About the error 'NoneType' object has no attribute 'create_execution_context'
I try to use yolov3-mobilenet-v2 on my jetson nano and when I create the execution context it give me this error:
AttributeError                            Traceback (most recent call last)
<ipython-input-7-5e5d94a8baad> in __init__(self, model, input_shape, category_num, cuda_ctx)
     26             # 使用create_execution_context创建可推理上下文
---> 27             self.context = self.engine.create_execution_context()
     28             self.inputs, self.outputs, self.bindings, self.stream = allocate_buffers(self.engine)
AttributeError: 'NoneType' object has no attribute 'create_execution_context'
The above exception was the direct cause of the following exception:
RuntimeError                              Traceback (most recent call last)
<ipython-input-15-7e90f933ff27> in <module>
      1 #12
      2 from IPython.display import Image
----> 3 main_one()
      4 Image("result.jpg")
<ipython-input-12-0b6b13d5f07a> in main_one()
      6     cls_dict = get_cls_dict("yolo_mobilenet_v2_traffic".split('_')[-1])
      7     model_name ="yolo_mobilenet_v2_traffic"
----> 8     trtYOLO = TrtYOLO(model_name, INPUT_HW)
      9     vis = BBoxVisualization(cls_dict)
     10     print("start detection!")
     29         # 返回报错信息
     30         except Exception as e:
---> 31             raise RuntimeError('fail to allocate CUDA resources') from e
     32         finally:
     33             if self.cuda_ctx:
RuntimeError: fail to allocate CUDA resources
for the environment:
1. Jetpack 4.4
2. Python 3.6.9
3. TensorRT 7.1
4. CUDA 10.2
5. Numpy 1.16.1
6. Opencv 4.1.1
Since I use jupyter, I cannot copy all the code directly here, here is the main function for inference:
class TrtYOLO(object):
"""TrtYOLO class encapsulates things needed to run TRT YOLO."""
def _load_engine(self):
    # 打开yolo/model_name.bin文件,以二进制只读格式
    TRTbin = 'yolo/%s.bin' % self.model
    with open(TRTbin, 'rb') as f, trt.Runtime(self.trt_logger) as runtime:
        return runtime.deserialize_cuda_engine(f.read())
def __init__(self, model, input_shape, category_num=80, cuda_ctx=None):
    """Initialize TensorRT plugins, engine and conetxt."""
    self.model = model
    self.input_shape = input_shape
    self.category_num = category_num
    self.cuda_ctx = cuda_ctx
    if self.cuda_ctx:
        self.cuda_ctx.push()
    self.inference_fn = do_inference if trt.__version__[0] < '7' else do_inference_v2
    self.trt_logger = trt.Logger(trt.Logger.INFO)
    self.engine = self._load_engine()
    try:
    finally:
        if self.cuda_ctx:
            self.cuda_ctx.pop()
def __del__(self):
    """Free CUDA memories."""
    del self.outputs
    del self.inputs
    del self.stream
def detect(self, img, conf_th=0.3):
    """Detect objects in the input image."""
    img_resized = _preprocess_yolo(img, self.input_shape)
    # Set host input to the image. The do_inference() function
    # will copy the input to the GPU before executing.
    self.inputs[0].host = np.ascontiguousarray(img_resized)
    if self.cuda_ctx:
    trt_outputs = self.inference_fn(
        context=self.context,
        bindings=self.bindings,
        inputs=self.inputs,
        outputs=self.outputs,
        stream=self.stream)
    if self.cuda_ctx:
        self.cuda_ctx.pop()
    boxes, scores, classes = _postprocess_yolo(trt_outputs, img.shape[1], img.shape[0], conf_th)
    # clip x1, y1, x2, y2 within original image
    boxes[:, [0, 2]] = np.clip(boxes[:, [0, 2]], 0, img.shape[1]-1)
    boxes[:, [1, 3]] = np.clip(boxes[:, [1, 3]], 0, img.shape[0]-1)
    return boxes, scores, classes
Here are some documents about the model I use and other related documents:
https://drive.google.com/file/d/1Iw-4sRZNFUwH-gXM-L_vwgD8-jcHln/view?usp=sharing
Could you modify the source to check the error occurs from creating the engine or allocating buffer?
try:
If the error occurs when allocating the buffer, Nano may be running out of memory.
Thanks.,
I used yolov3-resnet18 before and the same error occurred
https://drive.google.com/file/d/1B7_CIIMmRJAtClMYV8QPq4lc3KNzSkPb/view?usp=sharing
I just found out that I provided the wrong file link, this is correct, I am very sorry
Does anyone know how to solve this error
Have you tried the above experiment?
Could you tell us which line leads to the error?
i think is the line 20
I just tried tlt-Infer in my training environment, and it could infer normally. I thought my model was normal. I thought maybe there was something wrong with the code
To add, I changed these codes from the github project of
https://github.com/jkjung-avt/tensorrt_demos
there may be something I overlooked
Hi,I met the same problem, and I have done the experiment, the result was:fail to allocate CUDA resources. How can I solve this? thanks a lot
We try to reproduce this issue in our environment.
But meet error due to some missing library.
  File "signs-detection-yolo.py", line 61, in <module>
    from utils.yolov3_classes import get_cls_dict
ModuleNotFoundError: No module named 'utils'
Could you also share the utils module with us?
