Regarding doubts about deepstream 6.4 tracker implementation
• Hardware Platform (Jetson / GPU)-Jetson Orin
• DeepStream Version - 6.4
• JetPack Version (valid for Jetson only) - 6.0 -b52
• TensorRT Version - 8.6.2
• NVIDIA GPU Driver Version (valid for GPU only)-12.4
• Issue Type( questions, new requirements, bugs)- Regarding doubts about deep stream 6.4 tracker and now we are implementing person detection wtih tracking using Yolov8 and deepstream 6.4 tracker when using these two techniques but the tracker id is changing and if the person hide behind the wall then then tracker id should not be changed
how to detect person constantly wherever they can move or in same place
and tracker id should be there same
can you help me to resolve the problem?
Can you have a try PeopleNet v2.6.1 with NvDCF_accuracy tracker:Gst-nvtracker — DeepStream documentation 6.4 documentation ?
ok
will it work more accurately
Yes, here is the blog: State-of-the-Art Real-time Multi-Object Trackers with NVIDIA DeepStream SDK 6.2 | NVIDIA Technical Blog
can we use yolov8 instead of PeopleNet v2.6.1?
Yes, you can use yolov8. But we test it with PeopleNet v2.6.1 for people detect as nvtracker accuracy also depend on the accuracy of people detection.
ok thank you
