• Hardware Platform : NVIDIA Tesla T4
• DeepStream Version : 8.0
• TensorRT Version : N/A
• NVIDIA GPU Driver Version : 595.58.03
• Issue Type : NvDCF ReID tracker configurations causing improper detections
• How to reproduce the issue ? : I’m using a custom YOLO based deepstream-app pipeline with the NvDCF Accuracy tracker (with ghost_reid.onnx and updated tracker configs) and comparing its output against deepstream-app without any tracker, it seems evident that the outputs of tracker based deepstream-app are much more inconsistent and have lower accuracies compared to the one without tracker. I have set interval=2 in pgie configs and the accuracies across the two runs seem different, worse in the one with tracker.
here is the pgie config
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=/opt/nvidia/deepstream/deepstream-8.0/sources/apps/sample_apps/deepstream-app/weights/model.onnx
model-engine-file=/opt/nvidia/deepstream/deepstream-8.0/sources/apps/sample_apps/deepstream-app/model_b2_gpu0_fp16.engine
#int8-calib-file=calib.table
labelfile-path=./labels/labels.txt
batch-size=2
network-mode=2
output-tensor-meta=1
num-detected-classes=48
interval=2
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=../custom_lib/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
filter-out-class-ids =
[class-attrs-all]
nms-iou-threshold=0.5
pre-cluster-threshold=0.1
topk=300
tracker-config-file contents:
# SPDX-FileCopyrightText: Copyright (c) 2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
BaseConfig:
minDetectorConfidence: 0.0 # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
TargetManagement:
enableBboxUnClipping: 1 # In case the bbox is likely to be clipped by image border, unclip bbox
preserveStreamUpdateOrder: 0 # When assigning new target ids, preserve input streams' order to keep target ids in a deterministic order over multuple runs
maxTargetsPerStream: 200 # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. Max value depends on the GPU memory capacity
# [Creation & Termination Policy]
minIouDiff4NewTarget: 0.999 # If the IOU between the newly detected object and any of the existing targets is higher than this threshold, this newly detected object will be discarded.
minTrackerConfidence: 0.0 # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
probationAge: 0 # If the target's age exceeds this, the target will be considered to be valid.
maxShadowTrackingAge: 9999 # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
earlyTerminationAge: 9999 # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
TrajectoryManagement:
useUniqueID: 0 # Use 64-bit long Unique ID when assignining tracker ID. Default is [true]
enableReAssoc: 1 # Enable Re-Assoc
# [Re-Assoc Metric: Thresholds for valid candidates]
minMatchingScore4Overall: 0.2 # min matching score for overall
minTrackletMatchingScore: 0.29 # min tracklet similarity score for re-assoc
minMatchingScore4ReidSimilarity: 0.2 # min reid similarity score for re-assoc
# [Re-Assoc Metric: Weights]
matchingScoreWeight4TrackletSimilarity: 0.7981 # weight for tracklet similarity score
matchingScoreWeight4ReidSimilarity: 0.3848 # weight for reid similarity score
# [Re-Assoc: Motion-based]
minTrajectoryLength4Projection: 34 # min trajectory length required to make projected trajectory
prepLength4TrajectoryProjection: 58 # the length of the trajectory during which the state estimator is updated to make projections
trajectoryProjectionLength: 60 # the length of the projected trajectory
maxAngle4TrackletMatching: 67 # max angle difference for tracklet matching [degree]
minSpeedSimilarity4TrackletMatching: 0.05 # min speed similarity for tracklet matching
minBboxSizeSimilarity4TrackletMatching: 0.1 # min bbox size similarity for tracklet matching
maxTrackletMatchingTimeSearchRange: 300 # the search space in time for max tracklet similarity
trajectoryProjectionProcessNoiseScale: 0.0050 # trajectory projector's process noise scale w.r.t. state estimator
trajectoryProjectionMeasurementNoiseScale: 200 # trajectory projector's measurement noise scale w.r.t. state estimator
trackletSpacialSearchRegionScale: 0.100 # the search region scale for peer tracklet
# [Re-Assoc: Reid based. Reid model params are set in ReID section]
reidExtractionInterval: 8 # frame interval to extract reid features per target
DataAssociator:
dataAssociatorType: 0 # the type of data associator among { DEFAULT= 0 }
associationMatcherType: 1 # the type of matching algorithm among { GREEDY=0, CASCADED=1 }
checkClassMatch: 1 # If checked, only the same-class objects are associated with each other. Default: true
# [Association Metric: Thresholds for valid candidates]
minMatchingScore4Overall: 0.0 # Min total score
minMatchingScore4SizeSimilarity: 0.0 # Min bbox size similarity score
minMatchingScore4Iou: 0.0 # Min IOU score
minMatchingScore4VisualSimilarity: 0.0 # Min visual similarity score
# [Association Metric: Weights]
matchingScoreWeight4VisualSimilarity: 0.6 # Weight for the visual similarity (in terms of correlation response ratio)
matchingScoreWeight4SizeSimilarity: 0.3 # Weight for the Size-similarity score
matchingScoreWeight4Iou: 0.4033 # Weight for the IOU score
# [Association Metric: Tentative detections] only uses iou similarity for tentative detections
tentativeDetectorConfidence: 0.0 # If a detection's confidence is lower than this but higher than minDetectorConfidence, then it's considered as a tentative detection
minMatchingScore4TentativeIou: 0.0 # Min iou threshold to match targets and tentative detection
StateEstimator:
stateEstimatorType: 2 # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
# [Dynamics Modeling]
processNoiseVar4Loc: 6810.8668 # Process noise variance for bbox center
processNoiseVar4Size: 1541.8647 # Process noise variance for bbox size
processNoiseVar4Vel: 1348.4874 # Process noise variance for velocity
measurementNoiseVar4Detector: 100.0000 # Measurement noise variance for detector's detection
measurementNoiseVar4Tracker: 150.3238 # Measurement noise variance for tracker's localization
VisualTracker:
visualTrackerType: 1 # the type of visual tracker among { DUMMY=0, NvDCF=1 }
# [NvDCF: Feature Extraction]
useColorNames: 1 # Use ColorNames feature
useHog: 1 # Use Histogram-of-Oriented-Gradient (HOG) feature
featureImgSizeLevel: 5 # Size of a feature image. Valid range: {1, 2, 3, 4, 5}, from the smallest to the largest
featureFocusOffsetFactor_y: -0.1054 # The offset for the center of hanning window relative to the feature height. The center of hanning window would move by (featureFocusOffsetFactor_y*featureMatSize.height) in vertical direction
# [NvDCF: Correlation Filter]
filterLr: 0.0767 # learning rate for DCF filter in exponential moving average. Valid Range: [0.0, 1.0]
filterChannelWeightsLr: 0.0339 # learning rate for the channel weights among feature channels. Valid Range: [0.0, 1.0]
gaussianSigma: 0.5687 # Standard deviation for Gaussian for desired response when creating DCF filter [pixels]
ReID:
reidType: 2 # The type of reid among { DUMMY=0, NvDEEPSORT=1, Reid based reassoc=2, both NvDEEPSORT and reid based reassoc=3}
# [Reid Network Info]
batchSize: 100 # Batch size of reid network
workspaceSize: 1000 # Workspace size to be used by reid engine, in MB
reidFeatureSize: 512 # Size of reid feature
reidHistorySize: 512 # Max number of reid features kept for one object
inferDims: [3,384, 128] # Reid network input dimension CHW or HWC based on inputOrder
networkMode: 1 # Reid network inference precision mode among {fp32=0, fp16=1, int8=2 }
# [Input Preprocessing]
inputOrder: 0 # Reid network input order among { NCHW=0, NHWC=1 }. Batch will be converted to the specified order before reid input.
colorFormat: 0 # Reid network input color format among {RGB=0, BGR=1 }. Batch will be converted to the specified color before reid input.
offsets: [109.1250, 102.6000, 91.3500] # Array of values to be subtracted from each input channel, with length equal to number of channels
netScaleFactor: 0.01742919 # Scaling factor for reid network input after substracting offsets
keepAspc: 1 # Whether to keep aspc ratio when resizing input objects for reid
#useVPICropScaler: 1 # Use VPI for image cropping and rescaling
# [Output Postprocessing]
addFeatureNormalization: 1 # If reid feature is not normalized in network, adding normalization on output so each reid feature has l2 norm equal to 1
minVisibility4GalleryUpdate: 0.3 # Add ReID embedding to the gallery only if the visibility is not lower than this
# [Paths and Names]
onnxFile: "/opt/nvidia/deepstream/deepstream/samples/models/Tracker/ghost_reid.onnx" # NVIDIA TAO model path
tltModelKey: "nvidia_tao" # NVIDIA TAO model key
modelEngineFile: "/opt/nvidia/deepstream/deepstream/samples/models/Tracker/ghost_reid.onnx_b100_gpu0_fp16.engine" # Engine file path
Issues faced with NvDCF custom tracker configs:
- Random Flickering BBOXes
- ID Swapping between objects of different classes
- Excessive VRAM Usage when
maxTargetsPerStreamis over 100 and multiple streams are active - No detections with tracker on with frozen frame videos (single frame running in loop as an mp4 / rtsp stream)
please let me know if there is a solution to preserve pgie level accuracy (similar to python .pt performance) and maintain re-id with tracker from deepstream
