Hi evertbody
Environment:
Jetson nano
Jetpack: 4.3
Deepstream 4.02
camera: LCAM0336OD
Issues:
DeepStream fails when detecting objects with an rtsp stream. I have the video but the detection. It works well with video files. But not in RTSP.
run:$deepstream-app -c rtsp_infer-resnet_tracker_fp16_nano.txt
Using winsys: x11
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
KLT Tracker Init
**PERF: 37.60 (37.60)
**PERF: 33.78 (34.53)
**PERF: 30.00 (32.51)
**PERF: 29.99 (31.73)
**PERF: 30.00 (31.32)
**PERF: 30.00 (31.07)
**PERF: 30.00 (30.90)
but no detection:
$cat rtsp_infer-resnet_tracker_fp16_nano.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1024
height=768
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://192.168.100.224/channel1
num-sources=8
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b8_fp16.engine
batch-size=8
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
enable=1
tracker-width=480
tracker-height=272
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[tests]
file-loop=0
I tested implement a new libs in this post RTSP camera access frame issue
Not work
and this post
RTSP stream not loading with deepstream-sdk 4.0 on jetson nano
i tested with yolov3-tiny, not work
/prebuild.sh
export CUDA_VER=10.1
$cat deepstream_app_config_yoloV3_tiny.txt
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1024
height=768
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
#uri=file://../../samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=1
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_fp32.engine
labelfile-path=labels.txt
batch-size=1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3_tiny.txt
[tests]
file-loop=0
$ cat config_infer_primary_yoloV3_tiny.txt
[property]
gpu-id=0
net-scale-factor=1
#0=RGB, 1=BGR, 2=GRAY
model-color-format=0
custom-network-config=yolov3-tiny.cfg
model-file=yolov3-tiny.weights
model-engine-file=model_b1_fp16.engine
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=4
interval=1
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV3Tiny
custom-lib-
path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
$ cat yolov3-tiny.cfg
[net]
# Testing
batch=1
subdivisions=1
# Training
# batch=64
# subdivisions=2
width=416
height=416
channels=3
momentum=0.9
decay=0.0005
angle=0
saturation = 1.5
exposure = 1.5
hue=.1
learning_rate=0.001
burn_in=1000
max_batches = 500200
policy=steps
steps=400000,450000
scales=.1,.1
[convolutional]
batch_normalize=1
filters=16
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=32
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=64
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=128
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=256
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=512
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=1
[convolutional]
batch_normalize=1
filters=1024
size=3
stride=1
pad=1
activation=leaky
[convolutional]
batch_normalize=1
filters=256
size=1
stride=1
pad=1
activation=leaky
[convolutional]
batch_normalize=1
filters=512
size=3
stride=1
pad=1
activation=leaky
[convolutional]
size=1
stride=1
pad=1
filters=255
activation=linear
[yolo]
mask = 3,4,5
anchors = 10,14, 23,27, 37,58, 81,82, 135,169, 344,319
classes=80
num=6
jitter=.3
ignore_thresh = .7
truth_thresh = 1
random=1
[route]
layers = -4
[convolutional]
batch_normalize=1
filters=128
size=1
stride=1
pad=1
activation=leaky
[upsample]
stride=2
[route]
layers = -1, 8
[convolutional]
batch_normalize=1
filters=256
size=3
stride=1
pad=1
activation=leaky
[convolutional]
size=1
stride=1
pad=1
filters=255
activation=linear
[yolo]
mask = 0,1,2
classes=4
num=6
jitter=.3
ignore_thresh = .7
truth_thresh = 1
random=1
run: $deepstream-app -c deepstream_app_config_yoloV3_tiny.txt
Using winsys: x11
0:00:01.039496564 9413 0x3cbab8a0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
Loading pre-trained weights...
Loading complete!
Total Number of weights read : 8858734
layer inp_size out_size weightPtr
(1) conv-bn-leaky 3 x 416 x 416 16 x 416 x 416 496
(2) maxpool 16 x 416 x 416 16 x 208 x 208 496
(3) conv-bn-leaky 16 x 208 x 208 32 x 208 x 208 5232
(4) maxpool 32 x 208 x 208 32 x 104 x 104 5232
(5) conv-bn-leaky 32 x 104 x 104 64 x 104 x 104 23920
(6) maxpool 64 x 104 x 104 64 x 52 x 52 23920
(7) conv-bn-leaky 64 x 52 x 52 128 x 52 x 52 98160
(8) maxpool 128 x 52 x 52 128 x 26 x 26 98160
(9) conv-bn-leaky 128 x 26 x 26 256 x 26 x 26 394096
(10) maxpool 256 x 26 x 26 256 x 13 x 13 394096
(11) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 1575792
(12) maxpool 512 x 13 x 13 512 x 13 x 13 1575792
(13) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 6298480
(14) conv-bn-leaky 1024 x 13 x 13 256 x 13 x 13 6561648
(15) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 7743344
(16) conv-linear 512 x 13 x 13 255 x 13 x 13 7874159
(17) yolo 255 x 13 x 13 255 x 13 x 13 7874159
(18) route - 256 x 13 x 13 7874159
(19) conv-bn-leaky 256 x 13 x 13 128 x 13 x 13 7907439
(20) upsample 128 x 13 x 13 128 x 26 x 26 -
(21) route - 384 x 26 x 26 7907439
(22) conv-bn-leaky 384 x 26 x 26 256 x 26 x 26 8793199
(23) conv-linear 256 x 26 x 26 255 x 26 x 26 8858734
(24) yolo 255 x 26 x 26 255 x 26 x 26 8858734
Output blob names :
yolo_17
yolo_24
Total number of layers: 50
Total number of layers on DLA: 0
Building the TensorRT Engine...
Building complete!
0:03:18.967494762 9609 0x20e568a0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/alex/dev/Deep-Stream-ONNX/sources/objectDetector_Yolo/model_b8_fp16.engine
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 48.49 (48.49)
**PERF: 53.51 (51.89)
**PERF: 53.17 (52.41)
It work with uri file.
Not work with rtsp stream.
I have a video but not not inferenced.
Thank you so much for your answer.
Best regard
JAba
