.04.4
  • Lenovo BIOS QNCN38WW (2026-05-21), the latest BIOS offered for this machine
With nvidia-powerd disabled, the GPU is limited to its 50 W base TGP and
the same computer is stable. The GPU is also stable under long CUDA workloads
on Windows on the same hardware.
System information
Laptop: Lenovo Legion Y7000 IRX10
Machine type: LENOVO 83LY / LNVNB161216
BIOS: QNCN38WW, 2026-05-21
OS: Ubuntu 24.04.4 LTS
Kernel: 7.0.0-28-generic
GPU: NVIDIA GeForce RTX 5060 Laptop GPU
PCI ID: 10de:2d59
Subsystem: Lenovo 17aa:3e2e
Driver: nvidia-open 610.43.02
Desktop: GNOME/Wayland, dGPU display mode
The kernel 7.0 Lenovo WMI drivers are present and loaded:
lenovo_wmi_gamezone
lenovo_wmi_other
lenovo_wmi_capdata
lenovo_wmi_helpers
lenovo_wmi_events
/sys/firmware/acpi/platform_profile works and Fn+Q changes profiles.
Reproduction
  1. Select the Lenovo performance profile with Fn+Q.
  2. Start nvidia-powerd. It establishes its D-Bus connection and raises the
    GPU power ceiling from 50 W to as much as 115 W:
    sudo systemctl start nvidia-powerd.service
    journalctl -u nvidia-powerd.service -b
    nvidia-smi
  3. Start official Sabaki 0.60.0 with Chromium GPU rendering disabled:
    ELECTRON_ENABLE_LOGGING=1 \
      ~/Applications/sabaki-v0.60.0-linux-x64.AppImage \
      --disable-gpu --enable-logging=stderr
  4. Configure KataGo 1.16.5, TensorRT 10.14.1, FP16, 10 search threads, and
    the kata1-zhizi-b40c768nbt-s11272M-d5935M.bin.gz model.
  5. Set KataGo as the opponent, play B Q16, and let KataGo respond using:
    kata-genmove_analyze W 50
  6. On the latest captured run, KataGo completed 6,409 visits and returned
    D16 after 21.7584 seconds. Two seconds later the GPU fell off the bus and
    the entire display stopped responding.
    nvidia-powerd-xid79-evidence-20260725-public-redacted.zip (65.6 KB)
    nvidia-bug-report-public-redacted.log.gz (741.6 KB)
The incidence is high and this sequence has reproduced the failure repeatedly.
Exact latest timeline
19:33:01  workload begins                 32.51 W, 66 C, 99% GPU
19:33:03                                  114.17 W, 80 C, 100% GPU
19:33:05                                  113.68 W, 85 C, 99% GPU
19:33:09                                  104.40 W, 87 C, 99% GPU
19:33:15                                   98.36 W, 89 C, 99% GPU
19:33:22  KataGo returns D16 (6409 visits)
19:33:23                                   89.86 W, 90 C, 99% GPU
19:33:24  Xid 79, GPU has fallen off the bus
19:33:25  nvidia-smi can no longer access the GPU
There is no NVIDIA thermal-shutdown Xid. Other sustained workloads have
previously reached comparable temperatures without failure. The repeatable
in-flight RPC and caller are more specific than temperature or application
load alone.
Critical kernel evidence
Every captured failure contains:
NVRM: Xid (PCI:0000:01:00): 79, GPU has fallen off the bus.
NVRM: _kgspLogRpcSanityCheckFailure: GPU0 sanity check failed 0xf
      waiting for RPC response from GSP.
      Expected function 76 (GSP_RM_CONTROL)
NVRM: -1 76 GSP_RM_CONTROL ...
      ts_end 0x0000000000000000
CPU: ... PID: ... Comm: nvidia-powerd
NVRM: _kgspRpcRecvPoll: GSP RM heartbeat timed out
NVRM: _kgspRpcRecvPoll: LibOS heartbeat timed out
NVRM: Xid (PCI:0000:01:00): 154,
      GPU recovery action changed ... to OS Reboot
The immediately preceding occurrence of the same control request completes
normally in roughly 2 ms. The next identical request remains incomplete when
the GPU disappears:
-1 GSP_RM_CONTROL ... 0x2080a613 0x13840 ... no completion
-5 GSP_RM_CONTROL ... 0x2080a613 0x13840 ... 2141 us
Five recorder logs show the same signature:
2026-07-25 14:19:27  Linux 6.8.0-136  Comm: nvidia-powerd  Xid 79
2026-07-25 15:17:06  Linux 6.8.0-136  Comm: nvidia-powerd  Xid 79
2026-07-25 16:39:13  Linux 6.8.0-136  Comm: nvidia-powerd  Xid 79
2026-07-25 17:14:04  Linux 6.8.0-136  Comm: nvidia-powerd  Xid 79
2026-07-25 19:33:24  Linux 7.0.0-28   Comm: nvidia-powerd  Xid 79
Other firmware messages
At NVIDIA driver initialization:
failed to get target temp from SBIOS
failed to get platform power mode from SBIOS
At ACPI initialization:
ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.ETMD], AE_NOT_FOUND
ACPI Error: Aborting method \_SB.IETM._OSC due to previous error
The current nvidia-powerd service itself starts without a reported error:
nvidia-powerd version:2.0 (build 1)
DBus Connection is established
Workarounds tested
  • Disabling nvidia-powerd avoids the captured failure, but limits the GPU to
    50 W instead of up to 115 W.
  • sudo nvidia-smi -pl 100 --scope=0 is not supported on this laptop GPU.
  • Updating BIOS to QNCN38WW did not fix the failure.
  • Updating Ubuntu, Linux 6.8 to 7.0, and NVIDIA 595.84 to 610.43.02 did not
    change the failing GSP control request.
  • Sabaki was run with --disable-gpu, so Electron GPU rendering is not
    required for the reproduction.
Questions for NVIDIA
  1. What RM control operation does 0x2080a613 identify?
  2. Is this a known nvidia-powerd / Dynamic Boost / GSP firmware issue on
    Blackwell laptop GPUs?
  3. Is there a supported way to keep the higher GPU TGP while disabling the
    failing dynamic power-control operation?
  4. Is there a driver or GSP firmware build containing a fix that can be tested?
  • nvidia-bug-report.log.gz
  • Five kernel-*.log recorder files
  • live-20260725-191507.log
  • 20260725-193216-60247CAA.log (KataGo GTP log)
  • sabaki-kernel7-test.log
Additional observation: the two SBIOS query failures still occur on
Linux 7.0.0-28 with the new Lenovo WMI drivers.
The boot log ordering is:
  1. NVIDIA 610.43.02 kernel module loads
  2. “failed to get target temp from SBIOS”
  3. “failed to get platform power mode from SBIOS”
  4. lenovo_wmi_capdata and lenovo_wmi_other bind immediately afterwards
Fn+Q and /sys/firmware/acpi/platform_profile work after boot, so the
new Lenovo WMI support fixed platform-profile switching, but it did not
eliminate NVIDIA’s early SBIOS query failures. Could this initialization
ordering leave nvidia-powerd with invalid or incomplete platform data?
