Here is the script I used based on ssd_tensorrt.py.
This requires JetCard installation (specifically tf-models), Tensorflow 1.x(Tensorflow 1.5.2 for JetPack 4.4), and JetBot.
cd jetbot/jetbot/ssd_tensorrt
python3 ssd_tensorrt.py
import ctypes
import numpy as np
import os
import subprocess
import tensorrt as trt
TRT_INPUT_NAME = 'input'
TRT_OUTPUT_NAME = 'nms'
FROZEN_GRAPH_NAME = 'frozen_inference_graph.pb'
LABEL_IDX = 1
CONFIDENCE_IDX = 2
X0_IDX = 3
Y0_IDX = 4
X1_IDX = 5
Y1_IDX = 6
def download_model(model_name):
import six.moves.urllib as urllib
import tarfile
Download Model form TF's Model Zoo
model_file = model_name + ".tar.gz"
download_base = 'http://download.tensorflow.org/models/object_detection/'
if not os.path.isfile(model_file):
print('{} not found. Downloading it now.'.format(model_file))
opener = urllib.request.URLopener()
opener.retrieve(download_base + model_file, model_file)
else:
print('{} found. Proceed.'.format(model_file))
if not os.path.isdir(model_name):
print('{} not found. Extract it now.'.format(model_name))
tar_file = tarfile.open(model_file)
tar_file.extractall()
tar_file.close()
else:
print('{} found. Proceed.'.format(model_name))
def parse_boxes(outputs):
bboxes = outputs[0]
# iterate through each image index
all_detections = []
for i in range(bboxes.shape[0]):
detections = []
# iterate through each bounding box
for j in range(bboxes.shape[2]):
bbox = bboxes[i][0][j]
label = bbox[LABEL_IDX]
# last detection if < 0
if label < 0:
break
detections.append(dict(
label=int(label),
confidence=float(bbox[CONFIDENCE_IDX]),
bbox=[
float(bbox[X0_IDX]),
float(bbox[Y0_IDX]),
float(bbox[X1_IDX]),
float(bbox[Y1_IDX])
all_detections.append(detections)
return all_detections
def load_plugins():
library_path = os.path.join(
os.path.dirname(os.path.abspath(__file__)), 'libssd_tensorrt.so')
ctypes.CDLL(library_path)
def _get_feature_map_shape(config):
width = config.model.ssd.image_resizer.fixed_shape_resizer.width
fms = []
curr = int(np.ceil(width / 16.0))
for i in range(6):
fms.append(curr)
curr = int(np.ceil(curr / 2.0))
return fms
def _load_config(config_path):
from object_detection.protos.pipeline_pb2 import TrainEvalPipelineConfig
from google.protobuf.text_format import Merge
config = TrainEvalPipelineConfig()
with open(config_path, 'r') as f:
config_str = f.read()
lines = config_str.split('\n')
lines = [line for line in lines if 'batch_norm_trainable' not in line]
config_str = '\n'.join(lines)
Merge(config_str, config)
return config
def ssd_pipeline_to_uff(checkpoint_path, config_path,
tmp_dir='exported_model'):
import graphsurgeon as gs
from object_detection import exporter
import tensorflow as tf
import uff
# TODO(@jwelsh): Implement by extending model builders with
# TensorRT plugin stubs. Currently, this method uses pattern
# matching which is a bit hacky and subject to fail when TF
# object detection API exporter changes. We should add object
# detection as submodule to avoid versioning incompatibilities.
config = _load_config(config_path)
frozen_graph_path = os.path.join(tmp_dir, FROZEN_GRAPH_NAME)
# get input shape
channels = 3
height = config.model.ssd.image_resizer.fixed_shape_resizer.height
tf_config = tf.ConfigProto()
tf_config.gpu_options.allow_growth = True
# export checkpoint and config to frozen graph
with tf.Session(config=tf_config) as tf_sess:
with tf.Graph().as_default() as tf_graph:
subprocess.call(['mkdir', '-p', tmp_dir])
exporter.export_inference_graph(
'image_tensor',
config,
checkpoint_path,
tmp_dir,
input_shape=[1, None, None, 3])
dynamic_graph = gs.DynamicGraph(frozen_graph_path)
# remove all assert nodes
#all_assert_nodes = dynamic_graph.find_nodes_by_op("Assert")
#dynamic_graph.remove(all_assert_nodes, remove_exclusive_dependencies=True)
# forward all identity nodes
all_identity_nodes = dynamic_graph.find_nodes_by_op("Identity")
dynamic_graph.forward_inputs(all_identity_nodes)
# create input plugin
input_plugin = gs.create_plugin_node(
name=TRT_INPUT_NAME,
op="Placeholder",
dtype=tf.float32,
shape=[1, height, width, channels])
# create anchor box generator
anchor_generator_config = config.model.ssd.anchor_generator.ssd_anchor_generator
box_coder_config = config.model.ssd.box_coder.faster_rcnn_box_coder
priorbox_plugin = gs.create_plugin_node(
name="priorbox",
op="GridAnchor_TRT",
minSize=anchor_generator_config.min_scale,
maxSize=anchor_generator_config.max_scale,
aspectRatios=list(anchor_generator_config.aspect_ratios),
variance=[
1.0 / box_coder_config.y_scale, 1.0 / box_coder_config.x_scale,
1.0 / box_coder_config.height_scale,
1.0 / box_coder_config.width_scale
featureMapShapes=_get_feature_map_shape(config),
numLayers=config.model.ssd.anchor_generator.ssd_anchor_generator.
num_layers)
# create nms plugin
nms_config = config.model.ssd.post_processing.batch_non_max_suppression
nms_plugin = gs.create_plugin_node(
name=TRT_OUTPUT_NAME,
op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=nms_config.score_threshold,
nmsThreshold=nms_config.iou_threshold,
topK=nms_config.max_detections_per_class,
keepTopK=nms_config.max_total_detections,
numClasses=config.model.ssd.num_classes + 1, # add background
inputOrder=[1, 2, 0],
confSigmoid=1,
isNormalized=1,
scoreConverter="SIGMOID",
codeType=3)
priorbox_concat_plugin = gs.create_node(
"priorbox_concat", op="ConcatV2", dtype=tf.float32, axis=2)
boxloc_concat_plugin = gs.create_plugin_node(
"boxloc_concat",
op="FlattenConcat_TRT_jetbot",
dtype=tf.float32,
boxconf_concat_plugin = gs.create_plugin_node(
"boxconf_concat",
dtype=tf.float32,
namespace_plugin_map = {
"MultipleGridAnchorGenerator": priorbox_plugin,
"Postprocessor": nms_plugin,
"Preprocessor": input_plugin,
"ToFloat": input_plugin,
"image_tensor": input_plugin,
"Concatenate": priorbox_concat_plugin,
"concat": boxloc_concat_plugin,
"concat_1": boxconf_concat_plugin
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# fix name
for i, name in enumerate(
dynamic_graph.find_nodes_by_op('NMS_TRT')[0].input):
if TRT_INPUT_NAME in name:
dynamic_graph.find_nodes_by_op('NMS_TRT')[0].input.pop(i)
dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
uff_buffer = uff.from_tensorflow(dynamic_graph.as_graph_def(),
[TRT_OUTPUT_NAME])
return uff_buffer
def ssd_uff_to_engine(uff_buffer,
fp16_mode=True,
max_batch_size=1,
max_workspace_size=1 << 26,
min_find_iterations=2,
average_find_iterations=1,
strict_type_constraints=False,
log_level=trt.Logger.INFO):
import uff
# create the tensorrt engine
with trt.Logger(log_level) as logger, trt.Builder(logger) as builder, \
builder.create_network() as network, trt.UffParser() as parser:
# init built in plugins
trt.init_libnvinfer_plugins(logger, '')
# load jetbot plugins
load_plugins()
meta_graph = uff.model.uff_pb2.MetaGraph()
meta_graph.ParseFromString(uff_buffer)
input_node = None
for n in meta_graph.ListFields()[3][1][0].nodes:
if 'Input' in n.operation:
input_node = n
channels = input_node.fields['shape'].i_list.val[3]
height = input_node.fields['shape'].i_list.val[1]
width = input_node.fields['shape'].i_list.val[2]
# parse uff to create network
parser.register_input(TRT_INPUT_NAME, (channels, height, width))
parser.register_output(TRT_OUTPUT_NAME)
parser.parse_buffer(uff_buffer, network)
builder.fp16_mode = fp16_mode
builder.max_batch_size = max_batch_size
builder.max_workspace_size = max_workspace_size
builder.min_find_iterations = min_find_iterations
builder.average_find_iterations = average_find_iterations
builder.strict_type_constraints = strict_type_constraints
engine = builder.build_cuda_engine(network)
return engine
if __name__ == '__main__':
model_name = "ssd_mobilenet_v2_coco_2018_03_29"
checkpoint_path = model_name + "/model.ckpt"
config_path = model_name + "/pipeline.config"
output_engine = "ssd_mobilenet_v2_coco.engine"
uff_buffer = ssd_pipeline_to_uff(checkpoint_path, config_path, tmp_dir='exported_model')
engine = ssd_uff_to_engine(uff_buffer,
fp16_mode=True,
max_batch_size=1,
buf = engine.serialize()
with open(output_engine, 'wb') as f:
f.write(buf)
