Unable to enable the NvTracker for objects detected from an RT-DETR model
• Hardware Platform (Jetson / GPU): Thor Dev Kit
• DeepStream Version: 8.0
• JetPack Version (valid for Jetson only): 7.0
• TensorRT Version: 10.13.2
• NVIDIA GPU Driver Version (valid for GPU only): 580.0
Issue Type( questions, new requirements, bugs)
Unable to enable the NvTracker for objects detected from an RT-DETR model.
** INFO: <bus_callback:277>: Pipeline running
GPUassert_VPI: VPI_ERROR_INTERNAL (:EGL_NOT_INITIALIZED) /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/src/modules/VisualTracker/DCFTracker.cpp 269
!![Exception] GPUassert_VPI failed
An exception occurred. GPUassert_VPI failed
gstnvtracker: Low-level tracker lib returned error 1
0:00:01.172834381    54 0xaaaaf1acbe60 WARN                 nvinfer gstnvinfer.cpp:2435:gst_nvinfer_output_loop:<primary_gie> error: Internal data stream error.
ERROR from tracking_tracker: Failed to submit input to tracker
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvtracker2/gstnvtracker.cpp(841): gst_nv_tracker_submit_input_buffer (): /GstPipeline:pipeline/GstBin:tracking_bin/GstNvTracker:tracking_tracker
0:00:01.172947307    54 0xaaaaf1acbe60 WARN                 nvinfer gstnvinfer.cpp:2435:gst_nvinfer_output_loop:<primary_gie> error: streaming stopped, reason error (-5)
ERROR from primary_gie: Internal data stream error.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2435): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
ERROR from qtdemux0: Internal data stream error.
Debug info: ../gst/isomp4/qtdemux.c(7439): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
Quitting
[NvMultiObjectTracker] De-initialized
App run failed
How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Take a trained model, configure deepstream-app to use a tracker like this one:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
# Type 3 = URI/File
type=3
uri=file:///opt/nvidia/deepstream/deepstream-8.0/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[streammux]
gpu-id=0
## Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
## Resolution of the pipeline (adjust to match your video aspect ratio)
width=1920
height=1080
enable-padding=1
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=1
config-file=/model/config_infer_rtdetr.txt
nvbuf-memory-type=0
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=0
clock-y-offset=0
clock-text-size=12
clock-color=1;0;0;0
# CRITICAL: display-mask=1 is required to see segmentation outputs
display-mask=0
display-bbox=1
display-text=1
process-mode=1
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink(Jetson only) 3=File 4=RTSPStreaming 5=nvdrmvideosink
type=2
sync=0
conn-id=0
width=0
height=0
plane-id=1
source-id=0
[sink1]
#source0 output as filesink
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
#bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
# set profile only for hw encoder, sw encoder selects profile based on sw-preset
profile=0
#output-file=out_source0.mp4
output-file=/data/S1000030-output.mp4
source-id=0
msg-conv-dummy-payload=1
Configure the Primary GIE for inference:
[property]
gpu-id=0
offsets=123.675;116.28;103.53
net-scale-factor=0.0173520735728
onnx-file=/model/rtdetr_model.onnx
model-engine-file=/model/rtdetr_model_fp16.engine
labelfile-path=/model/labels.txt
# int8-calib-file=../../models/Primary_Detector/cal_trt.bin
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=9
interval=0
gie-unique-id=1
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/this/directory/libnvds_infercustomparser.so
output-blob-names=pred_boxes;pred_logits
custom-lib-path=/model/libnvds_infercustomparser_tao.so
parse-bbox-func-name=NvDsInferParseCustomDDETRTAO
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=2
#scaling-filter=0
#scaling-compute-hw=0
#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3
#Use the config params below for NMS clustering mode
[class-attrs-all]
topk=20
nms-iou-threshold=0.2
pre-cluster-threshold=0.5
NOTE: I’m using the customparser_tao library
The RT-DETR doesn’t have an official post-processor from Nvidia, but the Deformable DETR post-processor produces bboxes that appear to be valid.
Then attempt to launch the deepstream-app:
#!/bin/bash
docker run -it --rm \
    -v $(pwd)/model:/model \
    -v $(pwd)/data:/data \
    -v /tmp/.X11-unix:/tmp/.X11-unix \
    -e DEBUG2=true \
    -e DISPLAY=$DISPLAY \
    -e GST_DEBUG2=2,GST_SCHEDULING:5,v4l2videoenc:9,nvv4l2h265enc:9 \
    nvcr.io/nvidia/deepstream:8.0-triton-multiarch \
    deepstream-app -c /model/ds_config_rtdetr.txt
Additional Notes:
  • I was able to run inference on the entire video, produce an encoded video output, and see the annotations/bounding boxes.
  • When I enable the tracker, everything fails.
  • Everything works until at least 1 detection occurs, and then when there are no detections, the error happens. I was able to verify this using the -e DEBUG=true environment variable to see from the custom post-processor that there were no detections right before the error happens, but there were in the previous frames.
Seems this configuration file works (NvSORT), so the issue is in the use of NvDCF_perf.yml
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvSORT.yml`
Does config_tracker_NvDCF_perf.yml works with default DeepStream release deepstream-app? If it works, maybe the post process cause the CUDA error. nvtracker checked the CUDA error with CUDA API. So you see the error in nvtracker. You can add cudaGetLastError() to check CUDA error after post process.
NvDCF Works
I was able to run the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display.txt example. This sample points to NvDCF_perf.yml by default.
Debug Logs
I re-compiled the post-processor to include a couple extra lines to verify the CUDA errors:
deepstream_tao_apps/post_processor/nvdsinfer_custombboxparser_tao.cpp:640
    cudaError_t cuda_error = cudaGetLastError();
    const char* cuda_error_name = cudaGetErrorName(cuda_error);
    const char* cuda_error_string = cudaGetErrorString(cuda_error);
    if (cuda_error_name != nullptr) {
        DEBUG_PRINT(cuda_error_name);
    if (cuda_error_string != nullptr) {
        DEBUG_PRINT(cuda_error_string);
Output:
[2025-12-09 17:42:37] DEBUG_PRINT: cudaSuccess
[2025-12-09 17:42:37] DEBUG_PRINT: no error
It obviously logs this message out for each frame.
I see “EGL_NOT_INITIALIZED” in the log. Do you connect the monitor with the Thor and set “export DISPLAY=:0”?
I’m running Thor headless. Is there a requirement for a connected monitor to run this tracker?
For headless, please have a try with: “unset DISPLAY” before run DeepStream command line.
Okay- I revisited the issue this morning. It seems everything is working right now, but I plugged in a monitor. I will try in a headless mode in the next few days as a test. It also didn’t have permission to access the screen so I had to run xhost +.
I had gdm.service stopped entirely. I don’t know if that’s another potential issue or not. Seems like when I run the sync && echo 3 > /proc/sys/vm/drop_caches command the HDMI monitor starts to flicker from that point forward. It doesn’t flicker when gdm is stopped and I only use a terminal/tmux via HDMI though.
As a side note, with sink0 disabled (the display window):
**PERF:  FPS 0 (Avg)
**PERF:  132.40 (159.38)
**PERF:  174.80 (167.80)
**PERF:  157.80 (164.26)
**PERF:  160.00 (163.15)
And with sink0 enabled:
**PERF:  FPS 0 (Avg)
**PERF:  65.60 (78.67)
**PERF:  87.00 (83.20)
**PERF:  87.00 (84.54)
**PERF:  88.60 (85.59)
**PERF:  88.60 (86.21)
**PERF:  88.80 (86.66)
**PERF:  88.60 (86.94)
**PERF:  88.40 (87.13)
**PERF:  88.60 (87.29)
The display window cuts the performance in half.
If you don’t see the nvtracker failed now, we can close the topic. Please submit new topic for other issues.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
