I am new to accelerator programming and am attempting to add accelerator directives around some do loops in Fortran code. When I compile with the -Minfo option I get the following debug and am not sure what to do to fix it.
Statement 255 and 390 are not in the acccelerated section.
255, Invariant assignments hoisted out of loop
283, Generating copyin(radiance(:,1,1,1:64))
Generating copyout(model_radiance(1:nwl,1:64))
Generating compute capability 1.0 binary
Generating compute capability 1.3 binary
284, Accelerator restriction: scalar variable live-out from loop: wl
Sequential loop scheduled on host
285, Loop is parallelizable
Accelerator kernel generated
285, !$acc do parallel, vector(32)
Non-stride-1 accesses for array ‘model_radiance’
CC 1.0 : 4 registers; 24 shared, 72 constant, 0 local memory bytes; 33 occupancy
CC 1.3 : 4 registers; 24 shared, 72 constant, 0 local memory bytes; 25 occupancy
290, Accelerator restriction: scalar variable live-out from loop: wl
294, Loop is parallelizable
294, !$acc do parallel, vector(32)
Non-stride-1 accesses for array ‘radiance’
CC 1.0 : 6 registers; 28 shared, 72 constant, 0 local memory bytes; 33 occupancy
CC 1.3 : 6 registers; 28 shared, 72 constant, 0 local memory bytes; 25 occupancy
299, Loop is parallelizable
299, !$acc do parallel, vector(32)
CC 1.0 : 11 registers; 24 shared, 112 constant, 0 local memory bytes; 33 occupancy
CC 1.3 : 11 registers; 24 shared, 112 constant, 0 local memory bytes; 25 occupancy
390, Invariant assignments hoisted out of loop
