• Hardware Platform (Jetson / GPU) : Jetson TX2 - 4GB Ram
• DeepStream Version : DS-5.0
• JetPack Version (valid for Jetson only) : JetPack 4.4
• TensorRT Version**
• NVIDIA GPU Driver Version (valid for GPU only)**
We are moving our application from Deepstream-4.X to Deepstream-5.0,
We are setting up a pipeline similar to below one
interpipeSrc-1 -> queue -> NvVideoConvert -> \ / AppSinkBin-1
interpipeSrc-2 -> queue -> NvVideoConvert -> / -> NvStreamMux -> NvInfer -> NvTracker -> NvStreamDemux -> \ AppSinkBin-2
interpipeSrc-N -> queue -> NvVideoConvert -> / \ AppSinkBin-N
this pipeline is correctly working with Deepstream-4.X but when using with Deepstream-5.0 we get following assertion
GPUassert_CUFFT: CUFFT_INVALID_DEVICE /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvdcf/src/modules/NvDCF/NvDCF.cpp 1012
it seems there is something to be adjusted for new tracking … of for new DCF algorithm …
Could it be our tracking/Dcf configuration files require some modfications ?
Can you check what is required at line 1012 of your nvdcf/src/modules/NvDCF/NvDCF.cpp ?
here more traces got during application running
setting gie batch-size to 2
setting gie interval to 2
OK: create_gie_bin_CCM success
OK: create_tracking_bin_CCM success** INFO: <Create_Core_Components:705>
OK: Created element 'demuxer'
... setting CoreInferencePipe to PLAYING ....
gstnvtracker: Loading low-level lib at /mnt/disk/CRS/CCM_AS_CRS/inferNetwork__Tiny_YoloV3/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
terminate called after throwing an instance of 'boost::wrapexcept<boost::log::v2_mt_posix::system_error>'
what(): Failed to set TLS value: Invalid argument
terminate called recursively
