64bit raspi CSI/USBcam live stream Jetson-inference compatible
Hi @DaneLLL,
Thank you for your response. I am attempting test-launch and was able to get it to fire up successfully on my pi after following this fix. Now when I attempt to recieve the stream on my jetson I am met with the lack of nvoverlaysink. I tried using nvdrmvideosink and nv3dsink and am met with decoding errors.
gst-launch-1.0 uridecodebin uri=rtsp://<myserverIP>:8554/test ! nvdrmvideosink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://<myserverIP>:8554/test
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source: Unhandled error
Additional debug info:
gstrtspsrc.c(6585): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source:
Service Unavailable (503)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
gst-launch-1.0 uridecodebin uri=rtsp://<myserverIP>:8554/test ! nv3dsink
I moved on to attempt the test pipe through the docker container and have coppied the result below.
root@ubuntu:/jetson-inference# imagenet rtp://<myserverIP>:8554 --input-codec=h264
[gstreamer] initialized gstreamer, version 1.16.3.0
[gstreamer] gstDecoder -- creating decoder for <myserverIP>
[gstreamer] gstDecoder -- resource discovery not supported for RTP streams
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] udpsrc port=8554 multicast-group=<myserverIP> auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! nvv4l2decoder ! video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw ! appsink name=mysink
[video]  created gstDecoder from rtp://<myserverIP>:8554
gstDecoder video options:
  -- URI: rtp://<myserverIP>:8554
     - protocol:  rtp
     - port:      8554
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      0
  -- height:     0
  -- frameRate:  0.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- rtspLatency 2000
[OpenGL] glDisplay -- X screen 0 resolution:  1920x1080
[OpenGL] glDisplay -- X window resolution:    1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
[video]  created glDisplay from display://0
glDisplay video options:
  -- URI: display://0
     - protocol:  display
  -- deviceType: display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- rtspLatency 2000
imageNet -- loading classification network model from:
         -- prototxt     networks/googlenet.prototxt
         -- model        networks/bvlc_googlenet.caffemodel
         -- class_labels networks/ilsvrc12_synset_words.txt
         -- input_blob   'data'
         -- output_blob  'prob'
         -- batch_size   1
[TRT]    TensorRT version 8.4.1
[TRT]    loading NVIDIA plugins...
[TRT]    Registered plugin creator - ::GridAnchor_TRT version 1
[TRT]    Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT]    Registered plugin creator - ::NMS_TRT version 1
[TRT]    Registered plugin creator - ::Reorg_TRT version 1
[TRT]    Registered plugin creator - ::Region_TRT version 1
[TRT]    Registered plugin creator - ::Clip_TRT version 1
[TRT]    Registered plugin creator - ::LReLU_TRT version 1
[TRT]    Registered plugin creator - ::PriorBox_TRT version 1
[TRT]    Registered plugin creator - ::Normalize_TRT version 1
[TRT]    Registered plugin creator - ::ScatterND version 1
[TRT]    Registered plugin creator - ::RPROI_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT]    Registered plugin creator - ::BatchTilePlugin_TRT version 1
[TRT]    Could not register plugin creator -  ::FlattenConcat_TRT version 1
[TRT]    Registered plugin creator - ::CropAndResize version 1
[TRT]    Registered plugin creator - ::CropAndResizeDynamic version 1
[TRT]    Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[TRT]    Registered plugin creator - ::ProposalDynamic version 1
[TRT]    Registered plugin creator - ::Proposal version 1
[TRT]    Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT]    Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT]    Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT]    Registered plugin creator - ::Split version 1
[TRT]    Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT]    Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT]    Registered plugin creator - ::InstanceNormalization_TRT version 2
[TRT]    Registered plugin creator - ::CoordConvAC version 1
[TRT]    Registered plugin creator - ::DecodeBbox3DPlugin version 1
[TRT]    Registered plugin creator - ::GenerateDetection_TRT version 1
[TRT]    Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[TRT]    Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[TRT]    Registered plugin creator - ::NMSDynamic_TRT version 1
[TRT]    Registered plugin creator - ::PillarScatterPlugin version 1
[TRT]    Registered plugin creator - ::VoxelGeneratorPlugin version 1
[TRT]    Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[TRT]    detected model format - caffe  (extension '.caffemodel')
[TRT]    desired precision specified for GPU: FASTEST
[TRT]    requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT]    [MemUsageChange] Init CUDA: CPU +181, GPU +0, now: CPU 220, GPU 5075 (MiB)
[TRT]    [MemUsageChange] Init builder kernel library: CPU +131, GPU +250, now: CPU 370, GPU 5232 (MiB)
[TRT]    native precisions detected for GPU:  FP32, FP16, INT8
[TRT]    selecting fastest native precision for GPU:  FP16
[TRT]    found engine cache file /usr/local/bin/networks/bvlc_googlenet.caffemodel.1.1.8401.GPU.FP16.engine
[TRT]    found model checksum /usr/local/bin/networks/bvlc_googlenet.caffemodel.sha256sum
[TRT]    echo "$(cat /usr/local/bin/networks/bvlc_googlenet.caffemodel.sha256sum) /usr/local/bin/networks/bvlc_googlenet.caffemodel" | sha256sum --check --status
[TRT]    model matched checksum /usr/local/bin/networks/bvlc_googlenet.caffemodel.sha256sum
[TRT]    loading network plan from engine cache... /usr/local/bin/networks/bvlc_googlenet.caffemodel.1.1.8401.GPU.FP16.engine
[TRT]    device GPU, loaded /usr/local/bin/networks/bvlc_googlenet.caffemodel
[TRT]    [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 255, GPU 5141 (MiB)
[TRT]    Loaded engine size: 14 MiB
[TRT]    Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[TRT]    Using cuDNN as a tactic source
[TRT]    [MemUsageChange] Init cuDNN: CPU +345, GPU +363, now: CPU 603, GPU 5504 (MiB)
[TRT]    Deserialization required 4300778 microseconds.
[TRT]    [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +13, now: CPU 0, GPU 13 (MiB)
[TRT]    [MemUsageChange] Init cuDNN: CPU +1, GPU +2, now: CPU 604, GPU 5505 (MiB)
[TRT]    Total per-runner device persistent memory is 94720
[TRT]    Total per-runner host persistent memory is 112976
[TRT]    Allocated activation device memory of size 3612672
[TRT]    [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +4, now: CPU 0, GPU 17 (MiB)
[TRT]
[TRT]    CUDA engine context initialized on device GPU:
[TRT]       -- layers       72
[TRT]       -- maxBatchSize 1
[TRT]       -- deviceMemory 3612672
[TRT]       -- bindings     2
[TRT]       binding 0
                -- index   0
                -- name    'data'
                -- type    FP32
                -- in/out  INPUT
                -- # dims  3
                -- dim #0  3
                -- dim #1  224
                -- dim #2  224
[TRT]       binding 1
                -- index   1
                -- name    'prob'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  1000
                -- dim #1  1
                -- dim #2  1
[TRT]
[TRT]    binding to input 0 data  binding index:  0
[TRT]    binding to input 0 data  dims (b=1 c=3 h=224 w=224) size=602112
[TRT]    binding to output 0 prob  binding index:  1
[TRT]    binding to output 0 prob  dims (b=1 c=1000 h=1 w=1) size=4000
[TRT]
[TRT]    device GPU, /usr/local/bin/networks/bvlc_googlenet.caffemodel initialized.
[TRT]    loaded 1000 class labels
[TRT]    imageNet -- networks/bvlc_googlenet.caffemodel initialized.
[gstreamer] opening gstDecoder for streaming, transitioning pipeline to GST_STATE_PLAYING
Opening in BLOCKING MODE
[gstreamer] gstDecoder -- failed to set pipeline state to PLAYING (error 0)
imagenet:  shutting down...
imagenet:  shutdown complete.
Any further advice would be greatly appreciated.
I tried opening the stream in VLC and cannot either, even though I am met with
stream ready at rtsp://127.0.0.1:8554/test
on the pi.
