How to have persistent tracking id's when using deepstream app for people detection?
Right now I’m using deepstream to detect people and the problem which I’m facing right now is the tracking id keeps flickering. This was observed with both KLT tracker and NvDCF tracker. When I read the SDK documentation, they mention that using DCF would have less frequent changes in tracker id which isn’t the same when observed using the sample demo videos. Is there anything that could be done to not have the tracker ids flicker?
Could you provide more info on your settings like what sample video you tried with what config?
Can you also add what platform you are using ? Thanks
I’m using Deepstream 4.0.1 with Nvidia GTX 1060 card. I’m not using nano.
@beefshepherd Can you please respond to this question ?
@NvCJR,
sorry for the late reply,
here’s my tracker config,
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Mandatory properties for the tracker:
#   tracker-width
#   tracker-height: needs to be multiple of 6 for NvDCF
#   gpu-id
#   ll-lib-file: path to low-level tracker lib
#   ll-config-file: required for NvDCF, optional for KLT and IOU
[tracker]
tracker-width=640
tracker-height=368
gpu-id=0
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
ll-config-file=tracker_config.yml
enable-batch-process=1
%YAML:1.0
NvDCF:
  useBufferedOutput: 0
  maxTargetsPerStream: 30 # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. Max value depends on the GPU memory capacity
  filterLr: 0.11 # learning rate for DCF filter in exponential moving average. Valid Range: [0.0, 1.0]
  gaussianSigma: 0.75 # Standard deviation for Gaussian for desired response when creating DCF filter
  minDetectorConfidence: 0.0 # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
  minTrackerConfidence: 0.6 # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
  featureImgSizeLevel: 5 # Size of a feature image. Valid range: {1, 2, 3, 4, 5}, from the smallest to the largest
  SearchRegionPaddingScale: 3 # Search region size. Determines how large the search region should be scaled from the target bbox.  Valid range: {1, 2, 3}, from the smallest to the largest
  maxShadowTrackingAge: 9        # Max length of shadow tracking (the shadow tracking age is incremented when (1) there's detector input yet no match or (2) tracker confidence is lower than minTrackerConfidence). Once reached, the tracker will be terminated.
  probationAge: 12                # Once the tracker age (incremented at every frame) reaches this, the tracker is considered to be valid
  earlyTerminationAge: 2         # Early termination age (in terms of shadow tracking age) during the probation period
  minVisibiilty4Tracking: 0.1    # If the visibility of the bbox of a tracker gets lower, then it will be terminated
Could you provide deepstream-app config as well?
It’s not much of an issue. Nvm
