**• Hardware Platform : Jetson Xavier
**• DeepStream Version: 5.0
**• JetPack Version (valid for Jetson only) :
• TensorRT Version : 7.1.3
• Issue Type( questions, new requirements, bugs) Trakcer config question
**• How to reproduce the issue ?
I am intergrating new model that detected vehicle, and I want to check how long the vehicle stopped , I am trying to based on track ID that is calcuated by DCF tracker. But unfortunately , the track ID is updated sequently when other object passes through or moves around the detected object and in sometimes this object is not detected in next severial frames so when it detected again track ID is changed.
I also tried by KLT and IOT but the same result occurred.
Is there is any config that I can change to improve the result?
Thank in advanced!
Cactus
