Fewer threads per block = ... faster performance?
I was playing around with the number of threads per block, and I noticed that it seems like a lower number resulted in greater overall performance. E.g. 128 threads per block resulted in faster performance than 1024. I somehow assumed that maximizing the threads per block would have resulted in faster performance, but that’s not the case.
Could someone perhaps point me to the theoretical reason why lower threads per block results in greater performance than just going with the maximum number of threads per block?
(This is executed on a T4 on google colab. Changing the MAX_NUM_THREADS_PER_BLOCK variable from 1024 to 128 results in slightly better performance (although the performance is even more pronounced on another application I’m testing))
%%writefile TestProg.cu
#include <iostream>
#include "cuda_fp16.h"
using namespace std;
#define MAX_NUM_THREADS_PER_BLOCK 128
#define gpuErrorCheck(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
   if (code != cudaSuccess)
      fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
      if (abort) exit(code);
struct foo
  int num;
  half2 *y = NULL;
  half2 *m = NULL;
  half2 *x = NULL;
  half2 *b = NULL;
  foo (int num) : num(num)
    cudaMallocManaged(&y, sizeof(half2) * num);
    cudaMallocManaged(&m, sizeof(half2) * num);
    cudaMallocManaged(&x, sizeof(half2) * num);
    cudaMallocManaged(&b, sizeof(half2) * num);
    for (int i = 0; i < num; i++)
      y[i] = __float2half2_rn(2.0f);
      m[i] = __float2half2_rn(2.0f);
      x[i] = __float2half2_rn(2.0f);
      b[i]  = __float2half2_rn(2.0f);
    int deviceId;
    cudaGetDevice(&deviceId);
    cudaMemPrefetchAsync(y, sizeof(half2) * num, deviceId);
    cudaMemPrefetchAsync(m, sizeof(half2) * num, deviceId);
    cudaMemPrefetchAsync(x, sizeof(half2) * num, deviceId);
    cudaMemPrefetchAsync(b, sizeof(half2) * num, deviceId);
  __device__ inline void bar()
    int index = blockIdx.x * blockDim.x + threadIdx.x;
    int stride = blockDim.x * gridDim.x;
    for (int i = index; i < num; i += stride)
      y[i] = m[i]*x[i] + b[i];
__global__ void run(foo foos, int num)
  foos.bar();
int main ()
  int num = 1024 * 1024;
  foo *foos = NULL;
  cudaMallocManaged(&foos, sizeof(foo));
  new (foos) foo(num);
  int deviceId;
  cudaMemPrefetchAsync(foos, sizeof(foo), deviceId);
  gpuErrorCheck(cudaPeekAtLastError());
  gpuErrorCheck(cudaDeviceSynchronize());
  int numberOfBlocks = (num + MAX_NUM_THREADS_PER_BLOCK - 1) / MAX_NUM_THREADS_PER_BLOCK;
  run<<<numberOfBlocks, MAX_NUM_THREADS_PER_BLOCK>>>(*foos, num);
  return 0;
Performance with 128 threads:
==3726== NVPROF is profiling process 3726, command: ./TestProg
==3726== Profiling application: ./TestProg
==3726== Profiling result:
            Type  Time(%)      Time     Calls       Avg       Min       Max  Name
 GPU activities:  100.00%  129.50us         2  64.751us  63.295us  66.207us  run(foo, int)
      API calls:   91.79%  136.00ms         5  27.199ms  18.820us  135.86ms  cudaMallocManaged
                    7.24%  10.725ms         3  3.5751ms  63.126us  10.593ms  cudaDeviceSynchronize
                    0.64%  946.13us         5  189.23us  5.1120us  757.87us  cudaMemPrefetchAsync
                    0.21%  314.01us         2  157.01us  8.9780us  305.04us  cudaLaunchKernel
                    0.10%  144.83us       114  1.2700us     156ns  57.261us  cuDeviceGetAttribute
                    0.01%  12.813us         1  12.813us  12.813us  12.813us  cuDeviceGetName
                    0.01%  10.377us         2  5.1880us  1.8500us  8.5270us  cudaGetDevice
                    0.00%  5.0200us         1  5.0200us  5.0200us  5.0200us  cuDeviceGetPCIBusId
                    0.00%  4.6180us         1  4.6180us  4.6180us  4.6180us  cuDeviceTotalMem
                    0.00%  1.6790us         3     559ns     231ns  1.1630us  cuDeviceGetCount
                    0.00%  1.4430us         3     481ns     286ns     609ns  cudaPeekAtLastError
                    0.00%  1.0270us         2     513ns     215ns     812ns  cuDeviceGet
                    0.00%     487ns         1     487ns     487ns     487ns  cuModuleGetLoadingMode
                    0.00%     343ns         1     343ns     343ns     343ns  cuDeviceGetUuid
==3726== Unified Memory profiling result:
Device "Tesla T4 (0)"
   Count  Avg Size  Min Size  Max Size  Total Size  Total Time  Name
       9  1.7782MB  4.0000KB  2.0000MB  16.00391MB  1.398856ms  Host To Device
       1  4.0000KB  4.0000KB  4.0000KB  4.000000KB  1.888000us  Device To Host
Total CPU Page faults: 50
performance with 1024 threads:
==5309== NVPROF is profiling process 5309, command: ./TestProg
==5309== Profiling application: ./TestProg
==5309== Profiling result:
 GPU activities:  100.00%  146.62us         2  73.310us  72.447us  74.174us  run(foo, int)
      API calls:   97.35%  109.32ms         5  21.864ms  13.430us  109.23ms  cudaMallocManaged
                    1.33%  1.4988ms         3  499.60us  73.074us  1.3485ms  cudaDeviceSynchronize
                    0.91%  1.0164ms         5  203.27us  7.8520us  644.41us  cudaMemPrefetchAsync
                    0.26%  287.86us         2  143.93us  10.699us  277.17us  cudaLaunchKernel
                    0.12%  139.71us       114  1.2250us     144ns  55.623us  cuDeviceGetAttribute
                    0.01%  11.217us         1  11.217us  11.217us  11.217us  cuDeviceGetName
                    0.01%  8.3230us         2  4.1610us  1.7540us  6.5690us  cudaGetDevice
                    0.00%  5.5570us         1  5.5570us  5.5570us  5.5570us  cuDeviceGetPCIBusId
                    0.00%  4.8530us         1  4.8530us  4.8530us  4.8530us  cuDeviceTotalMem
                    0.00%  1.7480us         3     582ns     360ns     719ns  cudaPeekAtLastError
                    0.00%  1.7100us         3     570ns     197ns  1.1880us  cuDeviceGetCount
                    0.00%     873ns         2     436ns     189ns     684ns  cuDeviceGet
                    0.00%     580ns         1     580ns     580ns     580ns  cuModuleGetLoadingMode
                    0.00%     195ns         1     195ns     195ns     195ns  cuDeviceGetUuid
==5309== Unified Memory profiling result:
       9  1.7782MB  4.0000KB  2.0000MB  16.00391MB  1.392620ms  Host To Device
Thanks again for the help!! I’m still learning all this haha, there’s a lot to learn :D
Generally speaking, a finer granularity of resource usage leads to a higher overall utilization of resources. If I provide $150 of spending money, this resource is used better when it can be spent in chunks of $50 than in chunks of $100.
For this reason a rule of thumb in CUDA development is to initially target a block size of between 128 and 256 threads inclusive (divisible by 32), and to deviate from this only if there is a strong, experimentally validated, reason to pick a larger or smaller block size.
To add some hand-waving to what njuffa already said.
  • The T4 has a maximum of 1024 threads per SM.
  • When threadblocks are 1024 threads per block, a new block cannot be deposited on a SM until all 1024 threads from the previous block retire.
  • When threadblocks are 128 threads, a new block can be deposited before all previous threads have retired. (We effectively only require a group of 4 warps to have retired. And it is possible to show experimentally, I believe, that those 4 warps need not even belong to the same block.)
  • Therefore, if we assume something other than pure-lockstep execution across the threadblock, it stands to reason that the average time duration until a new thread can be deposited on any given SM must be lower in the 128 threads per block case than the 1024 threads per block case. The 1024 threads per block case is effectively the upper bound or worst case.
If the average time duration until new threads can begin is shorter, I think it stands to reason that the work will get done, on average, quicker.
I’m not suggesting I’m certain or have proven this is the actual explanation, but it is in my view plausible, especially since we are only trying to account for ~9us of difference.
You’ve written a grid-stride loop kernel design, but have not taken a common next step: size the grid to match the dimensions of the GPU. I think if you did that, these scheduling inefficiencies should mostly disappear, and I would expect the performance gap to reduce. Perhaps you will prove me wrong.
I don’t suppose you could dive into details on this statement: size the grid to match the dimensions of the GPU.
or are you saying that by specifying 128 threads, it more closely sizes the grid to the dimensions of the GPU?
Thanks!!
Possibly what Robert’s alluding to, is outlined in point 1, towards the end of this blog post:
Yes, the most basic step is mentioned there: choose a number of threadblocks that is a whole-number multiple of the number of SMs. And an example is given.
We can do even more - choose a grid size which exactly matches the theoretical occupancy of the kernel in question. These topics are covered in many places and in many forum posts.
A basic viewpoint would be to choose a grid such that the number of threadblocks is just enough to “fill” the GPU. For example, my cc8.9 L4 GPU happens to have 58 SMs. Each cc8.9 SM can hold a maximum of 1536 threads. So I often choose launch sizes of 512 threads per block, with 58x3 blocks. This gives exactly enough threads to “fill” the GPU; no more, no less.
The additional wrinkle that you can do is to check theoretical occupancy of your kernel. The profilers can help with this. Just because the GPU has the capability to hold 1536 threads per SM does not mean that every kernel design behaves that way. There may be other limiters to occupancy, such as register usage or shared memory usage, to name two of the most common ones. Other limiters to occupancy may reduce the actual thread carrying capacity of the SM, compared to the theoretical number (1536 for my cc8.9 GPU). If your max theoretical occupancy for your kernel design is less than that predicted by the hardware, then this would alter (i.e. reduce) the grid size you need to launch, to “maximally fill” the GPU.
Most excellent! Thanks for the feedback Robert and RS.
I tried this technique on my dummy application above, and unfortunately, I got slightly worse performance regardless of the number of blocks per SM I selected trying to fully fill a T4 GPU (I only tried standard sizes of like 32, 64, 128, 512, 1024, etc).
However, when I ran this on my ‘real’ application, I did get slightly better performance, but the numbers didn’t line up with ‘filling’ the GPU. (I had 102410246 threads, and I used 1024 blocks per SM, and 128 threads per block). (but perhaps it has to do with the funky number of threads).
For the ‘dummy’ application, here is the code I was trying. I was adjusting the MAX_NUM_THREADS_PER_BLOCK. The NUM_BLOCKS_PER_SM formula tries to calculate the optimal number of blocks to multiply by the number of SMs in order to ‘fill’ the GPU.
So maybe this is more of an ‘art’ than a ‘science’ and filling the GPU gets you close and you just have to tweak from there?
#include <iostream>
#define NUM_OF_BLOCKS_T4 40
#define MAX_THREADS_PER_SM_T4 1024
#define NUM_BLOCKS_PER_SM (NUM_OF_BLOCKS_T4 * MAX_THREADS_PER_SM_T4) / MAX_NUM_THREADS_PER_BLOCK
struct foo
  int num;
  half2 *y = NULL;
  half2 *m = NULL;
  half2 *x = NULL;
  half2 *b = NULL;
    int deviceId;
  foos.bar();
int main ()
  foo *foos = NULL;
  int deviceId;
  //int numberOfBlocks = (num + MAX_NUM_THREADS_PER_BLOCK - 1) / MAX_NUM_THREADS_PER_BLOCK;
  int numSMs;
  cudaDeviceGetAttribute(&numSMs, cudaDevAttrMultiProcessorCount, deviceId);
  printf("num SMs %i \n", numSMs);
  int numberOfBlocks = numSMs * NUM_BLOCKS_PER_SM;
  return 0;
(Btw, thanks again for all your amazing support! This forum is great!)
How big are the measured differences when they are described as “slightly less” and “slightly more”?
Differences in the range ±2% should be considered non-actionable noise. Complex memory hierarchies in modern processors interacting with scheduling mechanism for the compute load produce at least this much variability especially for memory-intensive code, as it is impossible to reproduce the exact same hardware state for repeated measurements.
By default, modern processors use fast-switching dynamic clocking, so the performance for the same GPU can differ based on environmental factors such as temperature, and can also differ between two GPUs of the same model due to manufacturing tolerances in the GPU die and the sensors for power and temperature.
That code could profit, if it is guaranteed that y, m, xand b are separate non-overlapping arrays.
