I’m using Cuda 1.1 and
I’m trying the tutorial code on simple matrix multiplication,
to test its performance on my 8600M.
So, when I try to compare the results, it seems that with the simple algorithm I get matrixC = matrixAmatrixB, but with the cublasSgemm I get matrixC = matrixBmatrixA! How it’s possible? (if I change A with B in the simple algorithm, I get the same result as cublas).
The code is the same as in the official programming guide.
The cublasSgemm call is:
cublasSgemm( ‘n’,‘n’, m, n, k, 1.0f , dA, lda, dB, ldb, 0.0f, dC, ldc );
Cublas is using Fortran memory layout (column-major), your C code is probably using C memory layout ( row-major), so in one case you are computing the product with matrices that are the transpose of the other case.
So, if I use the cublas library, I should pass matrix to cublassgemm columns by columns, instead of rows by rows?
so, to pass
|x00 x10 x20|
|x01 x11 x21|
|x02 x12 x22|
I should pass an array made by:
[x00, x01, x02, x10, x11, x12, x20, x21, x22]
instead of:
[x00, x10, x20, x01, x11, x21, x02, x12, x22]
I thought that Fortran memory layout was only a way to write the contract form of an array of array… ex. in C array[5][2] is an array of 2 columns * 5 rows were
near values are in the same row,
and in Fortran array[5][2] is an array of 5 columns * 2 rows were near values are in the same row too… sorry!!
