About ISP tuning
Can the built-in camera of jeton tx2 be used for ISP tuning? What should I do.
Hello @2162822944,
Unfortunately the ISP tuning process is not something that everyone can do.
There are only a few select NVIDIA Partners that can help you with that.
Please let me know if you have any other questions, I would love to help.
regards,
Andrew
Hi @proventusnova
Thanks for the answer. Do you mean I need to buy a camera for ISP tuning?
@2162822944,
What I mean is that you wont be able to acess the ISP tuning tools unless you are a camera sensor manufacturer.
There is some tuning you could do to your camera colors by playing with the argus camera accesible parameters. However, to properly tune your ISP with a custom ISP tuning file, you might need to contact your camera manufacturer or a partner with access to the required tools.
regards,
Andrew
The ISP tuning process is not specific to a camera type. Each image sensor needs a different ISP setting. The ISP is tuned to the sensor + lens being used.
The process is not something you can do without access to the ISP tuning tools. You could try requesting a custom ISP file for the camera you are using from the manufacturer.
If one is not available then your next option is to contact the NVIDIA partners with access to those tools.
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
