A kernel panic occurs sometimes when closing camera
Hi, nvidia teams:
When we do not connet camera module to orin and use the following command:
*gst-launch-1.0 *
*nvv4l2camerasrc device=/dev/video0 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=(int)960, height=(int)540, format=(string)NV12’ ! nv3dsink window-x=0 window-y=0 *
*nvv4l2camerasrc device=/dev/video2 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=(int)960, height=(int)540, format=(string)NV12’ ! nv3dsink window-x=960 window-y=0 *
*nvv4l2camerasrc device=/dev/video4 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=(int)960, height=(int)540, format=(string)NV12’ ! nv3dsink window-x=0 window-y=540 *
*nvv4l2camerasrc device=/dev/video6 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=(int)960, height=(int)540, format=(string)NV12’ ! nv3dsink window-x=960 window-y=540 \ "
to open 4 cameras, after execute this command, there we be 4 windows in the screen,
but when I use mouse to close these windows, there will be a kernel panic sometimes, the log is in the attachment.
so have you seen this bug before? how to solve it?
camera_panic.txt (453.7 KB)
is there /dev/video* nodes? may I know what’s the real use-case to enable the stream without camera device connected physically?
