Trying to execute the following utilzing the NVIDIA-AI-IOT/jetbot :
from jetbot import ObjectDetector
model = ObjectDetector(‘ssd_mobilenet_v2_coco.engine’)
here’s the error
AttributeError Traceback (most recent call last)
in
1 from jetbot import ObjectDetector
2
----> 3 model = ObjectDetector(‘ssd_mobilenet_v2_coco.engine’)
/usr/local/lib/python3.6/dist-packages/jetbot-0.3.0-py3.6.egg/jetbot/object_detection.py in init (self, engine_path, preprocess_fn)
26 load_plugins()
27 self.trt_model = TRTModel(engine_path, input_names=[TRT_INPUT_NAME],
—> 28 output_names=[TRT_OUTPUT_NAME, TRT_OUTPUT_NAME + ‘_1’])
29 self.preprocess_fn = preprocess_fn
30
/usr/local/lib/python3.6/dist-packages/jetbot-0.3.0-py3.6.egg/jetbot/tensorrt_model.py in init (self, engine_path, input_names, output_names, final_shapes)
57 with open(engine_path, ‘rb’) as f:
58 self.engine = self.runtime.deserialize_cuda_engine(f.read())
—> 59 self.context = self.engine.create_execution_context()
60
61 if input_names is None:
AttributeError: ‘NoneType’ object has no attribute ‘create_execution_context’
Dou you have solved,I have the smae problem as fllow:
[TensorRT] ERROR: Could not compute dimensions for Concatenate/concat, because the network is not valid
File “main_my.py”, line 43, in
buf = engine.serialize()
AttributeError: ‘NoneType’ object has no attribute ‘serialize’
Hi, kingyuluk
Which image do you use?
Please noticed that you will need to use this image to make jetbot model work:
https://github.com/NVIDIA-AI-IOT/jetbot/wiki/software-setup#step-1—flash-jetbot-image-onto-sd-card
The model shared in the GitHub cannot work with TensorRT 5.1 yet.
Hi, 452302450
The error indicates that there are some compatible issue on the model architecture, which is different from the kingyuluk .
We always encourage user to file a new topic for their own problem so it can be well-handled.
Could you help us doing so?
AastaLLL:
Hi, 452302450
Hi,AastaLLL,
thanks very much,the problem has solved,and is different from the kingyuluk exactly,the reason is Compatibility issues。
AK51
February 14, 2020, 9:12am
6
I have the same AtributeError problem too. Same as the topic indicated. Is there any solution? Thx
I am using Download the expandable JetBot SD card image jetbot_image_v0p4p0.zip
AK51
February 15, 2020, 1:44pm
7
I used the older Jetbot SD card image and the problem is solved.
system
February 17, 2020, 3:50am
8
Hi, I got exactly the same error message:
model = ObjectDetector('ssd_mobilenet_v2_coco.engine')
<ipython-input-3-78c468b59bd4> in <module>
2
----> 3 model = ObjectDetector('ssd_mobilenet_v2_coco.engine')
/usr/local/lib/python3.6/dist-packages/jetbot-0.3.0-py3.6.egg/jetbot/object_detection.py in __init__(self, engine_path, preprocess_fn)
26 load_plugins()
---> 28 output_names=[TRT_OUTPUT_NAME, TRT_OUTPUT_NAME + '_1'])
30
/usr/local/lib/python3.6/dist-packages/jetbot-0.3.0-py3.6.egg/jetbot/tensorrt_model.py in __init__(self, engine_path, input_names, output_names, final_shapes)
57 with open(engine_path, 'rb') as f:
---> 59 self.context = self.engine.create_execution_context()
60
AttributeError: 'NoneType' object has no attribute 'create_execution_context'
I am using JetBot SD card image jetbot_image_v0p4p0.zip and ssd_mobilenet_v2_coco.engine for v0.4 downloaded from ssd_mobilenet_v2_coco.engine - Google Drive
kayccc
February 27, 2020, 6:00am
9
Hi leon-zhang,
Please help to open a new topic for your issue. Thanks
