HI ALL
I 'm writing a CUDA algorithm that have to process data, fetching them from an array (‘D’) of float in device memory.
For a lot of reasons this data are fetched in a random order (‘index’) from memory so I bind a texture (‘tex_D_float’)
on that array to improve performace. This is the source code:
texture<float,1> tex_D_float;
cudaBindTexture(NULL, tex_D_float, cu_vector_D , VectorDim*sizeof(float));
__global__ kernel1 <<<....>>> (.....)
float tempFloatD;
unsigned int index;
[calculate "index" value]
tempFloatD=tex1Dfetch(tex_D_float,index);
[process data]
[output data]
[number of threads=VectorDim]
With this code, a single thread are fetching only one float at a time (tempFloatD).
In a second stage, I noticed that I could improve processing algorithm by fetching
and processing two consecutive (in memory) float data (float2 type) at a time .
If I use no texture to fetch float2 data per thread, this improvement is very evident
respect fetching and processing a single float datum per thread without texture.
The strange behaviour is that the performance does not follow
this improvement…only when I use texture.
I noticed that, with a texture system to fetch data, using a single thread to fetch float2 data is worse
than using a single thread to fetch a single float datum.
This is the source code I used for fetching and processing float2 data:
texture<float2,1> tex_D_float2;
cudaBindTexture(NULL, tex_D_float2, cu_vector_D , VectorDim*sizeof(float));
[inside the kernel]
__global__ kernel2 <<<....>>> (.....)
float2 tempFloat2_D;
unsigned int index;
tempFloat2_D=tex1Dfetch(tex_D_float2,index);
[process data]
[output data]
[number of threads=VectorDim/2]
I tried this algorithm on devices with compute capability 1.1 and 1.3
noticed the same performace degradation using texture to fetch float2 data.
did a make a mistake in the code?? or cuda device have really this performace degradation
using texture to fetch float2 data per thread?
please …help me
thank you in advance
Rocco
