**• Hardware Platform Jetson
**• DeepStream Version 5.1
**• JetPack Version 4.5.1
**• TensorRT Version 7.1.3
I install deepstream-dewarper-app from GitHub - NVIDIA-AI-IOT/Deepstream-Dewarper-App: This project demonstrate how to infer and track from a 360 videos by using the dewarper plugin. and run app:
sudo ./deepstream-dewarper-app 2 1 v4l2:///dev/video0 0 config_dewarper.txt
where config_dewarper.txt:
[property]
#dewarp-dump-frames=10
# aisle-calibration-file property is getting used in case of deepstream-360d-app,
# if set below properties under group [surfaceX] will be ignored
aisle-calibration-file=csv_files/nvaisle_2M.csv
# spot-calibration-file property is getting used in case of deepstream-360d-app,
spot-calibration-file=csv_files/nvspot_2M.csv
# Note - Max 4 surfaces are supported
[surface0]
# 1=PushBroom, 2=VertRadCyl
projection-type=1
surface-index=0
#dewarped surface parameters
width=1280
height=720
top-angle=0
bottom-angle=-35
pitch=90
yaw=0
roll=0
focal-length=437
[surface1]
projection-type=1
surface-index=1
width=1280
height=720
top-angle=0
bottom-angle=-35
pitch=-90
yaw=0
roll=180
focal-length=437
[surface2]
projection-type=2
surface-index=0
width=640
height=1200
top-angle=90.3
bottom-angle=0.3
pitch=0
yaw=0
roll=278
focal-length=437
[surface3]
projection-type=2
surface-index=1
width=640
height=1200
top-angle=90.3
bottom-angle=0.3
pitch=0
yaw=0
roll=98
focal-length=437
but i get output:
args1: v4l2:///dev/video0args2: 0Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
(deepstream-dewarper-app:26914): GStreamer-WARNING **: 22:42:07.127: Name 'nvinfer0' is not unique in bin 'dewarper-app-pipeline', not adding
(deepstream-dewarper-app:26914): GStreamer-WARNING **: 22:42:07.127: Name 'nvtracker' is not unique in bin 'dewarper-app-pipeline', not adding
(deepstream-dewarper-app:26914): GStreamer-WARNING **: 22:42:07.128: Name 'nvtiler' is not unique in bin 'dewarper-app-pipeline', not adding
(deepstream-dewarper-app:26914): GStreamer-WARNING **: 22:42:07.128: Name 'nv-onscreendisplay' is not unique in bin 'dewarper-app-pipeline', not adding
(deepstream-dewarper-app:26914): GStreamer-WARNING **: 22:42:07.128: Name 'fake-renderer' is not unique in bin 'dewarper-app-pipeline', not adding
Now playing:
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:05.171560819 26914 0x557bc0ba70 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/Deepstream-Dewarper-App/inference_files/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 12x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 3x34x60
0:00:05.171701865 26914 0x557bc0ba70 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/Deepstream-Dewarper-App/inference_files/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine
0:00:05.196029493 26914 0x557bc0ba70 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:inference_files/config_infer_primary_peoplenet.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Opening in BLOCKING MODE
Available Sensor modes :
Resolution: 3264 x 2464 ; Framerate = 21.000000; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
Resolution: 3264 x 1848 ; Framerate = 28.000001; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
Resolution: 1920 x 1080 ; Framerate = 29.999999; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
Resolution: 1640 x 1232 ; Framerate = 29.999999; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
Resolution: 1280 x 720 ; Framerate = 59.999999; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
Resolution: 1280 x 720 ; Framerate = 120.000005; Analog Gain Range Min 1.000000, Max 10.625000, Exposure Range Min 13000, Max 683709000
DEFAULT no IOCTL called
Running...
Not Implemented
Segmentation fault
As I understand it, the problem is that the deepstream-dewarper-app starts tracking even though I didn’t ask for it. How can this be fixed?
