here is my algorithm for object detection
it works fine with usb cam or video file but when input RTSP FEED ,i get an error
import cv2
import jetson.inference
import jetson.utils
import sys
import numpy as np
width=1280
height=720
display = jetson.utils.glDisplay() #initialting a
net = jetson.inference.detectNet(“ssd-mobilenet-v2”, threshold=0.5) #loading the model
vs=cv2.VideoCapture(‘rtsp://wakesys:wake1sys2@twp-l.dyndns.biz:555/streaming/channels/101/’) #video input file
while display.IsOpen():
_,frame = vs.read() #reading a frmae
img = cv2.cvtColor(frame, cv2.COLOR_BGR2RGBA) #converting it to a bgra format for jetson util
img = jetson.utils.cudaFromNumpy(img) #converting image to cuda format from numpy array
#img, width, height = camera.CaptureRGBA()
detections = net.Detect(img, width, height) #running detections on each image and saving the results in detections
display.RenderOnce(img, width, height) #display the output frame with detection
display.SetTitle(“Object Detection | Network {:.0f} FPS”.format(net.GetNetworkFPS())) #display title for the output feed
here is the error
[h264 @ 0x496fd5a0] error while decoding MB 94 14, bytestream -9
[h264 @ 0x496fe190] error while decoding MB 94 14, bytestream -9
