Hi all… When I run a example under <SDK_INSTALL_PATH>/bin/linux/release
got an error:
./matrixMul: error while loading shared libraries: libcudart.so.2: cannot open shared object file: No such file or directory
Help… Thank you…
and I have sudo ldconfig,… My OS is Ubuntu 8.10 amd64…
who can help me~~~~
[quote name=‘kaven_sdu’ post=‘520972’ date=‘Mar 21 2009, 07:28 AM’]
got an error:
[codebox]include /etc/ld.so.conf.d/*.conf
/opt/cuda/lib
[/codebox]
and then run ldconfig
or modify your LD_LIBRARY_PATH variable to include the cuda/lib directory. eg
[codebox]export LD_LIBRARY_PATH="/opt/cuda/lib/:$LD_LIBRARY_PATH"[/codebox]
hope it helps.
tocyx
#3
hello,
i have the same problem on my fedora 10.
the problem is due to selinux.
So to solve the problem , try the following command [chcon -t textrel_shlib_t ‘/usr/local/cuda/lib/libcudart.so.2.1’ ]
for me it solve the problem.
best regards
tocyx
