I just looked at the module files and they do pretty much what I do (using thee 2020 one and the MPI one). I do not have “module” installed on my local systems, and it is not available in the standard APT repositories. As such, a user just has to know which directories to add to which paths.
Also, it seems there are duplicate binaries for some things.
For example, there is a nsight systems “nsys” in the compiler bin folder but also in the profiler/NsightSystems bin folder and they are not the same.
If I want to use nsight systems or nsight compute, which bin should I use?
One other thing I set up manually is the CUDA library path, CUDA path, and the “CUDA_HOME” env.
I do not think the module files do this.
I don’t know if they are necessary for compiled code but since I have an ubuntu-installed cuda library on my system, I wanted to make sure there are no conflicts.
A simple bash script to source that takes care of all of this in one shot would be nice.
One other thing I noticed in the module files is that they set CC=nvc, FC=nvfortran, etc. This breaks features of a lot of source code packages (such as zlib, hdf5, etc.) as their configure scripts have special sections for PGI but they do not know about the NV compilers. It might be better for now to use the legacy PGI names in the module file or at least provide an alternative module file that does so. I can see a lot of people having issues with this.
