[Jetson TX2] help!RTSP camera and USB camera did not work in deepstream4.0
fellas,errors encountered during RTSP camera and USB camera tests in Deepstream4.0. Both of the two cameras works good in deepstream1.5. Hardware:TX2
  1. RTSP camera:
    config file:
# Copyright (c) 2018 NVIDIA Corporation.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=4
uri=rtsp://db:db@192.168.3.33:554
camera-width=1280
camera-height=720
camera-fps-n=15
camera-fps-d=1
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=1
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=554
udp-port=5400
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary.txt
[tests]
file-loop=0
error log:
IP carmar
deepstream-app -c source1_csi_dec_infer_resnet_int8.txt
 *** DeepStream: Launched RTSP Streaming at rtsp://localhost:554/ds-test ***
Opening in BLOCKING MODE
Creating LL OSD context new
0:00:01.105170218 20467     0x2489ca70 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:00:01.105287977 20467     0x2489ca70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.105648645 20467     0x2489ca70 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:00:28.955960022 20467     0x2489ca70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/nvidia/deepstream_sdk_v4.0_jetson/samples/models/Primary_Detector/resnet10.caffemodel_b1_fp16.engine
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:163>: Pipeline ready
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
ERROR from src_elem0: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7465): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Failed to connect. (Generic error)
Reset source pipeline reset_source_pipeline 0x7f6ebb1080
,**PERF: 0.00 (0.00)
  1. USB camera(logitec C270 V4L2 supported)
    config file:
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
[source0]
enable=1
type=1
camera-width=1280
camera-height=720
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
[sink0]
enable=1
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
codec=1
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
rtsp-port=8554
udp-port=5400
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
live-source=1
batch-size=1
width=1280
height=720
[primary-gie]
enable=1
#property
batch-size=1
interval=0
gie-unique-id=1
[tests]
file-loop=0
error log:
deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
(deepstream-app:20763): GStreamer-WARNING **: 14:31:25.466: Name 'src_cap_filter' is not unique in bin 'src_sub_bin0', not adding
0:00:01.293572954 20763      0x9ea98a0 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:00:01.293729050 20763      0x9ea98a0 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.294096570 20763      0x9ea98a0 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:00:29.582159979 20763      0x9ea98a0 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/nvidia/deepstream_sdk_v4.0_jetson/samples/models/Primary_Detector/resnet10.caffemodel_b1_fp16.engine
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
** INFO: <bus_callback:149>: Pipeline running
Quitting
App run failed
thanks
Could you try below case?
[url]https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5366807/#5366807[/url]
thanks, i am trying with this.
But what about the USB camera issue? can you give me some hint?
this case you mentioned works on our board, but our RTSP camera still does not work
Please try
[url]https://devtalk.nvidia.com/default/topic/1058381/deepstream-sdk/-tx2-deepstream-4-0-run-failed-with-rtsp-source/post/5367296/#5367296[/url]
[url]https://devtalk.nvidia.com/default/topic/1058381/deepstream-sdk/-tx2-deepstream-4-0-run-failed-with-rtsp-source/post/5367363/#5367363[/url]
Please check
[url]https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5372640/#5372640[/url]
