Questions regarding NvDCF tracker and other trackers supported by Deepstream
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version : 7.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only): 12.0
• Issue Type( questions, new requirements, bugs) questions
I have some queries related to NvDCF tracker available in Deepstream. As per my understanding through the documentation, there are 3 versions of NvDCF, which mainly focusses on accuracy vs GPU usage,
Is there any variant of NvDCF which utilizes only CPU.
Also are there any benchmarking results available of the trackers available in Deepstream on Benchmark datasets like MOT15, MOT20, Dance track.
Also are there any comparision available to popular opensource trackers like OC-SORT.
Here is the CPU/GPU usage of all types of tracker in DeepStream: Gst-nvtracker — DeepStream documentation 6.4 documentation
Why you need the benchmarking result of tracker? If you need to tune tracker, you can have a try with PipeTuner: Gst-nvtracker — DeepStream documentation 6.4 documentation
