TX2 NX
jetpack 4.6
deepstream6.0.1
Yolov5 6.1
The tracker does not take effect, run yolvo5 via deepstream, the output is as follows:
deepstream-app -c deepstream_app_config.txt
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
Deserialize yoloLayer plugin: yolo
0:00:06.054614543 10113 0x5f1ac40 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/lcfc/Desktop/test5/model_b1_gpu0_fp32.engine
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT num_detections 1
2 OUTPUT kFLOAT detection_boxes 25200x4
3 OUTPUT kFLOAT detection_scores 25200
4 OUTPUT kFLOAT detection_classes 25200
0:00:06.054914415 10113 0x5f1ac40 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/lcfc/Desktop/test5/model_b1_gpu0_fp32.engine
0:00:06.312491843 10113 0x5f1ac40 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/lcfc/Desktop/test5/config_infer_primary_yoloV5.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 260
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 260
** INFO: <bus_callback:180>: Pipeline running
**PERF: 17.32 (17.21)
**PERF: 18.01 (17.70)
**PERF: 17.56 (17.59)
**PERF: 17.77 (17.70)
**PERF: 17.45 (17.59)
**PERF: 13.61 (16.91)
**PERF: 13.71 (16.41)
**PERF: 13.74 (16.07)
**PERF: 13.73 (15.78)
**PERF: 13.77 (15.57)
Quitting
[NvMultiObjectTracker] De-initialized
App run successful
I’ve added the following to the config file:
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=config_tracker_IOU.yml
ll-config-file=config_tracker_NvDCF_perf.yml
# ll-config-file=config_tracker_NvDCF_accuracy.yml
# ll-config-file=config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[application]
kitti-track-output-dir=/home/lcfc/Desktop/track
It looks like the video in tile hasn’t changed, and the txt files in the track is empty
