Dear all, thank you for your input.
I have run some more tests and I think that I have a answer or rather a guess since I cannot find literature to confirm this. It was all about adding one line with __syncthreads() command.
Here is my copy/pasted answer I have put on stackoverflow with the same question as above:
There is a lot of information about how important are coalesced memory operations on warp level when all threads in warp should access same aligned segments of memory.
But it seems that synchronizing warps in a block makes coalescing possible on inter-warp level probably utilizing better memory bus width on different GPUs ← this is just my “explanation” to this problem since I could not find any literature on that.
I would be very happy if anybody can confirm above and/or point me to some good info about how memory is read by multiple warps/SMs. We should remember that memory bus is much wider than L2 32-bytes aligned segments (it might be as big as 4096bits in case of monsters like v100).
Also to reach maximum possible memory transfers we need to saturate all of SMs equally with maximum number of active blocks/threads possible.
Here is my final benchmark (interested persons should focus on memCopy2dB and memCopy2dBnotSynchronized kernels).
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <iostream>
#include <chrono>
#include <memory>
#include <vector>
template<typename T>
__global__ void memCopy1dKernel(T *in, T *out, size_t len) {
size_t idx = blockIdx.x * blockDim.x + threadIdx.x;
if (idx < len) {
out[idx] = in[idx];
__global__ void memCopy2dA(const T *in, T *out, size_t xLen, size_t yLen) {
size_t xi = blockIdx.x * blockDim.x + threadIdx.x;
size_t yi = blockIdx.y * blockDim.y + threadIdx.y;
if (xi < xLen && yi < yLen) {
out[yi * xLen + xi] = in[yi * xLen + xi];
__global__ void memCopy2dB(const T *in, T *out, size_t xLen, size_t yLen) {
if (xi < xLen) {
for (size_t idx = xi; idx < yLen * xLen; idx += xLen) {
__syncthreads(); // don't need sychronization but it gives super speedup!
out[idx] = in[idx];
__global__ void memCopy2dBnotSynchronized(const T *in, T *out, size_t xLen, size_t yLen) {
if (xi < xLen) {
out[idx] = in[idx];
static void waitForCuda() {
cudaDeviceSynchronize();
cudaError_t err = cudaGetLastError();
if (err != cudaSuccess) printf("Error: %s\n", cudaGetErrorString(err));
class ScopedBandwidth {
const std::string name;
const std::chrono::high_resolution_clock::time_point startTime;
const size_t dataSize;
const int numOfRepetitions;
static constexpr double gigabyte = 1000 * 1000 * 1000;
public:
ScopedBandwidth(const std::string &name, size_t dataSize, size_t numOfRepetitions) : name(name), startTime(std::chrono::high_resolution_clock::now()), dataSize(dataSize), numOfRepetitions(numOfRepetitions) {}
~ScopedBandwidth() {
auto stopTime = std::chrono::high_resolution_clock::now();
std::chrono::duration<double> elapsed = stopTime - startTime;
std::cout << name << " GB/s: " << (2 * dataSize * numOfRepetitions) / elapsed.count() / gigabyte << std::endl;
template <typename T>
void warmUp(int numOfRepetitions, int numOfThreads, size_t xLen, size_t yLen, T *dInput, T *dOutput) {
const size_t numOfElements = xLen * yLen;
dim3 threadsPerBlock(numOfThreads);
dim3 numBlocks((numOfElements + threadsPerBlock.x - 1) / threadsPerBlock.x);
for (int i = 0; i < numOfRepetitions; ++i) {
memCopy1dKernel << < numBlocks, threadsPerBlock >> > (dInput, dOutput, numOfElements);
waitForCuda();
void test1D(int numOfRepetitions, int numOfThreads, size_t xLen, size_t yLen, T *dInput, T *dOutput) {
const size_t dataSize = numOfElements * sizeof(T);
ScopedBandwidth sb("test1D", dataSize, numOfRepetitions);
waitForCuda();
void test2DA(int numOfRepetitions, int numOfThreads, size_t xLen, size_t yLen, T *dInput, T *dOutput) {
dim3 threadsPerBlock(numOfThreads, 1);
dim3 numBlocks((xLen + threadsPerBlock.x - 1) / threadsPerBlock.x,
(yLen + threadsPerBlock.y - 1) / threadsPerBlock.y);
ScopedBandwidth sb("test2DA", dataSize, numOfRepetitions);
memCopy2dA <<< numBlocks, threadsPerBlock >>> (dInput, dOutput, xLen, yLen);
waitForCuda();
void test2DB(int numOfRepetitions, int numOfThreads, size_t xLen, size_t yLen, T *dInput, T *dOutput) {
dim3 numBlocks((xLen + threadsPerBlock.x - 1) / threadsPerBlock.x);
ScopedBandwidth sb("test2DB", dataSize, numOfRepetitions);
memCopy2dB <<< numBlocks, threadsPerBlock >>> (dInput, dOutput, xLen, yLen);
waitForCuda();
void test2DBnotSynchronized(int numOfRepetitions, int numOfThreads, size_t xLen, size_t yLen, T *dInput, T *dOutput) {
ScopedBandwidth sb("test2DBnotSynchronized", dataSize, numOfRepetitions);
memCopy2dBnotSynchronized <<< numBlocks, threadsPerBlock >>> (dInput, dOutput, xLen, yLen);
waitForCuda();
void setMemory(T *dInput, T *dOutput, size_t dataSize) {
cudaMemset(dInput, 0, dataSize);
cudaMemset(dOutput, 11, dataSize);
void checkMemory(T *dOutput, size_t numOfElements) {
std::unique_ptr<T[]> hMemory(new T[numOfElements]);
cudaMemcpy(hMemory.get(), dOutput, numOfElements * sizeof(T), cudaMemcpyDeviceToHost);
size_t cnt = 0;
for (size_t i = 0; i < numOfElements; ++i) {
if (hMemory[i] != 0) { // check if memory was zeroed
cnt++;
if (cnt > 0) {
std::cout << "Memory not copied properly! Found " << numOfElements << "/" << cnt << " errors." << std::endl;
exit(1);
int main() {
cudaDeviceProp deviceProp;
cudaGetDeviceProperties(&deviceProp, 0);
const int smCount = deviceProp.multiProcessorCount;
std::cout << "Number of SMs = " << smCount << std::endl;
std::cout << "Size of global mem = " << static_cast<float>(deviceProp.totalGlobalMem / 1048576.0f) << "MB" << std::endl;
using T=float;
const size_t yLen = 1024;
// calculate coefficient to get for both buffers about half of memory in GPU
const size_t halfMemCoef = deviceProp.totalGlobalMem / (yLen * 32 * 64 * smCount * sizeof(T)) / 2 / 2;
// max efficiency at #SM * 32 (max num of active blocks) * 64 (maximum num of active threads 2048/32 active blocks)
const size_t xLen = smCount * 32 * 64 * halfMemCoef;
std::cout << "Used DataSize = " << dataSize / 1024 / 1024 << "MB\n";
T *dInput;
cudaMalloc(&dInput, dataSize);
T *dOutput;
cudaMalloc(&dOutput, dataSize);
const int numOfRepetitions = 50;
warmUp(numOfRepetitions, 64, xLen, yLen, dInput, dOutput);
std::vector<int> numThreadsPool = {32, 64, 128, 256};
for (int numOfThreads : numThreadsPool) {
std::cout << "-------- numOfThreads in block = " << numOfThreads << std::endl;
setMemory(dInput, dOutput, dataSize);
test1D(numOfRepetitions, numOfThreads, xLen, yLen, dInput, dOutput);
checkMemory(dOutput, numOfElements);
test2DA(numOfRepetitions, numOfThreads, xLen, yLen, dInput, dOutput);
test2DB(numOfRepetitions, numOfThreads, xLen, yLen, dInput, dOutput);
test2DBnotSynchronized(numOfRepetitions, numOfThreads, xLen, yLen, dInput, dOutput);
cudaFree(dInput);
cudaFree(dOutput);
return 0;
With about benchmark this are my results from 1080Ti:
Number of SMs = 28
Size of global mem = 11177.2MB
Used DataSize = 2688MB
-------- numOfThreads in block = 32
test1D GB/s: 206.252
test2DA GB/s: 197.154
test2DB GB/s: 282.854
test2DBnotSynchronized GB/s: 292.736
-------- numOfThreads in block = 64
test1D GB/s: 358.422
test2DA GB/s: 369.371
test2DB GB/s: 349.66
test2DBnotSynchronized GB/s: 299.613
-------- numOfThreads in block = 128
test1D GB/s: 369.34
test2DA GB/s: 369.274
test2DB GB/s: 358.829
test2DBnotSynchronized GB/s: 310.661
-------- numOfThreads in block = 256
test1D GB/s: 369.489
test2DA GB/s: 369.395
test2DB GB/s: 359.54
test2DBnotSynchronized GB/s: 321.461
As we can see synchronized kernel memCopy2dB is really faster than not synchronized version, even if we lose some time on synchronization.
