Hello, @WayneWWW
1, Can you tell me the path before include?
2. Does the document even introduce how to apply uboot after building it?
Thank you.
Hello, @WayneWWW
Thank you.
Please download the uboot source from the website.
Uboot source also provided in the L4T webstie.
Same tarball file as where you downloaded the kernel source.
Hello, @WayneWWW
Can I modify it as follows to boot from usb?
if right
How to apply uboot rebuild to jetson?
#ifndef CONFIG_SPL_BUILD
#ifndef BOOT_TARGET_DEVICES
#define BOOT_TARGET_DEVICES(func) \
func(MMC, mmc, 1) \
func(MMC, mmc, 0) \
func(USB, usb, 0) \
func(PXE, pxe, na) \
func(DHCP, dhcp, na)
#endif
change boot sequence
func(USB, usb, 0) \
func(MMC, mmc, 1) \
func(MMC, mmc, 0) \
#endif
Thank you.
You can search uboot.bin under your BSP/bootloader and replace the old uboot file.
Hello, @WayneWWW
Could not find uboot.bin under bootloader directory.
can you guide me about
or_Tegra/bootloader$ ls
bmp.blob mksparse
boot.img mnt
boot.img.sb nv_boot_control.conf
BUP_generator.py nvidia-l4t-bootloader_32.7.1-20220219090432_arm64.deb
cboot.bin NVIDIA_Trademark_License_Addendum_SW.pdf
chkbdinfo nvtboot.bin
crc-flash.xml.bin nvtboot_cpu.bin
crc-flash.xml.tmp nvtboot_cpu_rb.bin
cvm.bin nvtboot_recovery.bin
eks.img nvtboot_recovery_cpu.bin
emmc_bootblob_ver.txt P3448_A00_lpddr4_204Mhz_P987.cfg
extlinux.conf pycache
flashcmd.txt rp4.blob
flash_parameters.txt sc7entry-firmware.bin
flash_win.bat signed
flash.xml system.img
flash.xml.sb system.img.raw
initrd t210ref
kernel_tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb
kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.sb tegrabct
l4t_bup_gen.func tegradevflash
l4t_initrd.img tegraflash_internal.py
LICENSE tegraflash.py
LICENSE.chkbdinfo tegrahost
LICENSE.mkbctpart tegraopenssl
LICENSE.mkbootimg tegraparser
LICENSE.mkgpt tegrarcm
LICENSE.mksparse tegrasign
LICENSE.tegraopenssl tegrasign_v3_internal.py
LICENSE.tos-mon-only.img.arm-trusted-firmware tegrasign_v3.py
LICENSE.u-boot tegrasign_v3_util.py
mkbctpart tos.img
mkbootimg tos-mon-only.img
mkgpt warmboot.bin
Thank you.
Hello, @WayneWWW
Can I refer to the article below document?
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/uboot_guide.html#wwpID0E0GJ0HA
Thank you.
You can follow that. But you still need to put the new uboot binary to the path.
Search file name with âu-bootâ in your BSP.
Hello, @WayneWWW
As mentioned above, there is no uboot.bin under the Linux_for_tegra/bootloader folder.
Can I just copy the newly built uboot.bin under the bootloader?
Thank you.
Honestly, I donât want to be a babysitter here to keep teaching you some basics.
Canât you just use find command for any file contains âu-bootâ in your bootloader folder?
Linux_for_Tegra/bootloader/t210ref/p3450-0000$ ls
u-boot.bin
Thank you.
Yes, good. Smart guy.
Iâm sorry for the basic question.
But still, when I check boot_targets with printenv, mmc1 comes out first.
Is the source edit not reflected well?
[ 2.9182 ] tegradevflash --write BCT P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.9194 ] Cboot version 00.01.0000
[ 2.9214 ] Writing partition BCT with P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.9220 ] [âŚ] 100%
[ 3.3209 ]
[ 3.3211 ] Coldbooting the device
[ 3.3237 ] tegradevflash --reboot coldboot
[ 3.3251 ] Cboot version 00.01.0000
[ 3.3276 ]
*** The [LNX] has been updated successfully. **
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Tegra210 (P3450-0000) # printenv boot_targets
boot_targets=mmc1 mmc0 usb0 nvme0 pxe dhcp
Thank you.
Hello, @WayneWWW
I simply changed the boot order in the uboot/include/config/tegra-common-post.h file as follows and replaced the old uboot binary after building uboot.
After that, even after flashing with the following command, it does not boot from USB. Am I missing something?
sudo ./flash.sh -k LNX mmcblk0p1
func(USB, usb, 0) \
func(MMC, mmc, 1) \
func(MMC, mmc, 0) \
#endif
Thank you.
Any log to share?
