about __syncthreads() in SDK/project/transpose
Dear there,
I am a newbie here!
When I try to understand the matrix transpose project which is packed under cuda SDK/project/transpose/
I noticed that the kernel “transpose_naive” looks did not do anything to do the read/write synchronization to make sure the correct value is read and write.
Can anybody point out how cuda make sure the output of “transpose_naive” is correct?
Thank you very much!
// This naive transpose kernel suffers from completely non-coalesced writes.
// It can be up to 10x slower than the kernel above for large matrices.
__global__ void transpose_naive(float *odata, float* idata, int width, int height)
   unsigned int xIndex = blockDim.x * blockIdx.x + threadIdx.x;
   unsigned int yIndex = blockDim.y * blockIdx.y + threadIdx.y;
if (xIndex < width && yIndex < height)
	   unsigned int index_in  = xIndex + width * yIndex;
	   unsigned int index_out = yIndex + height * xIndex;
	   odata[index_out] = idata[index_in];
KZ
[quote name=‘kewumgh’ post=‘586411’ date=‘Sep 9 2009, 05:40 AM’]
Dear there,
I am a newbie here!
[codebox]__global__ void transpose(float *odata, float *idata, int width, int height)
__shared__ float block[BLOCK_DIM][BLOCK_DIM+1];
// read the matrix tile into shared memory
unsigned int xIndex = blockIdx.x * BLOCK_DIM + threadIdx.x;
unsigned int yIndex = blockIdx.y * BLOCK_DIM + threadIdx.y;
if((xIndex < width) && (yIndex < height))
	unsigned int index_in = yIndex * width + xIndex;
	block[threadIdx.y][threadIdx.x] = idata[index_in];
__syncthreads();
// write the transposed matrix tile to global memory
xIndex = blockIdx.y * BLOCK_DIM + threadIdx.x;
yIndex = blockIdx.x * BLOCK_DIM + threadIdx.y;
if((xIndex < height) && (yIndex < width))
	unsigned int index_out = yIndex * height + xIndex;
	odata[index_out] = block[threadIdx.x][threadIdx.y];
[/codebox]
Question: why does optimized kernel need to do synch. ?
the procedure of optimized kernel is
(1) copy idata(i,j) to shared memory block(i,j) for (i,j) belongs some thread block
(2) do synchronization to make sure all threads inside the block have done the transfer
(3) copy data block(i,j) to odata(j,i) for (i,j) belongs some thread block
if synchronization is removed, then consider thread = (1,0) say thread.x = 1, thread.y = 0
this thread moves idata(0,1) to block(0,1), however then the same thread
must move block(1,0) to odata(0,1), that is the problem
since thread (1,0) does not transfer data to block(1,0)
but thread(0,1) does.
bothe thread(1,0) and thread(0,1) belong to the same thread block, so synch. is necessary here
Thank you for detailed explanation!
I see now.
I thought we use shared memory to boost the performance is mainly because we can write a whole block of result back to device memory instead of write them one by one, therefore we can save some time by accessing much less of times device memory ( instead of accessing device memory at number of threads times, we only need ( number of threads / (blockdim * blockdim) ) times accessing.
So if we change the transpose code to make it do some simple copy operation, I am expecting that block copy will still be faster than thread by thread copy. But my testing tells me that thread by thread copy is faster than block copy. Can anybody point out why?
Here is the code:
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cutil_inline.h>
const unsigned int BLOCK_DIM = 16;
// kernel copy
// device memory copy entry by entry
__global__ void copy(float *outData, float* inData, unsigned int width, unsigned int height)
	unsigned int yIndex = blockDim.y * blockIdx.x + threadIdx.y;
	if( xIndex < width && yIndex < height )
		unsigned int index = yIndex * width + xIndex;
		outData[index] = inData[index];
// kernel copy
// shared memory temporary save, block copy back to device memory
__global__ void blockCopy(float* outData, float* inData, unsigned int width, unsigned int height)
	__shared__ float block[BLOCK_DIM][BLOCK_DIM];
	unsigned int xIndex = blockIdx.x* BLOCK_DIM + threadIdx.x;
	unsigned int yIndex = blockIdx.y* BLOCK_DIM + threadIdx.y;
	if(xIndex < width && yIndex < height)
		block[threadIdx.x][threadIdx.y] = inData[index];
	__syncthreads();
	outData[index] = block[threadIdx.x][threadIdx.y];
// declaration, forward
void runTest( int argc, char** argv);
// Program main
int
main( int argc, char** argv)
	runTest( argc, argv);
	cutilExit(argc, argv);
//! Run a simple test for CUDA
void
	// size of the matrix
	const unsigned int width = 1024;
	const unsigned int height = 1024;
	// size of memory required to store the matrix
	const unsigned int memSize = sizeof(float) * width * height;
	unsigned int timer;
	cutCreateTimer(&timer);
	// use command-line specified CUDA device, otherwise use device with highest Gflops/s
	if( cutCheckCmdLineFlag(argc, (const char**)argv, "device") )
		cutilDeviceInit(argc, argv);
	else
		cudaSetDevice( cutGetMaxGflopsDeviceId() );
	// allocate memory on host
	float *h_idata = (float*) malloc(memSize);
	// initalize the memory
	for( unsigned int i = 0; i < (width*height); ++i)
		h_idata[i] = (float) i;
	// allocate memory on device
	float* d_idata;	 // input memory
	float* d_odata;	 // output memory
	cutilSafeCall( cudaMalloc( (void**) &d_idata, memSize ));
	cutilSafeCall( cudaMalloc( (void**) &d_odata, memSize ));
	// copy host memory to device
	cutilSafeCall( cudaMemcpy( d_idata, h_idata, memSize, cudaMemcpyHostToDevice ));
	// set up grid, block dimensions
	dim3 grid(width/ BLOCK_DIM, height/BLOCK_DIM, 1);
	dim3 block(BLOCK_DIM, BLOCK_DIM, 1);
	// warmup so we don't time CUDA startup
	copy<<< grid, block>>>( d_odata, d_idata, width, height);
	blockCopy<<< grid, block >>>( d_odata, d_idata, width, height);
	cudaThreadSynchronize();
	printf("Copying a %d by %d matrix of floats...\n", width, height);
	int numIterations = 4;
	// execute the kernel: copy
	cutStartTimer(timer);
	for( unsigned int i = 0; i < numIterations; i++ )
	cutStopTimer(timer);
	float copyTime = cutGetTimerValue(timer);
	// execute the kernel: blockCopy
	cutResetTimer(timer);
	float blockCopyTime = cutGetTimerValue(timer);
	printf("copy average time:	 %0.3f ms\n", copyTime / numIterations);
	printf("block copy average time: %0.3f ms\n\n", blockCopyTime / numIterations);
	// check if kernel execution generated and error
	cutilCheckMsg("Kernel execution failed");
	// cleanup memory
	free(h_idata);
	cutilSafeCall(cudaFree(d_idata));
	cutilSafeCall(cudaFree(d_odata));
	cutilCheckError( cutDeleteTimer(timer));
	cudaThreadExit();
first I need to correct your kernel “blockCopy”, you should issue boundary condition again after synch.
[codebox]global void blockCopy(float* outData, float* inData, unsigned int width, unsigned int height)
if(xIndex < width && yIndex < height){
__syncthreads();
}[/codebox]
Question: if we change the transpose code to make it do some simple copy operation, I am expecting that
Ans: no, this is not true, remember that GPU cannot copy data from global memory to shared memory directly,
it will copy data to register, then move data from register to shared memory.
So for matrix copy problem, from your code, warps access continuous memory block, the read/write to
global memory can be coalesce to large chunk transfer (for example 16 (threads) x 4 (byte/float) = 64 bytes ).
This is best case that you can have. You don’t need shared memory, if you used, then you obtain extra overhead
from read, say global memory → register → shared memory. However this overhead is indeed overhead because you
don’t change transfer chunk size to global memory when using shared memory.
On the other hand, for transpose problem, read operation is O.K since warps access continuous memory block.
However write operation is not good due to transpose operation, I take naive code to interpret this
[codebox]global void transpose_naive(float odata, float idata, int width, int height)
}[/codebox]
now suppose (blockIdx.x, blockIdx.y) = (0,0) for simplicity,
a half-warp occupies 16 threads with id (threadIdx.x, threadIdx.y) =(0,0), (1,0), (2,0), (3,0), … (15,0)
then according to “index_in = xIndex + width * yIndex;”, these 16 threads access contiguous locations,
say index_in = 0, 1, 2, 3, …, 15
this means that read operation “idata[index_in]” can be optimized (group 16 reads into a big read).
in fact, idata[index_in] = idata[yIndex][xIndex] = idata[threadIdx.y][threadIdx.x]
However “index_out = yIndex + height * xIndex” is not good, these 16 threads access stride locations,
say if height = 16, then index_out = 0, 16, 32, 48, 64, …
and write operation “odata[index_out]” cannot be optimized now.
That is why NVIDIA propose an optimized kernel with shared memory in SDK
—Thank you!
it will copy data to register, then move data from register to shared memory.Nice, That was my blind spot!
I am still a bit confused about which part boost the performance? Based on my understanding about the code, both transpose and transpose_naive are doing the same operation when they are reading from the global memory but writing to different places. And they are reading continues memory block( best case we can have), so no potential for improvement.
The two procedures differs when they are trying to write result back to global memory, __syncthreads() is necessary only for optimized transfer to make sure that the correct result is written back to global memory.
Is it the writing of transpose beat the transpose_naive because it is writing block by block instead of thread by thread?
Then, my question is, which function call/flag tells it to write block by block? How could a programmer know it will write block by block or thread by thread?
many many thanks
question : Is it the writing of transpose beat the transpose_naive because it is writing block by block instead of thread by thread?
the key is "does a warp access continuous pattern?". for naive method, write of a warp access discontinuous pattern
but for optimized method, rite of a warp access continuous pattern.
when warp accesses continuous pattern, then hardware would group these oattern into a big transaction, then
number of read/write would decrease, that is why optimized method is faster than naive metheod.
please check section 5.1.2.1 in programming guide 2.3
