Hi everyone. I have two, 64-bit integers. Each integer is represented as two, 32-bit variables: unsigned int myVar1_hi, myVar1_low; myVar1 is guaranteed to be less than myVar2;
The operation I want to perform is as follows:
double myDouble = myVar1 / myVar2;
What is the best way to go about doing this? I have a feeling that if I convert myVar1 and myVar2 to 64-bit doubles for the division, too much accuracy will be lost, and my program will produce incorrect results, which is not acceptable. Should I be using unsigned long long instead of two unsigned 32-bit integers for each 64-bit integer? I really don’t want to spend time writing my own division function, especially if something already exists for this type of thing. I’m using a GTX280, which I understand has some double precision units. My code doesn’t need to be compatible with previous generation GPUs.
Yeah, now that I think about it more and more, I think the best solution is to use 96 or 128-bit fixed point for the result. It’s unfortunate, but I think it’s the only way to keep the errors from accumulating. It looks like I’ve got some work to do! Thanks.
