NvDCF Performance Metrics
I’m trying to analyse the trackers included in the Deepstream SDK. But it’s very hard to compare NvDCF with other trackers like DeepSort or ByteTracker or any other paper since there is no published paper on NvDCF. Is there any way I can test a tracker performance within deepstream?
If so, how should I do it? Are there any tests already of someone who decided to test them against each other?
• DeepStream Version
• TensorRT Version
NVIDIA Jetson Xavier AGX
DeepStream SDK 6
4.6
• TensorRT Version
The one in most recent jetpack
-NA
Question
NA
NA
Sorry for the late response, our team will do the investigation and provide suggestions soon. Thanks
We have different tracker config files and how to use it is documented. You can run the perf by yourself. https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvtracker.html and https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Performance.html#configuration-file-settings-for-performance-measurement
