kelson
November 11, 2010, 11:34am
1
I would like to know why the cublasSgemm return wrong result.
I would like to multiply a matrix A of size (2,2)
and an over matrix B of size (2,6) initialized like this
A
0.375 0
0 0.625
B
0.0968 0.1613 0.1935 0.0968 0.3226 0.129
0.0625 0.1875 0.1875 0.2083 0.2083 0.1458
The result C is
0.0363 0.1008 0.0726 0.0605 0.121 0.0806
0.0234 0.1172 0.0703 0.1302 0.0781 0.0911
But I know the result should be
0.0363 0.0605 0.0726 0.0363 0.1210 0.0484
0.0391 0.1172 0.1172 0.1302 0.1302 0.0911
the code is like this:
cublasSgemm(‘n’,‘n’,2, 6, 2,1.0f,A,2,B,2,0.0f,C,2);
I would appreciate any help.
Thank you
kelson
2
A
0.375 0
0 0.625
B
The result C is
Thank you
LSChien
November 11, 2010, 1:50pm
3
A
0.375 0
0 0.625
B
The result C is
CUBLAS is column-major, not row-major, I think that you use row-major to store B and use row-major to interpret C.
in row-major, you B is
0.0968 0.1935 0.3226 …
0.1613 0.0968 0.129 …
and C = A*B is
0.0363 0.0726 0.1210 …
0.1008 0.0605 0.0806
which is column-major format.
but you use row-major to interpret column-major result, hence
C = 0.0363 0.1008 0.0726 0.0605 0.1210 0.0806
LSChien
4
A
0.375 0
0 0.625
B
The result C is
and C = A*B is
kelson
November 11, 2010, 2:30pm
5
and C = A*B is
Thank you LSChien for your quick reply.
I realize that that B is store in row-major.
I would appreciate if you can tell me how to change
this situation to get it column-major.
Thank you
kelson
6
and C = A*B is
Thank you
YDD
November 11, 2010, 3:28pm
7
Thank you
The simplest thing is probably to tell [font=“Courier New”]cublasSgemm[/font] to transpose its inputs.
YDD
8
Thank you
LSChien
November 12, 2010, 1:09am
9
Thank you
you need to use clumn-major in your host code,
B(i,j) = B[2*j + i] ;
if you use B[i][j], then C-compiler uses row-major to do translation, say B[i*6+j]
LSChien
10
Thank you
kelson
November 12, 2010, 1:45am
11
I think my matrices were colum-major stored.
I did like this
for (int i = 0; i < row; i++) {
for (int j = 0; j < col; j++) {
dMatrix[i * col + j] = (float)value;
kelson
12
I did like this
avidday
November 12, 2010, 5:33am
13
That is row-major ordering not column major ordering.
avidday
14
kelson
November 12, 2010, 12:11pm
15
It was a misunderstanding of mine.
May I change like this for col-major?
[i]for (int i = 0; i < row; i++) {
dMatrix[j * row + i] = (float)value;
}[/i]
kelson
16
}[/i]
