Hi all.
I met one problem. It’s OK if I use deepstream-app to run inference on videos with same model.
When I use this code to run yolov4 on camera source. Without nvtracker or write the pipeline as nvinfer → tiler → tracker, the program can run normally, it can detect objects.
But when I tried to add tracker behind nvinfer and before tiler. The program will fail. The error is this
gstnvtracker: NvBufSurfTransform failed with error -3 while converting buffergstnvtracker: Failed to convert input batch.
0:00:09.743364326 16216 0x55aee9d280 WARN nvinfer
gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<nvinfer0> error: Internal data stream error.
0:00:09.743410920 16216 0x55aee9d280 WARN nvinfer
gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<nvinfer0> error: streaming stopped, reason error (-5)
This is the code I am using.
camera0_pipe = gst_parse_launch("nvarguscamerasrc sensor-id=0 bufapi-version=true ! tee name=c0 \
nvarguscamerasrc sensor-id=1 bufapi-version=true ! tee name=c1 \
nvarguscamerasrc sensor-id=2 bufapi-version=true ! tee name=c2 \
nvarguscamerasrc sensor-id=3 bufapi-version=true ! tee name=c3 \
c0. ! video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12 ! queue ! m.sink_0 \
c1. ! video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12 ! queue ! m.sink_1 \
c2. ! video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12 ! queue ! m.sink_2 \
c3. ! video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12 ! queue ! m.sink_3 \
nvstreammux name=m batch-size=4 width=1920 height=1080 batched-push-timeout=4000000 \
! nvinfer config-file-path=./deepstreamrelated-master/Pytorch_Yolo_V4/config_infer_primary_yoloV4_b8_int8.txt interval=12 ! nvmultistreamtiler width=1920 height=1080 rows=2 columns=2 ! nvtracker tracker-width=608 tracker-height=608 ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so ! nvvideoconvert ! nvdsosd ! queue ! nvegltransform ! nveglglessink sync=false async=false ", NULL);
gst_element_set_state(camera0_pipe,GST_STATE_PLAYING);`
So nvtracker can be only put behind tiler? Because I want to use broker to send out data and I want to have sensor id, the sensor-id will be fix to 0 after tiler.
• Hardware Platform (Jetson / GPU):jetson xavier
• DeepStream Version:5.0
• JetPack Version (valid for Jetson only):4.4
• TensorRT Version:7.1.3
• Issue Type( questions, new requirements, bugs):questions
Thanks in advance
