A bug related to shared variables and label in nvcc v11.7
OS: Ubuntu 18.04
GPU: GeForce RTX 3080Ti
Cuda toolkit version: V11.7.64
Detail: When a label is before a shared variable definition(example code as bellow). The atomic operations on shared variables do not seem to work.
#include <cuda.h>
#include <cuda_runtime.h>
#include <stdio.h>
__global__ void entry(double* res) {
LABLE_START:           //The label.
    __shared__ int sv; //difinition of shared variable.
    sv = 0;
    atomicAdd(&sv, 40);
    res[0] = sv; //The program assigns a value of 0 to v. But the correct value of res[0] should be 40.
int main() {
    int SIZE = 1;
    // malloc host memory
    double* h = (double*)malloc(SIZE * sizeof(double));
    for (int i = 0; i < SIZE; i++) h[i] = 0.0;
    // malloc device memory
    double *d;
    cudaMalloc(&d, SIZE * sizeof(double));
    // Copy data from host memory to device memory
    cudaMemcpy(d, h, SIZE * sizeof(double), cudaMemcpyHostToDevice);
    // launch kernel function
    entry<<<1, 1>>>(d);
    cudaDeviceSynchronize();
    // Copy result from device memory to host memory
    cudaMemcpy(h, d, SIZE * sizeof(double), cudaMemcpyDeviceToHost);
    // Free device memory
    cudaFree(d);
    // print result data to file
    FILE *f = fopen("Result.txt", "w+");
    if (f != NULL) for (int i = 0; i < SIZE; i++) fprintf(f, "%lf\n", h[i]);
    // Free host memory
    free(h);
    return 0;
I want to make sure if this is a bug in the nvcc(v11.7) compiler.Preformatted text
I don’t think its a bug. When I compile your code I get various warnings which should not be ignored.
You can resolve the issue by placing the label after the shared declaration.
Yes,I get these warnings.
But it is strange that attribute “shared” does not apply here. This warning will disappear when I just add another statement between label and shared variable definition.
LABLE_START:
int t = 0;
__shared__ sv;
sure, file a bug if you wish.
