• GeForce GTX 1660 Ti Mobile
• DeepStream 6.1
• Ubuntu 20.04
• TensorRT 8.2.5.1
• GStreamer 1.16.2
• NVIDIA driver 510.47.03
• CUDA 11.6 Update 1
• Container nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
I successfuly started deepstream_lpr_app, it works well. I want to use it with Python. So, I tried to start deepstream-lpr-python-version
Log:
codeinside@CI-1442:~/deepstream-lpr-python-version$ python3 deepstream_lpr_app.py 1 3 0 ~/Custom.mp4 out.mp4
['deepstream_lpr_app.py', '1', '3', '0', '/home/codeinside/Custom.mp4', 'out.mp4']
1
deepstream_lpr_app.py:311: PyGIDeprecationWarning: Since version 3.11, calling threads_init is no longer needed. See: https://wiki.gnome.org/PyGObject/Threading
GObject.threads_init()
Creating Pipeline
Creating streamux
Creating source_bin 0
file:///home/codeinside/Custom.mp4
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvdsanalytics
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
Adding elements to Pipeline
Linking elements in the Pipeline
deepstream_lpr_app.py:604: PyGIDeprecationWarning: GObject.MainLoop is deprecated; use GLib.MainLoop instead
loop = GObject.MainLoop()
Now playing...
4 : /home/codeinside/Custom.mp4
Starting pipeline
0:00:01.763463539 11958 0x1d6cf80 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 3]: deserialized trt engine from :/home/codeinside/deepstream-lpr-python-version/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT image_input 3x48x96 min: 1x3x48x96 opt: 16x3x48x96 Max: 16x3x48x96
1 OUTPUT kINT32 tf_op_layer_ArgMax 24 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT tf_op_layer_Max 24 min: 0 opt: 0 Max: 0
ERROR: [TRT]: 3: Cannot find binding of given name: output_bbox/BiasAdd
0:00:01.788161815 11958 0x1d6cf80 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1867> [UID = 3]: Could not find output layer 'output_bbox/BiasAdd' in engine
ERROR: [TRT]: 3: Cannot find binding of given name: output_cov/Sigmoid
0:00:01.788190268 11958 0x1d6cf80 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1867> [UID = 3]: Could not find output layer 'output_cov/Sigmoid' in engine
0:00:01.788199504 11958 0x1d6cf80 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 3]: Use deserialized engine model: /home/codeinside/deepstream-lpr-python-version/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
0:00:01.789206141 11958 0x1d6cf80 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model:lpr_config_sgie_us.txt sucessfully
0:00:02.812658731 11958 0x1d6cf80 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/home/codeinside/deepstream-lpr-python-version/models/LP/LPD/usa_pruned.etlt_b16_gpu0_fp32.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x480x640
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x30x40
2 OUTPUT kFLOAT output_cov/Sigmoid 1x30x40
0:00:02.838844676 11958 0x1d6cf80 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 2]: Use deserialized engine model: /home/codeinside/deepstream-lpr-python-version/models/LP/LPD/usa_pruned.etlt_b16_gpu0_fp32.engine
0:00:02.839647412 11958 0x1d6cf80 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:lpd_us_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
dlopen error: /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
0:00:03.795643615 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 3]: deserialized trt engine from :/home/codeinside/deepstream-lpr-python-version/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
0:00:03.819677638 11958 0x2accc60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1867> [UID = 3]: Could not find output layer 'output_bbox/BiasAdd' in engine
0:00:03.819693625 11958 0x2accc60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1867> [UID = 3]: Could not find output layer 'output_cov/Sigmoid' in engine
0:00:03.819702204 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 3]: Use deserialized engine model: /home/codeinside/deepstream-lpr-python-version/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
0:00:03.820605694 11958 0x2accc60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model:lpr_config_sgie_us.txt sucessfully
0:00:04.572637277 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/home/codeinside/deepstream-lpr-python-version/models/LP/LPD/usa_pruned.etlt_b16_gpu0_fp32.engine
0:00:04.597745508 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 2]: Use deserialized engine model: /home/codeinside/deepstream-lpr-python-version/models/LP/LPD/usa_pruned.etlt_b16_gpu0_fp32.engine
0:00:04.598457992 11958 0x2accc60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:lpd_us_config.txt sucessfully
0:00:04.598733613 11958 0x2accc60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:05.360922359 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/codeinside/deepstream-lpr-python-version/models/tlt_pretrained_models/trafficcamnet/resnet18_trafficcamnet_pruned.etlt_b1_gpu0_fp32.engine
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:05.386662912 11958 0x2accc60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 1]: Use deserialized engine model: /home/codeinside/deepstream-lpr-python-version/models/tlt_pretrained_models/trafficcamnet/resnet18_trafficcamnet_pruned.etlt_b1_gpu0_fp32.engine
0:00:05.387265205 11958 0x2accc60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:trafficamnet_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f92b4c468e0 (GstCapsFeatures at 0x7f91500356e0)>
In cb_newpad
gstname= audio/x-raw
I have not any errors, but it doesn’t display image
