Hello!
I want to allocate NvBufSurface, width = 1504, height = 1500, pitch = 1504*4, Why NvBufSurfaceAllocate get pitch = 6144?
Hello!
NvBufSurfaceAllocateParams create_params;
memset(&create_params, 0, sizeof(create_params));
create_params.params.gpuId = 0;
create_params.params.width = 1504;
create_params.params.height = 1500;
create_params.params.memType = NVBUF_MEM_SURFACE_ARRAY;
create_params.params.layout = NVBUF_LAYOUT_PITCH;
create_params.params.colorFormat = NVBUF_COLOR_FORMAT_BGRA;
create_params.memtag = NvBufSurfaceTag_VIDEO_CONVERT;
NvBufSurface *src0;
int ret = NvBufSurfaceAllocate(&src0, 1, &create_params);
printf("src0->surfaceList[0].pitch:%d",src0->surfaceList[0].pitch);
How can I set pitch = 1504*4?
The pitch alignment is due to hardware design, so it is fixed and cannot be arbitrarily changed. Please note this.
Ok, thank you for your answer
I want to know NVBUF_LAYOUT_BLOCK_LINEAR data arrangement rule,can tell me?
create_params.params.width = 300;
create_params.params.height = 200;
NvBufSurface *src0, *src1;
create_params.params.layout = NVBUF_LAYOUT_BLOCK_LINEAR;
ret = NvBufSurfaceAllocate(&src1, 1, &create_params);
NvBufSurfaceMap(src0, 0, -1, NVBUF_MAP_READ_WRITE);
NvBufSurfaceMap(src1, 0, -1, NVBUF_MAP_READ_WRITE);
NvBufSurf::NvCommonTransformParams transform_params;
transform_params.src_top = 0;
transform_params.src_left = 0;
transform_params.src_width = 300;
transform_params.src_height = 200;
transform_params.dst_top = 0;
transform_params.dst_left = 0;
transform_params.dst_width = 300;
transform_params.dst_height = 200;
transform_params.flag = NVBUFSURF_TRANSFORM_FILTER;
transform_params.flip = NvBufSurfTransform_None;
transform_params.filter = NvBufSurfTransformInter_Nearest;
uchar * ptrStartAddr = (uchar * )src0->surfaceList[0].mappedAddr.addr[0];
for(int i = 0; i < src0->surfaceList[0].dataSize; i++)
*ptrStartAddr = 0xee;
ptrStartAddr++;
src0->numFilled = 1;
src1->numFilled = 1;
NvBufSurf::NvTransform(&transform_params, src0->surfaceList[0].bufferDesc, src1->surfaceList[0].bufferDesc);
std::ofstream outfile("/home/root/test.txt");
outfile.is_open();
u_char* ptr = (u_char*)src1->surfaceList[0].mappedAddr.addr[0];
for(int i = 0; i < src1->surfaceList[0].dataSize; i++)
outfile.put(*ptr);
ptr++;
outfile.close();
I filled all the data in NVBUF_LAYOUT_PITCH mode with 0xee,but use NvTransform to NVBUF_LAYOUT_BLOCK_LINEAR, data output like this
0000000 eeee eeee eeee eeee eeee eeee eeee eeee
0024140 0000 0000 0000 0000 0000 0000 0000 0000
0024180 eeee eeee eeee eeee eeee eeee eeee eeee
00241c0 0000 0000 0000 0000 0000 0000 0000 0000
0024200 eeee eeee eeee eeee eeee eeee eeee eeee
0024340 0000 0000 0000 0000 0000 0000 0000 0000
0024380 eeee eeee eeee eeee eeee eeee eeee eeee
00243c0 0000 0000 0000 0000 0000 0000 0000 0000
0024400 eeee eeee eeee eeee eeee eeee eeee eeee
0024540 0000 0000 0000 0000 0000 0000 0000 0000
0024580 eeee eeee eeee eeee eeee eeee eeee eeee
00245c0 0000 0000 0000 0000 0000 0000 0000 0000
0024600 eeee eeee eeee eeee eeee eeee eeee eeee
0024740 0000 0000 0000 0000 0000 0000 0000 0000
0024780 eeee eeee eeee eeee eeee eeee eeee eeee
00247c0 0000 0000 0000 0000 0000 0000 0000 0000
0024800 eeee eeee eeee eeee eeee eeee eeee eeee
0024940 0000 0000 0000 0000 0000 0000 0000 0000
0024980 eeee eeee eeee eeee eeee eeee eeee eeee
00249c0 0000 0000 0000 0000 0000 0000 0000 0000
0024a00 eeee eeee eeee eeee eeee eeee eeee eeee
0024b40 0000 0000 0000 0000 0000 0000 0000 0000
0024b80 eeee eeee eeee eeee eeee eeee eeee eeee
0024bc0 0000 0000 0000 0000 0000 0000 0000 0000
0024c00 eeee eeee eeee eeee eeee eeee eeee eeee
0024d40 0000 0000 0000 0000 0000 0000 0000 0000
0024d80 eeee eeee eeee eeee eeee eeee eeee eeee
0024dc0 0000 0000 0000 0000 0000 0000 0000 0000
0024e00 eeee eeee eeee eeee eeee eeee eeee eeee
0024f40 0000 0000 0000 0000 0000 0000 0000 0000
0024f80 eeee eeee eeee eeee eeee eeee eeee eeee
0024fc0 0000 0000 0000 0000 0000 0000 0000 0000
0025000 eeee eeee eeee eeee eeee eeee eeee eeee
0025140 0000 0000 0000 0000 0000 0000 0000 0000
0025180 eeee eeee eeee eeee eeee eeee eeee eeee
00251c0 0000 0000 0000 0000 0000 0000 0000 0000
0025200 eeee eeee eeee eeee eeee eeee eeee eeee
0025340 0000 0000 0000 0000 0000 0000 0000 0000
0025380 eeee eeee eeee eeee eeee eeee eeee eeee
00253c0 0000 0000 0000 0000 0000 0000 0000 0000
0025400 eeee eeee eeee eeee eeee eeee eeee eeee
0025540 0000 0000 0000 0000 0000 0000 0000 0000
0025580 eeee eeee eeee eeee eeee eeee eeee eeee
00255c0 0000 0000 0000 0000 0000 0000 0000 0000
0025600 eeee eeee eeee eeee eeee eeee eeee eeee
0025740 0000 0000 0000 0000 0000 0000 0000 0000
0025780 eeee eeee eeee eeee eeee eeee eeee eeee
00257c0 0000 0000 0000 0000 0000 0000 0000 0000
0025800 eeee eeee eeee eeee eeee eeee eeee eeee
0025940 0000 0000 0000 0000 0000 0000 0000 0000
0025980 eeee eeee eeee eeee eeee eeee eeee eeee
00259c0 0000 0000 0000 0000 0000 0000 0000 0000
0025a00 eeee eeee eeee eeee eeee eeee eeee eeee
0025b40 0000 0000 0000 0000 0000 0000 0000 0000
0025b80 eeee eeee eeee eeee eeee eeee eeee eeee
0025bc0 0000 0000 0000 0000 0000 0000 0000 0000
0025c00 eeee eeee eeee eeee eeee eeee eeee eeee
0025d40 0000 0000 0000 0000 0000 0000 0000 0000
0025d80 eeee eeee eeee eeee eeee eeee eeee eeee
0025dc0 0000 0000 0000 0000 0000 0000 0000 0000
0025e00 eeee eeee eeee eeee eeee eeee eeee eeee
0025f40 0000 0000 0000 0000 0000 0000 0000 0000
0025f80 eeee eeee eeee eeee eeee eeee eeee eeee
0025fc0 0000 0000 0000 0000 0000 0000 0000 0000
0026000 eeee eeee eeee eeee eeee eeee eeee eeee
0027200 0000 0000 0000 0000 0000 0000 0000 0000
0028000 eeee eeee eeee eeee eeee eeee eeee eeee
0029200 0000 0000 0000 0000 0000 0000 0000 0000
002a000 eeee eeee eeee eeee eeee eeee eeee eeee
002b200 0000 0000 0000 0000 0000 0000 0000 0000
002c000 eeee eeee eeee eeee eeee eeee eeee eeee
002d200 0000 0000 0000 0000 0000 0000 0000 0000
002e000 eeee eeee eeee eeee eeee eeee eeee eeee
002f200 0000 0000 0000 0000 0000 0000 0000 0000
0030000 eeee eeee eeee eeee eeee eeee eeee eeee
0031200 0000 0000 0000 0000 0000 0000 0000 0000
0032000 eeee eeee eeee eeee eeee eeee eeee eeee
0033200 0000 0000 0000 0000 0000 0000 0000 0000
0034000 eeee eeee eeee eeee eeee eeee eeee eeee
0035200 0000 0000 0000 0000 0000 0000 0000 0000
0036000 eeee eeee eeee eeee eeee eeee eeee eeee
0037200 0000 0000 0000 0000 0000 0000 0000 0000
0038000 eeee eeee eeee eeee eeee eeee eeee eeee
0039200 0000 0000 0000 0000 0000 0000 0000 0000
003a000 eeee eeee eeee eeee eeee eeee eeee eeee
003b200 0000 0000 0000 0000 0000 0000 0000 0000
003c000 eeee eeee eeee eeee eeee eeee eeee eeee
003d200 0000 0000 0000 0000 0000 0000 0000 0000
003e000 eeee eeee eeee eeee eeee eeee eeee eeee
003f200 0000 0000 0000 0000 0000 0000 0000 0000
0040000 eeee eeee eeee eeee eeee eeee eeee eeee
0041200 0000 0000 0000 0000 0000 0000 0000 0000
0042000 eeee eeee eeee eeee eeee eeee eeee eeee
0043200 0000 0000 0000 0000 0000 0000 0000 0000
0044000 eeee eeee eeee eeee eeee eeee eeee eeee
0045200 0000 0000 0000 0000 0000 0000 0000 0000
0046000 eeee eeee eeee eeee eeee eeee eeee eeee
0047200 0000 0000 0000 0000 0000 0000 0000 0000
0048000 eeee eeee eeee eeee eeee eeee eeee eeee
0049200 0000 0000 0000 0000 0000 0000 0000 0000
004a000 eeee eeee eeee eeee eeee eeee eeee eeee
004a140 0000 0000 0000 0000 0000 0000 0000 0000
004a180 eeee eeee eeee eeee eeee eeee eeee eeee
004a1c0 0000 0000 0000 0000 0000 0000 0000 0000
004a200 eeee eeee eeee eeee eeee eeee eeee eeee
004a340 0000 0000 0000 0000 0000 0000 0000 0000
004a380 eeee eeee eeee eeee eeee eeee eeee eeee
004a3c0 0000 0000 0000 0000 0000 0000 0000 0000
004a400 eeee eeee eeee eeee eeee eeee eeee eeee
004a540 0000 0000 0000 0000 0000 0000 0000 0000
004a580 eeee eeee eeee eeee eeee eeee eeee eeee
004a5c0 0000 0000 0000 0000 0000 0000 0000 0000
004a600 eeee eeee eeee eeee eeee eeee eeee eeee
004a740 0000 0000 0000 0000 0000 0000 0000 0000
004a780 eeee eeee eeee eeee eeee eeee eeee eeee
004a7c0 0000 0000 0000 0000 0000 0000 0000 0000
004a800 eeee eeee eeee eeee eeee eeee eeee eeee
004a940 0000 0000 0000 0000 0000 0000 0000 0000
004a980 eeee eeee eeee eeee eeee eeee eeee eeee
004a9c0 0000 0000 0000 0000 0000 0000 0000 0000
004aa00 eeee eeee eeee eeee eeee eeee eeee eeee
004ab40 0000 0000 0000 0000 0000 0000 0000 0000
004ab80 eeee eeee eeee eeee eeee eeee eeee eeee
004abc0 0000 0000 0000 0000 0000 0000 0000 0000
004ac00 eeee eeee eeee eeee eeee eeee eeee eeee
004ad40 0000 0000 0000 0000 0000 0000 0000 0000
004ad80 eeee eeee eeee eeee eeee eeee eeee eeee
004adc0 0000 0000 0000 0000 0000 0000 0000 0000
004ae00 eeee eeee eeee eeee eeee eeee eeee eeee
004af40 0000 0000 0000 0000 0000 0000 0000 0000
004af80 eeee eeee eeee eeee eeee eeee eeee eeee
004afc0 0000 0000 0000 0000 0000 0000 0000 0000
004b000 eeee eeee eeee eeee eeee eeee eeee eeee
004b140 0000 0000 0000 0000 0000 0000 0000 0000
004b180 eeee eeee eeee eeee eeee eeee eeee eeee
004b1c0 0000 0000 0000 0000 0000 0000 0000 0000
0060000
I took the 0xee data, 0xee data = 240000, Same result as 300* 200 *4,but I don’t know how to sort it
I thought NVBUF_LAYOUT_BLOCK_LINEAR should be all of 0xee, And there is no have 0x00
The blocklinear format is private. Please use pitch linear.
Private way, I also want to know the arrangement, because I see that the previous data are all linearly arranged, matching the type of data I want
We are not able to provide information about block linear. Please use pitch linear.
Okay, thanks for your answer.
