• Hardware Platform (Jetson / GPU) :- Tx2
• DeepStream Version :- deepstream 5.1
• JetPack Version (valid for Jetson only) : -jetpack 4.5
Hello , i am trying to run deepstream-test2 python code on tx2 with new deepstream and jetpack version .
but i am facing issue when trying to run nvcdf tracker instead of klt .
dlopen error: libnvvpi.so.1: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
i am not sure what is the issue as i tried to reinstall the deepstream .
can you please help me find the cause and solution for the same
thank you
