The single-precision error function, erff(), in CUDA 7.5 is already very fast. For various reasons I spent some time over the holidays trying to build a replacement that is even faster. As it turned out, that is quite hard to do. I managed a mere 4% performance increase as measured on my K2200 (sm_50): function throughput increased from 28.17 billion function calls per second with CUDA 7.5 to 29.32 billion function calls per second with my custom implementation.
I did manage a significant improvement in accuracy, however, with the maximum error of my implementation coming in at 1.29532 ulp, versus the maximum error of 2.33520 ulp of erff() in CUDA 7.5. As you can see from the code below, the two core approximations used are not evenly matched in terms of their maximum error. Therefore, overall accuracy could be improved even further by moving the switchover point between the two approximations down to about 0.85 instead of 1.0. However, moving down the switchover point even slightly resulted in a performance decrease relative to CUDA 7.5 in my tests.
[code below updated 10/13/2016, 7/24/2017, 11/12/2021]
Copyright (c) 2016-2021, Norbert Juffa
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* compute error function. max ulp error = 1.29532 */
__device__ float my_erff (float a)
float r, s, t, u;
t = fabsf (a);
s = a * a;
if (t > 1.0f) {
// ulp error = 1.03872
r = 2.58907676e-5f; // 0x1.b26000p-16
r = fmaf (r, t, -5.64874616e-4f); // -0x1.282830p-11
u = 5.66795561e-3f; // 0x1.737484p-8
u = fmaf (u, t, -3.51759829e-2f); // -0x1.202962p-5
r = fmaf (r, s, u);
r = fmaf (r, t, 1.54329389e-1f); // 0x1.3c110cp-3
r = fmaf (r, t, 9.15674746e-1f); // 0x1.d4d352p-1
r = fmaf (r, t, 6.28459513e-1f); // 0x1.41c572p-1
r = fmaf (r, t, t);
r = -r;
asm ("ex2.approx.ftz.f32 %0,%0;" : "+f"(r));
r = 1.0f - r;
r = __int_as_float (__float_as_int(a) & 0x80000000 | __float_as_int(r));
} else {
// ulp error = 1.29532
r = -5.58853149e-4f; // -0x1.250000p-11
r = fmaf (r, s, 4.90735564e-3f); // 0x1.419bc4p-8
r = fmaf (r, s, -2.67030653e-2f); // -0x1.b580c6p-6
r = fmaf (r, s, 1.12799220e-1f); // 0x1.ce068ep-4
r = fmaf (r, s, -3.76123011e-1f); // -0x1.812664p-2
r = fmaf (r, s, 1.28379121e-1f); // 0x1.06eba2p-3
r = fmaf (r, a, a);
return r;
