Deepstream 6.2 pipeline in C
**• Hardware Platform (Jetson / GPU)**jetson agx xavier
• DeepStream Version6.2
• TensorRT Version
Hi I want to implement the use case for the nvdcf tracker used in this example:
State-of-the-Art Real-time Multi-Object Trackers with NVIDIA DeepStream SDK 6.2 | NVIDIA Technical Blog
Can you make the source code available for this?
Is there also source code available to use multiple cameras with this tracker?
Thank you.
You can use NvDCF tracker in your application. We release nvtracker plugin source code in DeepStream 6.3.
