I’m trying to make our fortran program to be accelerated.
And I got following compiling massages with no executable file.
I tried to search for this, but could get any clue.
Sorry for making such a blur question, but I don’t know how to fix this.
pgfortran memb.iot.para.f -ta=nvidia,time -Minfo
accelar:
1168, Generating copyin(zj(:))
Generating copy(fzvm(:,1:iatom-1))
Generating copy(fyvm(:,1:iatom-1))
Generating copy(fxvm(:,1:iatom-1))
Generating copy(vvdwj(:,1:iatom-1))
Generating copyin(rvdwj(:))
Generating copyin(evdwj(:))
Generating copyin(nclosej(1:iatom-1))
Generating copyin(linkj(1:iatom-1,:))
Generating copyin(n13j(1:iatom-1))
Generating copyin(xj(:))
Generating copyin(yj(:))
Generating copyin(index3j(1:iatom-1,:))
1169, Accelerator kernel generated
1169, !$acc do parallel
Non-stride-1 accesses for array ‘evdwj’
Non-stride-1 accesses for array ‘rvdwj’
Non-stride-1 accesses for array ‘zj’
Non-stride-1 accesses for array ‘yj’
Non-stride-1 accesses for array ‘xj’
Non-stride-1 accesses for array ‘n13j’
Non-stride-1 accesses for array ‘nclosej’
1170, Accelerator restriction: induction variable live-out from loop: i
Accelerator restriction: induction variable live-out from loop: j
1173, Accelerator restriction: induction variable live-out from loop: i
Inner sequential loop scheduled on accelerator
1174, Accelerator restriction: induction variable live-out from loop: i
1175, Accelerator restriction: induction variable live-out from loop: j
Accelerator restriction: scalar variable live-out from loop: joke
Loop carried scalar dependence for ‘joke’ at line 1175
Scalar last value needed after loop for ‘joke’ at line 1180
Scalar last value needed after loop for ‘joke’ at line 1183
1178, Accelerator restriction: induction variable live-out from loop: i
1179, Accelerator restriction: induction variable live-out from loop: i
1180, Accelerator restriction: induction variable live-out from loop: j
Loop carried scalar dependence for ‘joke’ at line 1180
1185, Accelerator restriction: scalar variable live-out from loop: cute
1186, Accelerator restriction: scalar variable live-out from loop: cut1
1189, Accelerator restriction: induction variable live-out from loop: j
1191, Accelerator restriction: induction variable live-out from loop: j
1193, Accelerator restriction: induction variable live-out from loop: j
1196, Accelerator restriction: scalar variable live-out from loop: rr
1200, Accelerator restriction: induction variable live-out from loop: i
1201, Accelerator restriction: induction variable live-out from loop: j
1203, Accelerator restriction: induction variable live-out from loop: i
1205, Loop carried scalar dependence for ‘sw0’ at line 1228
Loop carried scalar dependence for ‘sw0’ at line 1230
Loop carried scalar dependence for ‘sw0’ at line 1231
Loop carried scalar dependence for ‘sw0’ at line 1232
1206, Loop carried scalar dependence for ‘sw0’ at line 1228
1208, Loop carried scalar dependence for ‘sw0’ at line 1228
1212, Loop carried scalar dependence for ‘dsw’ at line 1230
Loop carried scalar dependence for ‘dsw’ at line 1231
Loop carried scalar dependence for ‘dsw’ at line 1232
1213, Loop carried scalar dependence for ‘dsw’ at line 1230
1215, Loop carried scalar dependence for ‘dsw’ at line 1230
1228, Accelerator restriction: induction variable live-out from loop: i
1230, Accelerator restriction: induction variable live-out from loop: i
1231, Accelerator restriction: induction variable live-out from loop: i
1232, Accelerator restriction: induction variable live-out from loop: i
1281, Accelerator restriction: induction variable live-out from loop: j
1282, Accelerator restriction: induction variable live-out from loop: i
1286, Invariant assignments hoisted out of loop
1356, Accelerator restriction: induction variable live-out from loop: i
/opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_myprocnum': initpar.c:(.text+0x2): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_lcpu’ defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o)
/opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_ncpus': initpar.c:(.text+0x12): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_tcpus’ defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o)
/opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_getioproc': initpar.c:(.text+0x22): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_ioproc’ defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o)
/opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_is_ioproc': initpar.c:(.text+0x32): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_ioproc’ defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o)
initpar.c:(.text+0x38): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_lcpu' defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o) /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_abort’:
initpar.c:(.text+0x5f): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_lcpu' defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o) /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_abortp’:
initpar.c:(.text+0xeb): relocation truncated to fit: R_X86_64_PC32 against symbol__hpf_lcpu' defined in COMMON section in /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o) /opt/pgi/linux86-64/10.0/lib/libpgf90.a(initpar.o): In function__hpf_initarg’:
initpar.c:(.text+0x127): relocation truncated to fit: R_X86_64_PC32 against.bss' initpar.c:(.text+0x151): relocation truncated to fit: R_X86_64_PC32 against.bss’
initpar.c:(.text+0x17b): relocation truncated to fit: R_X86_64_PC32 against `.bss’
initpar.c:(.text+0x18b): additional relocation overflows omitted from the output
The following lines are the code in acc region.
call acc_init( acc_device_nvidia )
!$acc region do parallel, vector(256)
do i = 1, iatom - 1
do j = i + 1, iatom
joke = 0
do k = 1, nclosej(i)
k1 = linkj(i,k)
if( j.eq.k1 ) joke = 1
enddo
do k = 1, n13j(i)
k1 = index3j(i,k)
enddo
if( joke.eq.0 ) then
cute = 20.0/sunit
cut1 = 0.98*cute
econs = 332.0/(eunit*sunit)
xx = (xj(i) - xj(j)) -
s float(int( (xj(i)-xj(j))*2.0/boxa) ) *boxa
yy = (yj(i) - yj(j)) -
s float(int( (yj(i)-yj(j))*2.0/boxb) ) *boxb
zz = (zj(i) - zj(j)) -
s float(int( (zj(i)-zj(j))*2.0/boxc) ) *boxc
rr = sqrt( xx**2 + yy**2 + zz**2 )
if( rr.le.cutoff*1.01 ) then
rii = rvdwj(i)
rjj = rvdwj(j)
rij = (rii + rjj)/2.0
eij = sqrt( evdwj(i)*evdwj(j) )
if(rr.lt.cutoff) sw0=1.0
if(rr.gt.cutoff*1.01) sw0=0.0
if(rr.ge.cutoff.and.rr.le.cutoff*1.01) then
sw0=(cutoff*1.01+2.0*rr-3.0*cutoff)
s *(cutoff*1.01-rr)**2/((0.01*cutoff)**3)
endif
if(rr.lt.cutoff) dsw=0.0
if(rr.gt.cutoff*1.01) dsw=0.0
dsw=6.0*(cutoff-rr)*(cutoff*1.01-rr)/((0.01*cutoff)**3)
endif
aij = rij**6
bij = rij**3
rr6 = rr**6
rr12 = rr6 **2
rr13 = rr12 * rr
rr7 = rr6 * rr
vpart = 4.0*eij*(aij/(rr12) - bij/(rr6))
dpart = 4.0*eij*( -12.0*aij/(rr13) + 6.0*bij/(rr7) )
vdwij = vpart*sw0
vvdwj(j,i) = vpart *sw0
C
fxvm(j,i) = -( dpart*sw0 + vpart*dsw )*(xx/rr)
fyvm(j,i) = -( dpart*sw0 + vpart*dsw )*(yy/rr)
fzvm(j,i) = -( dpart*sw0 + vpart*dsw )*(zz/rr)
! ax(i1) = ax(i1) + fxv
! ay(i1) = ay(i1) + fyv
! az(i1) = az(i1) + fzv
! ax(j1) = ax(j1) - fxv
! ay(j1) = ay(j1) - fyv
! az(j1) = az(j1) - fzv
endif
enddo
enddo
!$acc end region
