The exponentially scaled complementary error function computes ex*x and is useful in preventing premature underflow when the complementary error function is combined with fast-growing terms, for example when computing the Mills ratio: M(x) = exp(x*x) * sqrt(π/2) * erfc (x/sqrt(2)). The single-precision implementation of it, erfcxf(), in CUDA 11 has a maximum error of 3.90275 ulps.
In my implementation below, my_erfcxf(), the maximum error is reduced to 2.4504 ulps. On my Quadro RTX 4000 (compute capability 7.5) it performs identically to CUDA’s built-in function within a measurement noise level of 2%. I would expect this to hold across all GPUs currently supported by CUDA.
Copyright (c) 2022, Norbert Juffa
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Compute exponential function with maximum error 0.86565 ulps */
__forceinline__ __device__ float my_expf (float a)
float f, r, j, s, t;
int i, ia;
// exp(a) = 2**i * exp(f); i = rintf (a / log(2))
j = fmaf (1.442695f, a, 12582912.f) - 12582912.f; // 0x1.715476p0, 0x1.8p23
f = fmaf (j, -6.93145752e-1f, a); // -0x1.62e400p-1 // log_2_hi
f = fmaf (j, -1.42860677e-6f, f); // -0x1.7f7d1cp-20 // log_2_lo
i = (int)j;
// approximate r = exp(f) on interval [-log(2)/2, +log(2)/2]
r = 1.37805939e-3f; // 0x1.694000p-10
r = fmaf (r, f, 8.37312452e-3f); // 0x1.125edcp-7
r = fmaf (r, f, 4.16695364e-2f); // 0x1.555b5ap-5
r = fmaf (r, f, 1.66664720e-1f); // 0x1.555450p-3
r = fmaf (r, f, 4.99999851e-1f); // 0x1.fffff6p-2
r = fmaf (r, f, 1.00000000e+0f); // 0x1.000000p+0
// exp(a) = 2**i * r
ia = (i > 0) ? 0 : 0x83000000;
s = __int_as_float (0x7f000000 + ia);
t = __int_as_float ((i << 23) - ia);
r = r * s;
r = r * t;
// handle special cases: severe overflow / underflow
if (fabsf (a) >= 104.0f) r = s * s;
return r;
Compute the exponentially scaled complementary error function exp(x*x)*erfc(x)
maximum error positive half-plane: 1.97521 ulps
maximum error negative half-plane: 2.45040 ulps
__inline__ __device__ float my_erfcxf (float x)
float MY_INF = __int_as_float (0x7f800000);
float a, d, e, p, q, r, s, t;
a = fabsf (x);
/* Compute q = (a-2)/(a+2) accurately. [0,INF) -> [-1,1] */
p = a + 2.0f;
asm ("rcp.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(p)); // r = 1.0f / p
q = fmaf (-4.0f, r, 1.0f);
t = fmaf (q + 1.0f, -2.0f, a);
e = fmaf (-a, q, t);
q = fmaf (r, e, q);
/* Approximate (1+2*a)*exp(a*a)*erfc(a) as p(q)+1 for q in [-1,1] */
p = 5.92619181e-5f; // 0x1.f12000p-15
p = fmaf (p, q, 1.61231728e-4f); // 0x1.5220a0p-13
p = fmaf (p, q, -3.46499495e-4f); // -0x1.6b54c0p-12
p = fmaf (p, q, -1.39683776e-3f); // -0x1.6e2c32p-10
p = fmaf (p, q, 1.20587996e-3f); // 0x1.3c1d3cp-10
p = fmaf (p, q, 8.69013276e-3f); // 0x1.1cc21ep-7
p = fmaf (p, q, -8.01389851e-3f); // -0x1.069974p-7
p = fmaf (p, q, -5.42122647e-2f); // -0x1.bc1b5cp-5
p = fmaf (p, q, 1.64048553e-1f); // 0x1.4ff8b0p-3
p = fmaf (p, q, -1.66031078e-1f); // -0x1.54081ap-3
p = fmaf (p, q, -9.27637145e-2f); // -0x1.7bf5cep-4
p = fmaf (p, q, 2.76978403e-1f); // 0x1.1ba03ap-2
/* Divide (1+p) by (1+2*a) ==> exp(a*a)*erfc(a) */
d = fmaf (0.25f, a, 0.125f);
asm ("rcp.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(d)); // r = 1.0f / d
q = fmaf (p, r, r);
e = fmaf (fmaf (-a, q, 4.0f), 0.25f, fmaf (-0.125f, q, p)); // residual
r = 0.125f * fmaf (e, r, q);
if (a == MY_INF) r = 0.0f;
/* Handle negative arguments: erfcx(x) = 2*exp(x*x) - erfcx(|x|) */
if (x < 0.0f) {
s = x * x;
d = fmaf (x, x, -s);
e = my_expf (s);
r = e - r;
r = fmaf (e, d + d, r);
r = r + e;
if (e == MY_INF) r = e; // avoid creating NaN
return r;
