TX2 Jetpack4.2.2 Deepstream4.0 can't show RTST video
Using TX2 DS4.0 objectDetector_Yolo case, get source from RTSP ,the terminal always should **PERF: 0.00 (0.00) and no video frame,and didn’t have any warning and error.
But it’s OK using --(gst-launch-1.0 rtspsrc location=rtsp://192.168.2.119/554 ! rtph264depay ! queue ! h264parse ! nvv4l2decoder ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=RGBA” ! nvegltransform ! nveglglessink sync=False)
The RTSP also can play by VLC, and this project can work well for some others camera.
sudo ./deepstream-app -c ../../../objectDetector/deepstream_app_config_yoloV3.txt
py_init
Opening in BLOCKING MODE
Using winsys: x11
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is ON
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvdcf/src/modules/NvDCF/NvDCF.cpp, NvDCF() @line 360]: !!![WARNING] Can't open config file (/home/nvidia/AI/DS7/sources/objectDetector/tracker_config.yml). Will go ahead with default values
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvdcf/src/modules/NvDCF/NvDCF.cpp, NvDCF() @line 372]: !!![WARNING] Invalid low-level config file is provided. Will go ahead with default values
[NvDCF] Initialized
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
cb_sourcesetup set 100 latency
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:163>: Pipeline ready
** INFO: <bus_callback:149>: Pipeline running
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
# uri=file://../../samples/streams/sample_1080p_h264.mp4
#uri=rtsp://admin:admin@192.168.2.64:554/cam/realmonitor?channel=1&subtype=2
#uri=rtsp://192.168.2.119/554
#uri=udp://192.168.2.255:23003
uri=rtsp://admin:abc123456@192.168.2.100:554/stream0
#uri=rtsp://192.168.2.12:8554/vlc
# uri=rtsp://admin:admin@192.168.1.64:554/cam/realmonitor?channel=1&subtype=2
#uri=file://../../samples/streams/sample_1080p_h264.mp4
#uri=file://../../samples/streams/v1.mp4
# uri=file://../../samples/streams/DJI.mp4
num-sources=1
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv  3=mpeg4
container=2
#1=h264 2=h265
codec=2
sync=0
bitrate=10000000
#1=cbr 2=vbr
# rc-mode=2
iframeinterval=30
#1=baseline 2=main 3=high
#profile=3
#output-file=file:///home/nvidia/TX2/tensorRT/deepstream_reference_apps-AI/output/out.mp4
output-file=../../../../output/out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
border-width=4
text-size=18
text-color=1;0;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=16
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=model_b1_fp16.engine
labelfile-path=labels.txt
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=19
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3.txt
[tracker]
enable=1
tracker-width=1920
tracker-height=1080
gpu-id=0
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
ll-config-file=tracker_config.yml
enable-batch-process=1
[ds-example]
enable=1
# 640 480 1920 1080
processing-width=1920
processing-height=1080
full-frame=0
unique-id=15
gpu-id=0
[tests]
file-loop=0
If I remove interchanger ,TX2 connect directly with camera, it has this error.
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
ERROR from source: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
Failed to connect. (Generic error)
py_finit
Quitting
App run failed
another camera is no video , using (gst-launch-1.0 rtspsrc location=rtsp://192.168.2.100:554/stream0 ! rtph264depay ! queue ! h264parse ! nvv4l2decoder ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=RGBA” ! nvegltransform ! nveglglessink sync=False)
no video frame and not any error.
gst-launch-1.0 rtspsrc location=rtsp://192.168.2.100:554/stream0 ! rtph264depay ! queue ! h264parse ! nvv4l2decoder ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=RGBA" ! nvegltransform ! nveglglessink sync=False
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.2.100:554/stream0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Please check if you can run this case first.
If test-launch rtsp source is working, the issue should be specific to your IP camera.
But it’s OK for VLC and test-launch ,using the same RTSP address, How to check the issue?
Please confirm you use DS4.0.1
We have fixed some issues of launching RTSP sources.
OK ,thanks ,I will try.
