Failed to open low-level lib libnvds_nvdcf.so
**• Hardware Platform: Jetson
**• DeepStream Version:6
**• JetPack Version :4.6
**• TensorRT Version: 8.0.1.6
**• Issue Type:questions
Following the last example in the article, the following errors occur.
$ gst-launch-1.0 filesrc location=streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=1 live-source=1 ! nvinfer config-file-path=../sources/apps/sample_apps/deepstream-nvdsanalytics-test/nvdsanalytics_pgie_config.txt ! nvtracker ll-lib-file = /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so ll-config-file= tracker_config.yml tracker-width=640 tracker-height=384  ! nvdsanalytics config-file=../sources/apps/sample_apps/deepstream-nvdsanalytics-test/config_nvdsanalytics.txt ! nvmultistreamtiler  ! nvvideoconvert  ! nvdsosd ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Using winsys: x11
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
 dlopen error: /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
ERROR: Pipeline doesn't want to pause.
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to NULL ...
Freeing pipeline ...
How to solve this problem?
Please read the DeepStream 6.0 document carefully. Gst-nvtracker — DeepStream 6.1.1 Release documentation
Nvtracker has changed much in DS 6.0.
gst-launch-1.0 filesrc location=streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=1 live-source=1 ! nvinfer config-file-path=../sources/apps/sample_apps/deepstream-nvdsanalytics-test/nvdsanalytics_pgie_config.txt ! nvtracker ll-lib-file = /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml tracker-width=640 tracker-height=384 ! nvdsanalytics config-file=../sources/apps/sample_apps/deepstream-nvdsanalytics-test/config_nvdsanalytics.txt ! nvmultistreamtiler ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
