I have been trying to debug a piece of CUDA code, and found it extremely hard. Sometimes, the bug won’t reproduce in -deviceemu, nor -G. And sometimes, when it does come up in -deviceemu, I am not able to set a breakpoint in the right function, because it has been inlined. So I composed this simple logging “library”. I would like to share it with you guys, hope it would be helpful for someone.
* DLog.h
* Simple logging mechanism for CUDA device code
* Usage:
* 1. include it in your .cu file
* 2. call DLog_Init(size) to reserve size bytes as output buffer
* on device
* 3. call DLog<<data in your CUDA device code
* 4. call DLog_Dump() after kernel invocation to dump the output
* This implementation is very simple, and inefficient. It supports only
* char, int and const char *.
* Author: Chuntao HONG (chuntao.hong@gmail.com)
* Last modified: Oct. 13th, 2009
#ifndef DLOG_H
#define DLOG_H
#include <cuda.h>
#include <iostream>
using namespace std;
const int MIN_ALIGN=4;
// align n to b bytes
template<class T>
__device__ T Align(T n, uint32_t b){
return ((uint32_t)n&(b-1))==NULL ? n : n+b-((uint32_t)n&(b-1));
template<class T>
__device__ T MinAlign(T n){
return ((uint32_t)n&(MIN_ALIGN-1))==NULL ? n : n+MIN_ALIGN-((uint32_t)n&(MIN_ALIGN-1));
// set some empty bytes, so that the logging data structures won't be polluted by out-of-bound writes
const int SAFTY_BYTES=1024*1024;
// data types supported, now only three
enum DataType{
CHAR,
INT,
STRING
struct LogPack{
int size;
DataType type;
union{
char c;
int i;
char str[];
}data;
__device__ int requiredLogSpace(const char*);
__device__ int requiredLogSpace(const int);
__device__ int requiredLogSpace(const unsigned int);
__device__ int requiredLogSpace(const char);
__device__ void assignLog(LogPack *, const char c);
__device__ void assignLog(LogPack *, const char * c);
__device__ void assignLog(LogPack *, const int c);
__device__ void assignLog(LogPack *, const unsigned int c);
struct MyLog{
public:
char empty_bytes[SAFTY_BYTES];
char * buf;
unsigned int curPos;
char empty_bytes2[SAFTY_BYTES];
public:
template <class T>
__device__ MyLog & operator<<(const T & t){
int packSize=MinAlign(requiredLogSpace(t));
int start=atomicAdd(&curPos, packSize);
LogPack * pack=(LogPack *)(buf+start);
assignLog(pack,t);
pack->size=packSize;
return *this;
__device__ MyLog DLog;
__device__ int requiredLogSpace(const int i){
return sizeof(i)+sizeof(DataType)+sizeof(int);
__device__ int requiredLogSpace(const char * str){
int len=0;
while(*str++){
len++;
return len+1+sizeof(DataType)+sizeof(int);
__device__ static int requiredLogSpace(const unsigned int i){
__device__ static int requiredLogSpace(const char c){
return sizeof(c)+sizeof(DataType)+sizeof(int);
__device__ void assignLog(LogPack * pack, const char c){
pack->data.c=c;
pack->type=CHAR;
__device__ void assignLog(LogPack * pack, const int i){
pack->data.i=i;
pack->type=INT;
__device__ void assignLog(LogPack * pack, const unsigned int i){
pack->data.i=i;
pack->type=INT;
__device__ void assignLog(LogPack * pack, const char * str){
int i=0;
while(*str){
pack->data.str[i++]=*str;
str++;
pack->type=STRING;
__host__ void DLog_Init(unsigned int size){
MyLog localLog;
localLog.curPos=SAFTY_BYTES;
cudaMalloc((void**)&localLog.buf, size+SAFTY_BYTES);
cudaMemset(localLog.buf, 0, size);
cudaMemcpyToSymbol(DLog, &localLog, sizeof(MyLog), 0, cudaMemcpyHostToDevice);
__host__ void DLog_Dump(){
MyLog localLog;
cudaMemcpyFromSymbol(&localLog, DLog, sizeof(MyLog), 0, cudaMemcpyDeviceToHost);
char * h_buf=new char[localLog.curPos+1];
cudaMemcpy(h_buf, localLog.buf, localLog.curPos, cudaMemcpyDeviceToHost);
cudaFree(localLog.buf);
char * ptr=h_buf+SAFTY_BYTES;
while(ptr<h_buf+localLog.curPos){
LogPack * pack=(LogPack *)ptr;
if(pack->type==CHAR){
cout<<pack->data.c<<endl;
else if(pack->type==INT){
cout<<"0x"<<hex<<pack->data.i<<endl;
else{
cout<<pack->data.str<<endl;
ptr+=pack->size;
delete[] h_buf;
#endif
