Faster division on 64-bit unsigned integers
I took the mul.wide.u64 code for sm_50 and above from a recent thread (https://devtalk.nvidia.com/default/topic/1017754/cuda-programming-and-performance/long-integer-multiplication-mul-wide-u64-and-mul-wide-u128/) and reworked it into a mul.hi.u64 emulation, which is a trivial modification.
I then used this code in the implementation of division of 64-bit unsigned integers, and found speedup of up to 16% when comparing against CUDA 8’s built-in division operator on a Quadro K2200 (sm_50). From looking at the SASS, I noted with interest that CUDA’s 64-bit unsigned division code uses a fastpath / slowpath design, with 64-bit division mapped to 32-bit division where possible, and using an inlined fastpath but a called slowpath (as this is very large, a sensible choice). This can give rise to divergent control flows, so for a fair comparison I duplicated that design choice in the code below.
With all operations going through the fastpath, I measured a 3% speedup. With all operations going through the slowpath I measured a 16% speedup. For a “realistic” mix of operands that can cause either path to be taken I measured 11% speedup. The divergence causes execution time to increase ~25% compared to the exclusive use of the slowpath.
I do not want to spend the time on a detailed analysis of the SASS for the division slowpath in CUDA 8; my current hypothesis is that CUDA 8 employs an insufficiently optimized emulation sequence for mul.hi.u64 on sm_50 and later architectures.
I should note that ensuring the correctness of non-trivial integer division routines is notoriously tricky. While I have tested the code below with billions of test vectors constructed according to multiple different patterns, you would want to double check before deploying this in any mission critical software.
[code updated 7/15/2017]
  Copyright (c) 2017, Norbert Juffa
  All rights reserved.
  Redistribution and use in source and binary forms, with or without
  modification, are permitted provided that the following conditions
  are met:
  1. Redistributions of source code must retain the above copyright
     notice, this list of conditions and the following disclaimer.
  2. Redistributions in binary form must reproduce the above copyright
     notice, this list of conditions and the following disclaimer in the
     documentation and/or other materials provided with the distribution.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
  HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
__device__  __forceinline__
unsigned long long int umul64lo (unsigned long long int a,
                                 unsigned long long int b)
    unsigned long long int res;
#if (__CUDA_ARCH__ >= 200) && (__CUDA_ARCH__ < 500)
    asm ("{\n\t"
         ".reg .u32       alo, ahi, blo, bhi, rlo, rhi;\n\t"
         // unpack source operands
         "mov.b64         {alo,ahi}, %1;\n\t"
         "mov.b64         {blo,bhi}, %2;\n\t"
         // generate and sum four partial products
         "mul.lo.u32      rlo, alo, blo;\n\t"
         "mul.hi.u32      rhi, alo, blo;\n\t"
         "mad.lo.u32      rhi, alo, bhi, rhi;\n\t"
         "mad.lo.u32      rhi, ahi, blo, rhi;\n\t"
         // pack output
         "mov.b64         %0, {rlo,rhi};\n\t"
         : "=l"(res)
         : "l"(a), "l"(b));
#elif __CUDA_ARCH__ >= 500
    asm ("{\n\t"
         ".reg .u32       alo, ahi, blo, bhi, r0, r1, r2, r3;\n\t"
         ".reg .u16       a0, a1, a2, a3, b0, b1, b2, b3;\n\t"
         ".reg .u32       s0, s1, t0, t1;\n\t"
         "mov.b32         {a0,a1}, alo;\n\t"
         "mov.b32         {a2,a3}, ahi;\n\t"
         "mov.b32         {b0,b1}, blo;\n\t"
         "mov.b32         {b2,b3}, bhi;\n\t"
         // first partial product r{0:1}
         "mul.wide.u16    r0, a0, b0;\n\t"
         "mul.wide.u16    r1, a0, b2;\n\t"
         "mul.wide.u16    s1, a1, b1;\n\t"
         "add.u32         r1, r1, s1;\n\t"
         "mul.wide.u16    s1, a2, b0;\n\t"
         // second partial product t{0:1}
         "mul.wide.u16    t0, a0, b1;\n\t"
         "mul.wide.u16    t1, a0, b3;\n\t"
         "mul.wide.u16    s0, a1, b0;\n\t"
         "mul.wide.u16    s1, a1, b2;\n\t"
         "add.cc.u32      t0, t0, s0;\n\t"
         "addc.u32        t1, t1, s1;\n\t"
         "mul.wide.u16    s1, a2, b1;\n\t"
         "add.u32         t1, t1, s1;\n\t"
         "mul.wide.u16    s1, a3, b0;\n\t"
         // offset second partial product
         "shf.l.clamp.b32 s1, t0, t1, 16;\n\t"
         "shf.l.clamp.b32 s0,  0, t0, 16;\n\t"
         // add partial sums
         "add.cc.u32      r0, r0, s0;\n\t"
         "addc.u32        r1, r1, s1;\n\t"
         // pack output
         "mov.b64         %0, {r0,r1};\n\t"
         : "=l"(res)
         : "l"(a), "l"(b));
#elif __CUDA_ARCH__
#error unsupported __CUDA_ARCH__
#else // avoid warning about uninitialized 'res'
    res = 0;
#endif
    return res;
unsigned long long int umul64hi (unsigned long long int a,
    asm ("{\n\t"
         ".reg .u32 r0, r1, r2, r3, alo, ahi, blo, bhi;\n\t"
         "mul.lo.u32      r0, alo, blo;\n\t"
         "mul.hi.u32      r1, alo, blo; \n\t"
         "mad.lo.cc.u32   r1, alo, bhi, r1;\n\t"
         "madc.hi.u32     r2, alo, bhi, 0;\n\t"
         "mad.lo.cc.u32   r1, ahi, blo, r1;\n\t"
         "madc.hi.cc.u32  r2, ahi, blo, r2;\n\t"
         "madc.hi.u32     r3, ahi, bhi, 0;\n\t"
         "mad.lo.cc.u32   r2, ahi, bhi, r2;\n\t"
         "addc.u32        r3, r3, 0;\n\t"
         "mov.b64         %0, {r2,r3};\n\t"
         : "=l"(res)
         : "l"(a), "l"(b));
    asm ("{\n\t"
         ".reg .u32       s0, s1, s2, s3, t0, t1, t2, t3, t4;\n\t"
         // split inputs into 16-bit chunks
         // first partial sum:
         // a3b3.wide  a1b3.wide  a0b2.wide  a0b0.wide
         //     0      a2b2.wide  a1b1.wide
         //     0      a3b1.wide  a2b0.wide
         "mul.wide.u16    r2, a1, b3;\n\t"
         "mul.wide.u16    r3, a3, b3;\n\t"
         "mul.wide.u16    t1, a1, b1;\n\t"
         "mul.wide.u16    t2, a2, b2;\n\t"
         "mul.wide.u16    t3, a2, b0;\n\t"
         "mul.wide.u16    t4, a3, b1;\n\t"
         "add.cc.u32      r1, r1, t1;\n\t"
         "addc.cc.u32     r2, r2, t2;\n\t"
         "mul.wide.u16    t1, a2, b0;\n\t"
         "mul.wide.u16    t2, a3, b1;\n\t"
         // second partial sum:
         // a2b3.wide  a0b3.wide  a0b1.wide
         // a3b2.wide  a1b2.wide  a1b0.wide
         //     0      a2b1.wide
         //     0      a3b0.wide
         "mul.wide.u16    s0, a0, b1;\n\t"
         "mul.wide.u16    s1, a0, b3;\n\t"
         "mul.wide.u16    s2, a2, b3;\n\t"
         "mul.wide.u16    t1, a2, b1;\n\t"
         "add.cc.u32      s1, s1, t1;\n\t"
         "addc.u32        s2, s2, 0;\n\t"
         "mul.wide.u16    t1, a3, b0;\n\t"
         "mul.wide.u16    t0, a1, b0;\n\t"
         "mul.wide.u16    t1, a1, b2;\n\t"
         "mul.wide.u16    t2, a3, b2;\n\t"
         "add.cc.u32      s0, s0, t0;\n\t"
         "addc.cc.u32     s1, s1, t1;\n\t"
         "addc.cc.u32     s2, s2, t2;\n\t"
         "addc.u32        s3, 0, 0;\n\t"
         // offset second partial sum by 16 bits to the left
         "shf.l.clamp.b32 t3, s2, s3, 16;\n\t"
         "shf.l.clamp.b32 t2, s1, s2, 16;\n\t"
         "shf.l.clamp.b32 t1, s0, s1, 16;\n\t"
         "shf.l.clamp.b32 t0,  0, s0, 16;\n\t"
         // add first sum in r{0,1,2,3} to second sum in t{0,1,2,3}
         "add.cc.u32      r0, r0, t0;\n\t"
         "addc.cc.u32     r1, r1, t1;\n\t"
         "addc.u32        r3, r3, t3;\n\t"
         // pack outputs
         : "=l"(res)
         : "l"(a), "l"(b));
#elif __CUDA_ARCH__
    res = 0;
#endif
    return res;
__device__ __noinline__
unsigned long long int udiv64_core (unsigned long long int dividend,
                                    unsigned long long int divisor)
    unsigned long long int temp, quot, rem, recip, neg_divisor = 0ULL - divisor;
    float r, s, t;
    /* compute initial approximation for reciprocal; must be underestimate! */
    t = __ull2float_ru (divisor);
    asm ("rcp.approx.f32.ftz %0,%1;" : "=f"(r) : "f"(t));
    s = __int_as_float (__float_as_int (r) - 2 + 0x20000000);
    recip = (unsigned long long int)s; /* underestimate of 2**64 / divisor */
    /* perform Halley iteration with cubic convergence to refine reciprocal */
    temp = umul64lo (neg_divisor, recip);
    temp = umul64hi (temp, temp) + temp;
    recip = umul64hi (recip, temp) + recip;
    /* compute preliminary quotient and remainder */
    quot = umul64hi (dividend, recip);
    rem = dividend - umul64lo (divisor, quot);
    /* adjust quotient if too small; quotient off by 2 at most */
    if (rem >= divisor) quot += ((rem - divisor) >= divisor) ? 2 : 1;
    /* handle division by zero */
    if (divisor == 0ULL) quot = ~0ULL;
    return quot;
unsigned long long int udiv64 (unsigned long long int dividend,
    unsigned int combined_hi;
    asm ("{\n\t"
         ".reg .u32       dividend_lo, dividend_hi, divisor_lo, divisor_hi;\n\t"
         "mov.b64         {dividend_lo, dividend_hi}, %1;\n\t"
         "mov.b64         {divisor_lo, divisor_hi}, %2;\n\t"
         "or.b32          %0, dividend_hi, divisor_hi;\n\t"
         : "=r"(combined_hi)
         : "l"(dividend), "l"(divisor));
    if (combined_hi == 0) {
        return (unsigned long long int)((unsigned int)(dividend) /
                                        (unsigned int)(divisor));
    } else {
        return udiv64_core (dividend, divisor);
Thanks for posting!
Interested to see how this performs in my array permutation code, which uses decomposition and has a huge amount of 64 bit integer division. Will test on the Pascal GTX 1080ti CUDA 8.0 and share my results.
if you need to perform multiple divisions with the same divider, factor out the reciprocal calculation. and look at Montgomeri division formula
Sped up the array permutation generation/evaluation code for the 13! case by about 4% while returning the correct result. Would expect at least that degree of improvement for the 14! and 15! case, as they have more 64-bit integer division.
Took 714 ms to generate all 6,227,020,800 array permutations and test each permutation against a linear (to N) test function. This was using a GTX 1080ti CUDA 8.0 with --use_fast_math, single GPU version.
Been meaning to update that code anyway, so this gives me an excuse. Thanks!
I noticed that by deploying my own emulation of mul.lo.u64 instead of using CUDA’s built-in multiplication operator I could save another six instructions and eke out an additional 1% in terms of performance, so I have updated the code in my original post accordingly.
