I’m trying to run my YOLOv4 in Deepstream with the NvDCF Tracker. But when I enable it nothing happens. The fps are not dropping and there are no IDs shown. I’m running inside the Deepstream Docker on my RTX 3090. So what problem stopped the tracker from working and how can I solve it?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which
As I said I run it on my RTX 3090 with Deepstream 6.0. It worked last week but it did not out of nowhere. You reproduce the issue by using the config files I provided. The GPU drivers are the newest ones. So it has to be an error with the configuration files.
Can you help to have a try with below samples which include tracker without any change?
