About the tracker is not working in the deepstream
Description
Hello There , want to do the tracker of the object using the yolov8 detection model , i was able to detect the objects and plotthe bbox around it but when i want to track them i was not able to do it , and not getting any error or any thing below i am attaching the my config.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-occupancy-analytics/videos/cam_52.mp4
num-sources=1
gpu-id=0
[source1]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-occupancy-analytics/videos/cam_139.mp4
num-sources=1
gpu-id=0
[source2]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-occupancy-analytics/videos/cam_140.mp4
num-sources=1
gpu-id=0
[source3]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-occupancy-analytics/videos/cam_142.mp4
num-sources=1
gpu-id=0
[sink0]
enable=1
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=6
msg-conv-config-file=msgconv_sample_config.txt
msg-conv-payload-type=0
proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
conn-str=localhost;9092;yolov8-tracked-objects
sync=0
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
display-tracking-id=1
[streammux]
gpu-id=0
live-source=0
batch-size=4
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
config-file=config_infer_primary_yoloV8.txt
nvbuf-memory-type=0
batch-size=1
[tracker]
enable=1
tracker-width=640
tracker-height=384
gpu-id=0
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
enable-batch-process=1
[tests]
file-loop=0
here below is my config_infer_primary_yoloV8.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/DeepStream-Yolo/models/best.pt.onnx
model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
topk=300
i am using this repo for yolo inference
→ GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 8.0 / 7.1 / 7.0 / 6.4 / 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 / 5.1 implementation for YOLO models
Environment
TensorRT Version: 8.6
GPU Type: Jetson orin nx
CUDA Version: 11.4
Moving to Deepstream forum for better assistance.
What exactly do you mean by “not being able to track the objects”? If the tracker is working, the only difference you should see is a number (object id) appearing next to the object label in the overlay.
Is the number not showing up? Or is the tracker losing track of the objects and assigning new IDs?
